Question about Aprilaire 700 Humidifier
What do i set a humdistate in the winter on a
What percent do i set a humidastate for in the winter on a attic vent fan
  • 686 Answers
45 percent
Posted on Mar 04, 2009
My carrier humidifier has a hose which drains into the laundry sink and a lot of water is coming out. Should this happen in winter? I thought water should only come out in the summer?
The humidifier should run in winter, however if the windows are fogged up it means the humidistat is set too high. Try lowerimg the setting on tue humidistat.
Jan 03, 2013 | Carrier SBP Humidifier
Hi, We have a new house fitted with a Honeywell HE225 humidifier. It does not seem to work. Doesn't matter what we set it to, there is still way too much condensation on all the windows. We ended up...
Cut the power to the whole house humidifier and turn off the water pipe to it. If you want it running in the winter, put the water back on, but put a timer or a humidistat on the power cable to only allow it to run a certain amount of time per day, or to only run it the humidistat shows an RH lower than 45 percent (or whatever your comfort level is).
May 27, 2017 | Honeywell HE225B Humidifier
How far should the humidastate be from the main unit on an aprilaire 550 to get an acurate reading
The humidistat should be mounted in the return air duct, does not really matter how far it is from humidifier as long as it is in the return air duct.
Dec 18, 2010 | Aprilaire 550 Humidifier
What percent should it be set at. It is 68F
Hi google the make it will give you the temp setings
Jan 10, 2010 | Aprilaire 550 Humidifier
Fan does not run. What now? Unit has been cleaned, not used since last winter. When I turn on the fan, it does not start - at any setting. Is there a fuse somewhere? Manual which came with humidifier is...
Not sure what solved the problem: Took fan section control box apart, used compressed air to blow out both areas. Noticed that on/off switch did not stay stable, but was able to re attach knob. By wiggling connections and plug-in, it did finally start.
Jan 08, 2010 | Bemis 427 3002 Humidifier
The power light on my Bemis 4D-7800 humidifier flashes.
On my water wheel several parameters must be met. 1. Power on, cord plugged in. 2. Water in tank, the float arm needs to move to indicate water present, the red light on the dash indicates no water. 3. Humidity controll set higher than the room atmosphere humidity, clockwise is higher on mine. 4. The fan speed selecter must be on either high or low, the fan won't run unless one position is selected. I hope this helps
Dec 30, 2008 | Bemis 4D7-800 Humidifier
Humidifier won't turn on with furnace fan set to Auto.
There is a devise called a current sensing relay (a little black box that hangs on a blower motor wire that senses current from that wire) If you have such a devise it should hang from the white (common) wire. Loop the wire through twice.
Nov 23, 2008 | Aprilaire 600 Humidifier
J-
I had this problem several years ago. In order for the water to flow, the outside temperature sending unit must indicate to the controller that it is less than 60F. If not, the unit will not operate outside of test mode. Check the temp outside where your sending unit is (could the sun be heating that side of the house?) and ensure that the circuit to the sending unit is working. I had a bad wire splice inside a wire nut stopping the circuit. Took me a long while to figure it out.
If the outside temp and your sending unit circuit is ok, I wish you luck on your troubleshooting.
adx_98
Nov 10, 2008 | Aprilaire 600 Humidifier
Hunidifier doesn't add enough moisture to air
here is the link to the manual for the w7 - they suggest a replacement wick filter would solve the problem due to bacteria or mineral build up - i would expect this to solve your problem as the only way these wicks can not soak up the water to the top is if they are clogged or the tank is empty. try the cleaning routine on page 9 first - might be enough but the wicks probably will need replacing soon anyway. http://www.bionaire.com/manuals/W7_English.pdf Hope this helps :)
Mar 08, 2007 | Bionaire W7 Humidifier
Aprilaire 700 Humidifier Logo
63 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
