Question about Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine
Starter on tecumseh H30 motor for a Troy Built Tuffy tiller won't
My starter cord broke. I took the starter off and put back the cord. When I pulled the cord to try it, it wouldn't recoil. Does anyone know how to make the cord recoil with each pull.
2 Suggested Answers
  • 69 Answers
SOURCE: does rear tine tiller run 2 belts
Check the Troybuilt website for specific info on your tiller.
www.troybuilt.com
Posted on May 06, 2009
Can't start my Troy Built Tuffy tiller. I haven't used it for a year, but it started fine last season. I replaced the spark plug, changed the oil and air filter and filled it with fresh gas. When I pull...
First pull your spark plug out reconnect to the plug wire and ground tot he engine body
Pull the starter cord and see if you have a good clean spark that goes to the electrode and not to the side of the spark plug.
If no spark check your off/on switch
Mar 31, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy bilt hasn't been used in 2yrs.; has oil and gas in it but will not electric or pull cord start...
1st I would drain the gas and put new in. It loses octane over time. Then try new spark plug. Also you may need a new diaphram in the carburetor. They are cheap and sell them at most hardware stores.
Dec 20, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
I have a Troy Bilt Tuffy Tiller H30-35387S Ser 91330. The only number I can find for the tiller is on the shaft housing between the tines and the wheels and it is X0010527. I need a manual or parts diagram...
You've got the right serial number - it appears you've got one of the older Tuffy's. I'd suggest keeping an eye on Ebay for the manual you're looking for. I find them out there with some regularity. You can't get them from a dealer anymore because this Tuffy was sold by Troy Bilt before they went bankrupt and MTD bought the assets.
Jul 07, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
I have an old pressure washer that uses Tecumseh H30 engine. After pumping the choke bulb on the carb, it will crank, run maybe 5 seconds and quit. Thanks
When you get it started, move the choke to the middle, then let it warm up. you might have to move the choke back and forth until it warms up, keep the throttle wide open.
Jun 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy Bilt Rotor tiller, won't start
lac spark plug on motor pull cord if no spark take the pull start cover off and sand rust off fly wheel
May 05, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Free wheel
Shift your Wheel gear lever to "disengage". Use the disengage position only when the engine is not running.
Apr 19, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Does rear tine tiller run 2 belts
www.troybuilt.com
Mar 22, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Need manual for a Troy-Bilt Tuffy tiller
Your engine number is wrong by only one character. The proper number is H30-35387S you had a 5 instead of the S. You can download the engine manual from Tecumseh. I don't know about The rest of the tiller. (I have the same tiller).
Feb 21, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Can't start snowblower with electric start.
Our pull cord broke .came out and now can not thread it back in and when we do cannot do it tight enough . Will not work . Thanking You Linda
Dec 20, 2008 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine Logo
491 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
