Question about Garden
Small Engine Tuneup (Tecumseh HS50)
I have an old Toro 421 with a 5HP Tecumseh HS40-55531 3F.
Engine wouldn't start at all when I got it.
I replaced the carb and it then it took off on the second pull.
I'm trying to tune it up and I'm looking for specs on things such as spark plug choice/gap, point gap setting, oil type/capacity.
Here's what I've been able to gather so far:
Points 30547A
Condensor 30548B
Any help would be appreciated:
Thanks, Dan
  • worldwidedan Feb 23, 2009
    Thanks Jerr! - Very helpful
  • eric4brs Mar 02, 2009
    tecumseh 5hp snow blower stalls when I put load on engine how do i tune it under load
  • 151 Answers
SOURCE: 93 Vw Fox tune up specs
no points on ur car (check from the center of distributor cap and follw that wire, it leads to the COIL) and gap is usually indicated under the hood on a sticker. Should be right near the front of the hood (on the underside) or just above the rad.
Posted on Nov 16, 2008
  • 641 Answers
SOURCE: starts runs min. or two then stops....
Go to toro.com then click customer care, then click manuals and parts. Type in model no. and download the owners manual. This should get you the spark and flywheel gap. Probably still something in the carb. Some orifices are very hard to find and to clean but they must be clean. Also check for dirt dopper nest in the muffler.
Posted on Apr 06, 2009
  • 15 Answers
SOURCE: briggs and stratton lawnmower 4horse power engine needegap specs on coil and points
That's easy man! You will always hear, "You sir, need to gap this or that at EXACTLY .00071542 inches per square meter".
The actual "poor boy fix"-
Put your magneto back on there, and stick a business card from your wallet in between it and the rotor. Let the magneto pull itself to it, you center it, and give it just a hair of breathing room (to slide the card back out). Tighten 'er down, and you got it.
1.- If you can't pull the card out, it is too tight.
2.- If you pull the card out easily, too loose.
3.- JUST enough to pull it out, and have it drag just a bit on the way out is JUST ENOUGH!
Remember, on 4-strokes, they ARE forgiving, and can do miracles even if you try your best to destroy them.
Posted on May 30, 2009
panilling9
  • 284 Answers
SOURCE: 4.5hp Sears/Tecumseh motor starts and dies in 5 - 10 seconds.
metal or plasic float?
Posted on Jun 21, 2009
garing
  • 998 Answers
SOURCE: My 550 series Bolens lawnmower won't start. When
keep pushing the prime button
Posted on Aug 08, 2009
I have a 5hp tecumseh motor HS50-67324K on a craftman snow blower,could you please tell me the high and low RPM speed settings on this unit.
Here is a 70 page Tecumseh service guide. Locate the type of carburetor you have in the guide. All instructions with diagrams are available. This is a PDF file. Adobe Reader will be needed to view it.
http://www.smallenginesuppliers.com/html/engine-specs/tecumseh/Tecumseh_quick_reference.pdf
Dec 14, 2010 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Electric Starting Difficulty on Toro mower with Tecumseh engine
it sounds like to me that the starter pully is getting caught up on the worm gear ,this could be because of dirt or grass getting in the way make sure that no grass or dirt is around the worm gear
Mar 03, 2010 | Garden
Cable
I'll tell you what I did to a cable like that on an old mower of mine, if you promise not to laugh at an old ****. I cut my cable shorter and fashioned a little bushing out of some small weedeater fuel line, so the edge of the hole on the lever wouldn't wear on the cable, and crimped a small cable clamp in the position I wanted and was back in action. Hope this helped, don't laugh, and best wishes.
Jul 28, 2009 | Garden
My tecumseh 5 hp engine will start but then after
Hello:
Operate the Engine Unitl it Quits and then Check for Fire to the Plug.
If No Fire, then the Ign Coil/Module Requires Replacing.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Garden Logo
1,237 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
