Question about Logitech R-10 Computer Speakers
Silly question Logitech r-10 speakers which is the left - the one with the controls?
    President:
  • 2,992 Answers
The speaker with the controls is the RIGHT speaker in every system I have ever seen.
Posted on Mar 04, 2009
Hi .. i have just bought a logitech x 530 speaker and only 2 of the speaker parts work .. can you please give me some solution advice?
Hi names Rui i like to help you by giving you step by step instruction in propely hocking up your logitech speakers:
Instructions
1. Connect the black plug of the rear right speaker into the black plug on the subwoofer.
2. Connect the yellow plug on the rear left speaker into the yellow input on the subwoofer.
3. Connect the red plug of the front center speaker into the red input on the subwoofer.
4. Connect the white plug of the front left speaker into the white input on the subwoofer.
5. Connect the d-sub connector plug from the front right speaker into the d-plug connector on the subwoofer.
6. Connect the green, black and orange input to the matching plugs on your computer. If you have a four-channel sound card, connect the green plug from the input audio cable to the front plug of the card and the black plug to the rear plug. Do not connect the orange input. If you are using a two-channel sound card, connect the green plug from the input audio cable to the "Line Out" jack on the sound card. Do not connect the green and orange plug.
7. Plug the subwoofer power chord into the electrical power outlet.
8. Place your subwoofer on ground around your computer desk. Position the front center speaker on top of your computer monitor.
9. Place the left and right front speakers on the sides of the monitor. Position the left and right rear speakers behind you, making sure they are pointing toward the front left and right speakers.
10. needs to support 5.1 surround. Normally, more than three sockets for sound indicates that it does. Then you need to use the software that comes with the sound hardware to configure it for 5.1 - Default will be 2.1 or just 2.
Check the control panel out. This is a lot easier under Windows 7.- Here you can access what you need via the speaker icon on the system tray (right click)
There is NO problem with your OS or hardware, this is pretty standard...
hope this will help you solve your problem.
Jul 18, 2011 | Logitech X-530 Computer Speakers
I don't have any CD or Driver of Logitech R 10 Speakar, So please tell what can i do?
I can help you with your logitech R10 speaker problem.
The Logitech R10 speakers do not ship with drivers. Please refer to the R10 Speaker setup guide which you can download direct from Logitech.
Your sound card may require drivers to be re-installed. Check where your speakers are plugged into, (line level rather than speaker preferred) and check your Control Panel > Sounds settings to make sure it is not muted and selected correctly.
I hope that helps.
Aug 30, 2010 | Computers & Internet
My right rear does not work and i have test averthing. what should i do now? Logitech z5450
mcdevito75 here, There should be a volume control on either the left or right speaker, maybe both, check the volume control on both speakers. also the connections to your computer.
Jun 22, 2010 | Logitech Z-5450 Computer Speakers
How can I connect my logitech x-230 speakers to my new laptop with windows 7? Never had probs before
Windows 7 adds High Definition and other sound features. Sound can be selecting in many more ways and it gets even tricker with microphones.
But this should do it:
Left Click "Start"
type "control panel" enter or click on menu selection
Left click "Sounds"
Enable your speakers from the default settings
Mar 27, 2010 | Logitech X-230 Computer Speakers
No CD and cannot find driver for Logitech R-10 speakers-HELP
The R10 speakers are analog speaker drivers are not needed, you may need drivers for your sound card-- quick test plug a headset into the green port on the back of your computer. if there is sound coming thru then the sound card is fine and you need to make sure your connection are correct. if no sound, plug the headset into the front ports for headphones. if sound is coming thru there but not in back the sound card needs replacement the port is bad.
Download the drivers from this link
http://www.logitech.com/index.cfm/downlo...
if you still have a problem try
http://logitech-en-amr.custhelp.com/cgi-...
Hope this helps :)
Sep 15, 2009 | Logitech R-10 Computer Speakers
I have Logitech X-230 speakers. The left speaker
CHECK THE POWER SUPPLY TO THE SPEAKERS
REPLACE ITEM IF POWER TRANSMISSION IN NIL
Jul 18, 2009 | Logitech X-230 Computer Speakers
Logitech R-10 speakers sound problem
in control panel, go to hardware and sound, click on realtech audio manager with your logitech speakers plugged in, and then you should be able to chose your speaker configuration. If that doesn't work, try going to sound, and configuring your speaker setup there. Realtech has different settings you can click on, including volume, as well as various equalizer settings which you choose if you want to sound like you are in a sadium, bathtub, etc.
Mar 09, 2008 | Logitech R-10 Computer Speakers
Both rear speakers on my z540 system play only the left side rear
Hmmm, this sounds like either a driver issue, or a card/compatibility issue. you might try reverting to old drivers(last resort), making shure you have 4.1 enabled in sound control pannel(do this first), triple checking connections/connectors on both the speakers and the card(remember, you only have 5 speakers, not 8) and if you have the headphone-type phone plug for your speakers, you might try making shure that they are compatible with the jacks on your card, although, I would have to know more about your setup to be completely shure.
Dec 26, 2007 | Logitech Z-540 Speaker
Trying to hook up z-10 computers, problems with USB
Check your device manager for "!"
Device Manager:
-Right click my computer on your desktop
-Choose manager
-On the left pane click device manager.
Nov 13, 2007 | Logitech Z-10 Computer Speakers
Channel not working
If the Logitech Pulse 475 is the same as the Labtech Pulse 475 then the left channel amplifier probably blew. The Labtec uses a 5 pin TDA2030A, which costs around $3. You will need to know how to solder to repair this. The back of the case comes off by removing the 8 screws around the back of the case and lifting it out by the power cord. Then, simply desolder the left channel amplifier marked IC201 (it's on the leftmost side of the board, next to the volume potentiometer) and solder the new amplifier in it's place.
Jun 19, 2006 | Logitech Z-680 Computer Speakers
Logitech R-10 Computer Speakers Logo
55 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
