Question about Western Digital Computers & Internet
My wd my book when plugged to computer will not give me any useful data,such as a memeo to look up the condition.I plugged and played mybook but no response was given to me . Thanks for your time , hoping to hear from you
  • 298 Answers
Is it External USB?
Try replacing the USB cable - these external USB HDD are known to come with cheap, made in ??? cables that turn out to be ****. Loose or iffy connections between the Power or Data and Clock pins/connections while WRITING may/will result in data loss, HDD corruption or just plain toast.
Spend 10-15.00 and get a good one with heavier-type cable that will work.
Posted on Feb 26, 2009
Change mybook from one pc to another
You have to install the backup software on the new computer. Either download from WD to use what came with the MyBook. Attach the MyBook and find it in My Computer. If it is not there, you have to reboot and find the attached device. After Windows recognized the drive, the backup software will ask you for a new backup but just decline and reactivate the plan (actions/reactivate). That should do it!
Dec 05, 2011 | Western Digital My Book Essential Edition...
I have a WD elements 250 hard drive for backing up, my computer is quite old by the way, but whenever I try to use it I receeive a message which basically says that I have to join Memeo before I can use...
Although it is not mandatory, but memeo is lite program that comes with WD hard drive that enable it to perform an automatic backup for you, so that even when you are away and not on your PC, it automatically backs up your data to your specified folder.
It is actually good to join the Memeo, but if it is made to be optional on your HDDrive, that is, if it autoruns the moment you plug it, and asks 'IF' you would like to enable/join it, then I would advise you to use it.
Hope this helps you out.
Thanks For using Fixya,.
Apr 25, 2010 | Western Digital Elements powered by WD 320...
I bought a new WD Elements 350gb external hard drive and it came with a Memeo software CD. It says to insert CD before starting backup. I do not appear to be able to use this external hard drive as a plug...
This software is not linked with the drive (with this particular drive you only get a trial version anyway). Just remove the software from your PC.
Start > Control Panel > Add or Remove Programs > Remove Memeo/ WD Anywhere Backup.
Once you have done that, you can delete everything on it (assuming you never manually put something on it apart from the backup). If so, back it up onto your PC, another drive or CD.
Jan 25, 2010 | Western Digital Elements powered by WD 320...
My external backup will not back up and to use I need product number.Where can I find it?
The my book essential only comes with a trial version of Memeo / WD Anywhere Backup, which can only be used for 30-days. Your only option to use the backup software with the drive, is to purchase it. However, you could use another software or alternatively manually copy / paste your data over to the drive.
If it's any help, windows also has a built-in backup and restore function.
WinXP - C:\WINDOWS\system32\ntbackup
Vista - Start > In the search bar, type: Backup. Open the executable.
Win 7 - Open my cumputer > right-click on your C-drive > select properties > select the 'tools' tab and select 'backup now'
Jan 16, 2010 | Western Digital 320GB MyBook External USB...
Computer doesn't recognize WD MyBook 500GB but no error message
Try using the western digital knowledge base info to help you resolve the problem...click here.
Otherwise, we need the full model # and the OS you're using to give better solutions....
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 23, 2009 | Western Digital My Book Essential Edition...
Ignoring and uninstalling Memeo Autobackup software
Yes, you do not need the Memeo software as long as it is plug and play.
Apr 28, 2009 | Western Digital 320GB MyBook External USB...
Cannot Find the Product code for registration with memeo?
that's what happens when you buy a laptop... lots of trial software that you are expected to buy if you want to keep using it. I would however check the documentation that came with the hard drive. there may be a registration number for the software there.
Robert
Jan 14, 2009 | Western Digital 320GB MyBook External USB...
Computer suddenly not recognizing relatively new WD MyBook 640GB
Just a shot in the dark, but ..., shut down your computer and unplug the drive. Turn the hard drive off, then back on. Plug it back into the computer and restart. If it doesn't pop up, restart your computer this time with it plugged in.
Is there any noise coming from the drive? Is the green light on the front?
The same thing happened to me and the same drive, but 500gb. I did the above and it fired right back up again. You may have to delete the trial version from the drive if it on there, or from your computer if you had originally installed it.
Jan 07, 2009 | Western Digital 320GB MyBook External USB...
How do you set up multiple WD Anywhere users on the network to share the same MyBook World Edition
hey,
-No WD Anywhere allows 5 users I think.
This could only be the solution, if you installed WD Anywhere on other PCs before
Check out the MioNet site, think they give options for new users.
if this is not the problem, I don't have a solution by now.
bye
Feb 08, 2008 | Western Digital 500GB My Book World...
Product key
Hi Guys,
Not all WD have inside the box a software product key for booldy Memeo Auto Backup thing. You need to buy the software and until wou get tha cash you can use free trial version.
They are quite pathetic how the trick the clients with unfriendly software provided by a "third party".
So we need to dig for more cash for the "master of puppets"
Next time I will buy only products with hard and soft inclucluded in the box. I on a learning "curve".
Here I attached the answer from teh WD site:
Cheers, Calin
WD Anywhere Backup
WD Anywhere Backup comes on our drives as a 30 day trial version software only. In order to use it, permanently, you will need the product key. The following Western Digital products come packaged with the product key:
  • Drives With Product Key - My Book Home, My Book Office, My Book Studio, My Book World, Passport Elite, My Book Mirror, and WD ShareSpace
  • Trial Version Only - My Book Essential
Your product key can be found in the installation manual, on a sticker, in the technical support section. If you have one of the drives that comes with a product key, and your installation manual does not have the product key sticker, please contact us using the Ask WD A Question page for a replacement product key.
Memeo AutoSync
We do not provide a product key for Memeo AutoSync. Memeo AutoSync is a 30 day trial version, and you will need to purchase it from Memeo in order to obtain a product key.
I hope that helps!
Dec 29, 2007 | Western Digital My Book Essential Edition...
Computers & Internet Logo
93 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
