Question about Makita HP1500- Factory-Reconditioned 5 Amp 9/16" Hammer Drill
I'm trying to repace the switch on a Makita HP1500 drill. They've changed the design and the new switch (TG803TLB-1 / 6519867) is wired differently to the old one. How do I find out which wire goes where? There are 10 wires in total!! Most wire positions in the old switch look to have similar counterparts in the new switch, but one is not in the same place and it isn't obvious which location on the new switch it is meant to go in....
  • David Ford
    David Ford May 11, 2010
    I have yet to find wiring directions online but I would suggest that you call Makita Tech at 1-800-4625482 and either have one faxed or emailed to you. If not let me know and I will get you one.
    Problem Solver:
  • 12 Answers
I have a wiring diagram that I could email you. I took it out of my Makita book and just made a copy of it.
Posted on Feb 26, 2009
  • Jorg Hornickel May 03, 2013
    Good day, I am experiencing a similar problem with the Makita MLT100 table saw, could you perhaps email the wiring diagram as well? My email adress is I will appreciate it, thanks.
Drill is not working
first measure of the batterie if its loaden ,only if the brushes are to short replace also anyway the armature and brushes BOTH . it is not good to switch only the carbonbrushes because of a marketing technical design concept because of the heat dissipation that playing tricks insite the armature and it is cheap made by Johnson
sometimes the half value compared to other brandnames.
Armatures are new designed in a short time
23465970-2oroqqetjko0hjqmfukebeah-4-0.jpgleft the armature of the old but same cdd 18 milwaukee no problems you can change only the brushes and its working again right the same modificated armature marketing technical a new design of this JOHNSON Armature (Johnson is also used in Panasonic powertools bv EY7441 ) it has much more force in the same armature but the heat dissipation plays tricks and if the brushes are to short replace anytime BOTH (the brushes and the armature look at the difference of the turns of the coil front right look the later design more and thiny wire on it more power force but a bad heat dissipation in about 2 or 3 years the brushes are on its end take by heavy work a more powerful tool its better longlasting then this machines Makita has oft a better armature but there are also posibillities in some tools.
Feb 11, 2014 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Wiring diagram for HP1501 using 6519867 switch Replacing old switch with 6519867. Different terminals from old one.Like to find a wiring diagram so I can install it... Thanks, Les
Makita doesn't furnish online schematics for replacement parts, BUT you can call their tech department and they should be able to send one as a PDF. Call them at 1-800-4625482. They do have one online for the original switch at "" but not the replacement. Let me know if you need more assistance.
Apr 10, 2011 | Makita Drills
Makita ML902 Flashlight how to open case housing to repair
Makita ML902 - great flashlight. but I wanted to upgrade the lamp to LED, and found that the POLARITY was wrong . so i HAD to open the dern thang. the 'special tool' and 'keep in-house' conspiracy had me 'fuming' ... turns out if one were to mark the EXACT spot that the pivot occurs with a felt pen, by drilling a small (sized) hole on each side, (stop as soon as the bit is thru! the shiney material that you stop at are lamp straps) then pressing 2 stiff objects from both sides, the head pops off ! one more screw is uncovered, making it an even 4 screws holding it all together. When i opened the case up, one wire wasn't even soldered to the switch ! aargh. so - swapped polarity, re-soldered the connections, add a bit of fresh solder, re-assemble, voila! I love the 9 volt cases, upgrading everything to 12v and 16v lithium 18650 cells. these old Makita ensembles are great! saw, drill, angle drill, light...
Mar 29, 2010 | Makita Drills
Makita HP1640 hammer drill dual mode - 2 hours
Exchanged Makita HP1640 hammer drill for a new one. The 2nd drill did the same thing in under an hour!! Will return for refund. Instructions say the Forward/Reverse switch must be in a full up or down position for the Hammer/Rotary switch to move; well, it is and the Hammer/Rotary switch still stops at a 1/2 way point between modes. Although I can still use the drill, instruction warnings say not to because it may potentially burn out the motor. I'll have to go with a different brand this 3rd time around. It seems to be a design flaw.
Oct 10, 2009 | Makita Drills
Drill motor runs at full speed as soon as plugged in
I would have to think that it is more of a switch issue than brushes. If you remove one half of the handle do you see that the switch is burnt? But either way the current has to run thru it and if it runs when plugged in the contacts have welded shut to complete the circuit would be me guess. You can get a switch almost anywhere or go to and order it direct. Let me know what happens please.
Feb 18, 2009 | Makita HP1500- Factory-Reconditioned 5 Amp...
Makita electric drill
the header lists 2 different tools but if you give me the model number I will find a cord set for you and the wiring diagram that you need. If you also give me the area (US only) I will try and find someone local that has what you need.
Oct 28, 2008 | Makita 6932FDWDE 14.4V Impact Driver
Makita HP1500- Factory-Reconditioned 5 Amp 9/16" Hammer Drill Logo
546 people viewed this question
Top Makita Drills Experts
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
