Question about Karcher 2500 PSI Pressure Washer
Tune-up of old Tecumseh HS40
I have an old Toro 421 with a 5HP Tecumseh HS40-55531 3F.
Engine wouldn't start at all when I got it.
I replaced the carb and it then it took off on the second pull.
I'm trying to tune it up and I'm looking for specs on things such as spark plug choice/gap, point gap setting, oil type/capacity.
Here's what I've been able to gather so far:
Points 30547A
Condensor 30548B
Any help would be appreciated:
Thanks, Dan
  • worldwidedan Feb 23, 2009
    I gotta lot of problems for you - I'll be back!
  • 18 Answers
SOURCE: Karcher 2400R
You have a poor signal to the spark plug usually caused by a rusty fly wheel found underneath the pullcord casing. clean it with releasing ajent such as wd 40. common when not in use for a while.
Posted on Sep 19, 2008
picatudo
  • 239 Answers
SOURCE: Briggs 6.75hp Will Not Start and it's Brand New!
you need a new had gasket or a new piston
Posted on Dec 28, 2008
  • 583 Answers
SOURCE: It looks like gas getting into the crankcase oil,
here`s the go ,good possibility that you didn`t turn the gas tap off at the last time you used it.If the needle isn`t seating properly the gas wii over flowinto the carburetterif the inlet valve is open ,fuel can ,if the macine is on uneven ground run back into bthe cylinder and over a period seep into the sump. I`ve only seen it once .I am assuming it is a GX140 motor, so dont tilt it back too far or the same thing will happen with the oil and the mufler eventually gets full and it will sm oke like a forrest fire for a month. why do you say it takes longer to warm up ?is it because you have to have abit of choke for longer ?if so it is a mixture problem .and no it doesn`t need a new spark plug.
Posted on Aug 18, 2009
  • 241 Answers
SOURCE: pull cord getting stuck
Pull starter rope wheel is Jamming against casing usually some lube n check for ware will fix it
Posted on Mar 24, 2010
SOURCE: Press. Washer Honda engine gx 390 will not start
did you leave fuel in it from last year, if so remove all fuel from tank, drain carb. (remove float bowl if it doesn't have a drain bolt) put in fresh fuel, check your oil level and you should be good to go. if not, please take it to a qualified tech. for carb. cleaning.
Doc
Posted on May 17, 2010
6.5 toro self propel.....new plug and new gas,,,turns over but then shuts down...replaced both neoprene hoses
Carburetor Cleaning TUNE UP of Toro 6 5HP Lawnmower with Tecumseh Engine
The above link will provide a video on how to clean the carb on the 6.5 hp mower. Before you go to that length, try putting some carb cleaner in the fuel tank and see if that corrects the problem. Also, as the video shows, make sure the spark plug is getting a good spark. If the spark is weak , the fly wheel may be rusted, ot the magneto is bad.
May 09, 2014 | Garden
Toro 6.5 tecumseh won't start
replace your spark plug. it takes a Champion J19LM. If you left fuel in your tank over the winter then drain your tank and your float bowl. Add clean fresh fuel and it should go if not you need to clean your carb
May 17, 2012 | Toro Power Lawn Mower
Toro recycler 20017 is very hard to start. it has to be primed many times. after it run a while it starts on one pull.
The carburetor may need to be serviced. You need to find a parts shop that handles Tecumseh parts. You will most likely need a rebuild kit for the carburetor. The carburetor part number is 640303. The rebuild kit is 632809. The Tecumseh engine company shut its' doors 3 years ago. Finding parts is becoming harder and harder. I've heard that someone has bought Tecumseh over the winter but it is unknown when the new parts will hit the market. Best of luck to you.
Apr 03, 2011 | Toro Power Lawn Mower
Electric Starting Difficulty on Toro mower with Tecumseh engine
it sounds like to me that the starter pully is getting caught up on the worm gear ,this could be because of dirt or grass getting in the way make sure that no grass or dirt is around the worm gear
Mar 03, 2010 | Garden
Need replacement engine or short block for Tecumseh LEV120-361541B
Tecumseh has gone bankrupt so finding parts and engines has been difficult. i would see if i could find a B&S engine with the same bolt pattern to mount on the deck.
Sep 30, 2009 | Toro Lawn Mower With Toro Power Tools
Tecumseh Snow King HS40 engine only runs on full choke, no power
i did and thanks - just picked up one that does the same thing and i plan to take your advise
Thank you Jerr
Jan 01, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
444 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
