Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Center partition wall of refrigerator is hot !
I own a KitchenAid KSCS25INSSOO - side-by-side refrigerator.  The serial number is #SS4037843.  The unit is between 3-4 years old and has been operating quite nicely in our kitchen since we bought it.  It still works fine, but I've noticed that recently the 2" wide face of the center partition wall is getting very hot (not warm - hot !).  Even the vinyl/magnetic door gaskets that seal against this thin center wall are getting hot  Concerned, I pulled the frig out from the wall and vacuumed behind.  At this point I noticed that the removable access plate on the bottom/back of the frig was hot as well.  I did a little research online and it sounds like the cooling fan is not operating properly.  Curious if there are operational features that I am not aware of that might solve the problem, or if it is time to call for service.  If it is time for service, How can I check to make sure that I don't pay more than I should ?
Thanks very much - Steve W.
  • Robert Ziegler Sep 23, 2012
    Condenser fan is unobstructed, Coils were very dirty, I had always cleaned along the front, but I see you have to force your way back in there. So, what about a overload switch? I guess I have to check power coming into the condenser but I don't see any good test points
  • 3 Answers
Sounds like your condenser fan isn't working...Take the back cover off to see if there's anything stuck in the fan blades. Usually when the fan stops, the compressor & tubing that runs between the doors get really hot. You may also want to clean your condenser coils.
Posted on Feb 22, 2009
Kitchenaid KSCS23IN Burning Hot Divider Wall then No Compressor, No Fan, No Cold Can Hear Clicking
The clicking is caused by the clixon turning off power to over heated motor that is not starting. Check the condition of the starter cap or relay and change. If a good cap or relay does not start your compressor then the rotor is frozen and you need a new compressor. (ouch)
Mar 12, 2017 | KitchenAid Superba KSCS23IN Side by Side...
Refrigerator model kscs25inssoo. Don't stop filling ice box in the door
you have a problem with the optics--if you look on the inside wall of the freezer section on the left side you will see a eye with a flipper on the left is another eye with the icemaker on off selection when ice reaches that level in the bin it cuts off a laser beam that runs from one side to another which stops power to the icemaker---clean both sets right and left eyes and unplug the fridge for 2min this will reset the optics--if problem still persists you will need new optics-part#-4389102
Mar 27, 2012 | KitchenAid Refrigerators
The center panel is hot. Why?
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101
May 08, 2011 | KitchenAid KSCS23FV Side by Side...
I have a KSSC48QMSO1, The center panel, that divides the freezer from the refrigerator is hot to the touch at the top end and only where the side doors close together. Also the refrigerator is not holding...
could be a problem with a dirty condenser or your condenser fan may be no good. That will cause the center panel to be hot and will prevent the refrigerator from cooling properly. Is the sides of the fridge hot to the touch as well?
Mar 18, 2011 | KitchenAid KSSC48QMS Side by Side...
The center wall that runs vertically between the freezer and refrigerator compartment is very hot on the end that is exposed when you open the refrigerator door (hot enough that the magnetic strip that...
Well, that is were a heating wire runs to evaporate condensation at the seal. So it is normal that it gets slightly hot, but if really hot, then call for service
Jun 18, 2017 | KitchenAid Superba® Architect® KSRP22FSMS...
Cleaned the condenser on my kitchenaid superba model kscs25Inssoo, but freezer is still making a loud humming sound. What could it be?
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 18, 2011 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Side by Side Refrigerator
hi thanks for the question is the compressor running . pull away from the wall remove back cover and check the compressor if its hot and running with no cooling you have a failed compressor thanks the appliance doc
Sep 26, 2008 | KitchenAid (KSRD22FKST) Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
536 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
