Question about Zanussi IZ12 Front Load Washer
Error messages displayed on my zanussi iz12 washing machine e20 and e40 explain please
    Master:
  • Zanussi Master
  • 480 Answers
E20 - Problems with water drain in wash phase
(maximum 10 minutes for each drain phase)
Possible causes: Drain hose obstructed; filter blocked; drain pump;
pressure switches; wiring; main PCB
E40 - door oopen, problem with door closure, triac which powers the door interlock faulty
Possible causes: Door open; door interlock; wiring; main PCB
Dado
Posted on Jul 06, 2015
E40 the door not been closed e20 the drain hose may be kinked
Posted on Feb 25, 2009
Hi, good evening. I have a zanussi iz12 washing machine that stops during rinse node and gives e20 fault (wont drain). I checked the pump - working fine. I've found that if i blow into the waste pipe the...
Hi there
I have an IZ12 jetsystem which sometimes works and other times it starts and then clicks and stops just before the water starts to run in. I usually turn it off and try it again a few hours later and then it starts to work again. Sometimes it is the next day before it will work again. Would anyone know the problem?
Jan 11, 2010 | Zanussi IZ12 Front Load Washer
Error E20
zanussi error E20 suggests a pump/draining problem. remove pump/filter and clean it all out. its located at the end of the drain hose at the bottom of machine. power off. it might need replacement.
Nov 01, 2009 | Zanussi ZWF1430W Front Load Washer
Zanussi IZ12 mid program door light comes on.
E40 is a door interlock fault, it is either faulty or the wiring between it and the main board is at fault,
Only way to open door is to remove top cover, and try to force the door open from the inside, if you can see the door latch, try pushing it with a screw driver or something to release it, worst case scenario, is you will have to break the lock to release the door.
Please rate my fixya solution.
Thanks.
Jan 31, 2009 | Hotpoint WMA30 Front Load Washer
E40 fault code zannusi washing machine.
You could look here:
RepairClinic.com (good)
espares.co.uk
AppliancePartsPros.com
Jan 31, 2009 | Zanussi IZ12 Front Load Washer
Error message on washing machine E20
E20 is "A problem with water draining"
Solutions:
The drain hose may be squashed or kinked
the drain pump may be blocked
or possible your filter is totally blocked. Clean out the filter everything will work again. Put a large bowl under the filter as you unscrew it; a fair amount of water could be there.
Good luck.Please rate the solution if accepted, also do post comments in case of any doubts.
Jan 23, 2009 | Zanussi Washing Machines
Zwd1471s washer dryer
E20 code on Zanussi washer dryer ZWD1471
washing machine working but dryer is not .
Any advice please
Mar 24, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
E20 message
Hi Helenw,
The error message E20, simply means the filter plastic cage which is located behind the trap door bottom right side of the machine is full and needs to be cleaned out.
All the fibres and lint gets trapped in here and prevents the waste water from escaping, hence Error code E20.
Regards,
David
Sep 12, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Zanussi IZ12 Front Load Washer Logo
604 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
