There is water in the bottom of the dishwasher and it wont drain away, i have washed out the filter and tried to set in for a rinse cycle but now a tap sign has appeared on the display and it wont start.
You can check the drain or the filter. You will have to pull it out of
the space it is now to access it. Items will get stuck in the drain
clogging it.
It could either be the filter (most likely), the drain pump (likely) or the drain hose/tube (least likely).
Normally,
there would a filter somewhere at the bottom of your washing machine with
the primary function of keeping loose clothing, torn fabric, lint, fluff and foreign objects away from the impeller/pump. Most
current washing machine have self-cleaning filters and therefore regular
cleaning is no longer a concern. However, some other washing machine need
to have
the filter manually removed and cleaned regularly or as even in your
case. If the filter or grate is
clogged or blocked with debris, it may interfere with the normal
functioning of your washing machine and may cause the problem as you have
described; water doesn't leave the tub.
To
check the filter and/or the drain pump, the bottom has to be exposed,
the filter/pump located and cleaned. In some instances, the drain could
be a valve operated by a solenoid.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Bosch E25ErrorThe drainpump is blocked or restricted by debrisPossibly something stuck/jammed in the wash or drainpropeller, remove filter mesh at the bottom of the dishwasher. Carefully remove any excess water and debris jammed near the propeller caution there may be glassor debris near or where the water drains-out.Removeand clean the spray arms, they may have food debris jammed, rinse in hot runningwaterMaintainerWash Runa wash with a tablespoon of powder, without any dishes on the hottest settinge.g. intensive, 65C, if you have a 70C this will be more effective.
Ive had this happen on mine too. remove the filters in the bottom. squirt washing up liquid into the space-- liberally dont be shy! Boil pans of water, boil the kettle. pour water into the space where the filters normally are. Fill the base of the dishwasher completely. Next close the door and repeatedly use the Reset feature. Eventually the pump will clear and kick back into life. Its a build up of fats, and sludge that causes the pump to appear to seize--the washing up liquid and boiling water see to that.
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
To access the pump filter, remove lower plastic panel at front of washer, there you will see the filter, unscrew filter cover anti clockwise, remove and clean filter.
You will probably find that whatever was causing the clicking noise is something in the filter.
If you can't see anything in it , then have a look inside the pump housing before you replace filter.
Plz rate my solution .
Thanks.
Hello Ramona Doug,
Try disconnecting power from your dishwasher for a few minutes to clear the memory and then reapply power again. Start a wash cycle without dishes on the hottest water setting and after a few minutes.. pause the wash and add a few cups of white vinegar to the wash water.,. that will help break up deposits in the system.. See if that gets you going properly.
Regards
Same problem. Not draining or working and tap sign showing.
