Question about Sony PlayStation Portable (PSP) Console
PSP won't play a game
My PSP won't play any of my games,I put it in close the back then it pops up in the games isle i select it,But it won't come up.. It doesent do a thing
  • 3 Answers
Lens may need cleaning
Posted on Feb 23, 2009
Sorry i have posted my 1st comment wrong. hi, I have recently bought my Sony PSP 2000 (piano black). It do not play the copy game CD's of UMD. When I bought that copy CD and put in my PSP it gives...
Here try this method.
  1. Open your Psp and Press Select to show the menu.
  2. Now Change the USB Device from Memory Stick change it to UMD Disc.
  3. And Exit the menu.
  4. Make Sure that you UMD GAME in inserted in the drive.
  5. Now insert your usb cable into your computer.
  6. On your PSP , GO to settings and USB CONNECTION
  7. Now on your computer go to MY COMPUTER and Double Click your PSP DRIVE.
  8. Now on your PSP Folder, Copy the game ISO and paste it in your Desktop
  9. Now Download and Install this software DOWNLOAD LINK
  10. Once install, Run this software.
  11. Choose compress ISO to CSO.
  12. on INPUT FILE, Browse for the game ISO, ( We save it in desktop )
  13. on OUTPUT FILE, Select the destination where you want to save the COMPRESSED FILE.
  14. Now choose your compression level ( I Suggest you choose 9 - Best Compression )
  15. Click Compress and wait for the process to finish.
  16. Now lets go back to your PSP, Press Select Again to show the menu.
  17. Now Change the USB DEVICE back to MEMORY STICK
  18. Go to your Settings and USB CONNECTION.
  19. Now on your computer, Open Your PSP Drive.
  20. Go to ISO Folder, (DO NOT CLOSE)
  21. Go to the Folder where you save the compressed file.
  22. Copy the compressed file and paste it in your ISO Folder.
  23. Now go to your PSP and Play the game.
  24. Enjoy.
Goodluck in doing this method. Hope i Helped. Please give me Feedback regarding my solution thanks.
Jul 05, 2011 | Sony PSP (Piano Black)
When I switch on my PSP, it directly goes onto load the UMD game and when I try to quit using HOME button, the buttons and consoles dont work. Then I need to use the hold button after which though the...
Hi. Since you're in UMD Autoload mode, you need to configure that in the PSP Settings. To do this, turn off your PSP and remove your UMD. Now, turn it back on and it won't autoload your UMD since it wasn't there anymore.
Now, go to "Settings" and scroll down to "System Settings" and press X. Scroll down again the selection until you see "UMD Auto-Start" and press X. At the right side will appear the options "ON" and "OFF". Select "OFF" and press O button several times to go back to main screen.
Insert your UMD. Now, try playing games from Memory Stick. You may have to turn off your PSP and turn it on again to finally play homebrew...
I hope this helps...
Jun 07, 2011 | Sony PlayStation Portable (PSP) Console
Cant play games downloaded for psp
make sure that you put the downloaded games in the GAME folder (capital letters are important) which itself is inside the PSP folder (capitals also important) so the folder you would put them in would look like F:\PSP\GAME\
All game files should end with PSP.
To play the games, from the PSP menu go to GAME then press X and scroll to select your game then press X again to confirm.
If your PSP firmware is above 1.5, it might be that you are trying to play protected games and it is why they cannot play.
Make sure you do not violate any intellectual property.
Regards,
Jan 13, 2011 | Sony PlayStation Portable (PSP) Console
Psp wont play umds or games
you have to attach back on the side that popped off if u post a picture it well lead to a more detailed and specific answer
Jul 21, 2010 | Sony PlayStation Portable (PSP) Console
Oblivion expansion will not load
The shivering isles isn't in anvil. First go to your map, scroll to bravil and look off to the right in the water. You should see a small piece of land that you can travel to, this is the door to shivering isles. I have this game, its amazing!
Oct 07, 2009 | Take 2 Interactive Elder Scrolls IV:...
I cant play the game in memory stick..
you'd first have to downgrade your psp. try to lower it to 3.50 or 4. something. then insert the .pbp file... this file is a hack.. or an upgrader for a psp.. once you do this.. your psp will be back to version 5.03 but now you can play downloadable games.
Jul 27, 2009 | Sony PlayStation Portable (PSP) Console
Psp repair
It sounds like there is a loose hinge on the door. Check the back of the PSP to make sure it is properly closed.
Apr 13, 2008 | Video Game Consoles & Games
PSP wont play games
To play game on your memory stick you'll need Custom Firmware installed such as M33/OE on your PSP, else if you play a UMD. The last CFw Update is 3.71M33-3.
What is version on your PSP? (on PSP Menu, move across to the "Settings Menu". Scroll down, select to "System Settings" > "System Information" and you should see version of your PSP.)
Here's, how to install CFw Guides. Hope this be of some help/idea. Pls post back a detail should you need additional information. ^_^
Nov 20, 2007 | Sony PlayStation Portable (PSP) Console
While playing with PSP it suddenly gets stuck and screen goes blank
check battery, run without the battery, using ac adapter, see if problem persists did you update psp firmware? if so, undo the update, go back to previous firmware version
Aug 26, 2007 | Video Game Consoles & Games
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
