Question about Car Audio & Video
Car Stereo Code??
I have a 1996 Mitsubishi Eclipse Spider - Infinity Radio W032 and it was requesting the code and I don't know it. Now the radio just says off. Does anyone know the code to re-start the radio? Any help would be appreciated.
Thanks
  • 95 Answers
The code is a user code that someone had enter at an earlier date and when the radio loses power it goes into security mode, thats what you have right now. The only way to get this code is you have to call infinity tech services and a tech will walk you through the steps in reseting the code
Posted on Feb 23, 2009
  • Tim C. Sep 07, 2012
    It's not asking for a code. It just says audio off and won't respond to anything including switching source. It's a Bose system. Any suggestions?
Mitsubishi Eclipse Spider Gt-S I cannot figure out how to get the fascia panel and face plate off of the radio to get to the numbers needed to retrieve the radio code. How do I take the panels OFF?
Hi
The stereo in the Eclipse can be removed with nothing more than a Phillips screwdriver
Disconnect the negative battery cable from your Eclipse's battery. Remove the two Phillips screws along the bottom of the radio/climate control trim panel. Lift up the bottom of the trim panel to unlock the lower retaining clips. Work your fingers around the sides of the panel to loosen the other clips and remove the panel. Remove the four Phillips screws holding the stereo in place. Slide the stereo out of the dashboard and disconnect the wiring harness and antenna cable from the back of the device.
Also check this link if it helps:-
http://www.ehow.com/how_5938157_remove-eclipse-car-radio.html
May 04, 2011 | Mitsubishi Car Audio & Video
My dead battery disconnected my car stereo and I need the code to get it going again - it's a 96 magna
call dealership with thw radio serial number they should have code on record
Feb 09, 2011 | 1996 Mitsubishi Eclipse
My stereo doesnt work it says code on it and i was needing to know how to get the code or how can i make the stereo work and its a 2001 mitsubishi eclipse?
Some radios have an antitheft feature built in. When the power is disconnected (like in replacing a battery or if the radio was removed or stolen from a car) then you have to enter a code to activate it. Call the dealer and ask if they can help you with the code and procedures. Your owner's manual should have the procedure listed in it but the code should have been in the papers that came with your car when it was new. Again the dealer is your best bet. They will need your vehicle VIN and maybe even the radio serial number. There are some web sites that offer to sell you radio codes but I have had good luck with the dealers giving me them free.
Mar 02, 2010 | 2001 Mitsubishi Eclipse Spyder
Need an unlock code for an infinity radio in my mitsubishi eclipse.............
that radio may plug in but the code gonna be a infinity code the mitsubishi wont accept you need a sony ,jvc ,keenwood or other i have an original radio for the eclipse if you want it and the cd player if your isnt working
Dec 31, 2009 | 2000 Mitsubishi Eclipse
I LOOSE CODE FOR RADIO MITSUBISHI DIAMANTE 98. PLEASE LETME KNOW HOW CAN GET THE CODE. THANKS
call dealer with vin number, you may have to go down with id to prove it your car radio and your reg, good luck.
Oct 13, 2009 | 1996 Mitsubishi Eclipse
Need car stereo lock code mitsubishi spider eclipse
I've read that will work ok. The radio will change from locked to being ready for the code. Make sure you know the procedure for entering the code.
Apr 27, 2009 | 2002 Mitsubishi Eclipse Spyder
Radio locked up
Yeah! Pull the radio out .. Write down Serial Number.. Call Mitsubishi.. And THEY CAN give you a code.. Thank you
Mar 15, 2009 | 1996 Mitsubishi Eclipse
Electrical problem, Infinity radio ''code'', cannot find in records
well to test if ur alternator is going bad take off ur pos wire on battery and if it keeps running it's good if it stops it's ur alternator and for the code for radio is 1523 thats for if the car shut off or battery died and after u put the code in hit tape if u got any questions email me at gsxturbo1@yahoo.com
Nov 19, 2008 | 1999 Mitsubishi Eclipse
Factory stereo code
Factory radio codes are an anti-theft deterrent, they are unique to each radio and car serial number, in order to get the code the dealer will have to access the manufacturers data base, you will need to pull the radio and record the radio model number and the serial number of the chassis of the radio and take it to the dealer, they will not in most cases give the info out over the phone, this would defeat the whole purpose of the code.
Oct 18, 2008 | 2000 Mitsubishi Eclipse
Car Audio & Video Logo
155 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
