Question about Dell MRMGA8 RADEON X300 SE, (128 MB) Graphic Card
Card not recognized
I've been having some serious problems with my Dell Dimension 8400 computer, including losing my hard drive twice, my network card(probably), and, for the past few months, I can't load a driver for my 1704FPT monitor. Moreover, in the Dell "present" configuration it shows no card loaded, but it's in there. I've unplugged and plugged it back in, checked cables and connectors, etc., but to no avail.
I run off a Belkin huge battery backup, with surge protector, but from the problems I've had I'm suspecting that somehow a surge made it through, sometime. Replacing the network card re-established my network connections, e.g. And my monitor is failing after about 20 minutes of running.
Bought the d______d system in April, 2005 . . . . pretty penny. Not pleased.
  • 5 more comments
  • Jonathan James
    Jonathan James Feb 22, 2009
    I have replaced the hard drive twice . . . first time about 1-1/2 years ago, and then again six month later. Lost everything, of course. But the problem right now is the monitor.
    FYI - in 1992 I bought a 386 sx, which was still working fine 15 years later, just SLOOOOOOOOW. Wouldn't run most of my programs. I'm still using a Compaq my wife bought me in 1995, because it runs the DOS drivers for my cad plotter . . . but it, too, plugs right along. Why shouldn't I expect the same of a more recent unit?
  • Jonathan James
    Jonathan James Feb 26, 2009
    So far Farcry1010 has the most useful response; I was able to download a driver, which proved to be the right one, and which I thought I had installed before. That made the monitor work as it's supposd to, except that it still stalls, and goes black. Interestingly, I found by accident that if I rapped on the screen with some determination, I could restart the display, and it would stay lit for varying amounts of timem from a few minutes to over four hours, but eventually it would fail again. Mechanical problem, I woud guess; I've checked all the connections and everythiong's tight, clean, etc. New monitor, I guess.
    So far as the disk goes, I've replaced the hard drive twice. I was unable to format it, or even get the computer to recognize there was a hard drive in place, each time. I could boot from a floppy, and I tried one program for disk recovery, but right now those two valuable disks are in a drawer, waiting until I can get at them and recover a lot of stuff I hadn't backed up in several months . . . I'd have been more careful about that except that I paid a good penny and my computer wasn't very old, with massive storage . . . . .
    Thanks to all. Any other suggestions, like how to get to the pc board in the monitor and look for loose lands, etc., would be appreciated. LONG time out of warranty.
    JLJames
  • Jonathan James
    Jonathan James Mar 01, 2009
    RODGANDYSR -
    Misunderstanding here - I haven't tried to install a new card. My hard drive quit, and in reinstallling software to a new drive, I appaantently loaded what I tyhought was the proper driver for my existing card, but after going to MS's website I found it wasn't. The driver I downloaded there has remedied almsot everything except the basic problem I'm having with my monitor, which, after some experimenting, seems to be a bad connection inside the case.
    Anyway, thank you for your replay.
    JLJames
  • Chuck May 11, 2010
    im glad to help alittle., It is so hard to to tell you where to look further without seeing it in front of me. Now as far as you formatting it what is it that you are formatting? Is this your main drive with operating system installed? if so and you did all your backups just use the Windows Operating System disc. When it tells you to boot from cd (make sure your boot sequence is to start from d:/ drive now when it asks you where to install it it will give you available options as far as partitions. since you already have one you must delete all partitions. now you will see your full disc drive capacity. now hit enter on the full partition. the next prompt will be fromat disc quick or just format do the second one it is a full format. this will give a good clean install.but get back to me here and make sure this is what you want to do. if you want email me here it is easier charles_farrah@comcast.net
    if you can run windows update or better yet the microsoft update and dont choose the reccomended one choose the one that says custom and after it searches your computer on the left hand side you will see text stating hardware. click on that now on the right where it shows all your hardware you have updates for choose all of them as well as any recommended ones as well.
    just the new windows do put more stress on the hardware new harddrives run at 7200 rpms and new operating systems are writing more and more info on your hard drives not like windows 95 or 98. the driver for your monitor is most likely for the usb hub incorporated into it. You shouldnt need this driver xp will autorecognize it. as long as you plugged in the usb cord to the monitor (check out picture it is #5 where you must plug in usb cord to computer)
    as for your network card is this internal card or usb type
    did you ever have to reformat the hard drive before? this computer is almost 4 years old. If not that is pretty good. with all service packs and updates and installing and uninstalling of software takes a toll on a hard drive as well as an operating system. I would consider buying a new hard drive they are pretty cheap today around 50 dollars for an OEM version and if you have your original xp disk do a fresh install meaning you will have to do a backup of your files and documents.
  • 1,602 Answers
The problem is the new card you keep on trying to install, the system is trying to tell you that is not compatible to your computer system
rod
Posted on Feb 26, 2009
Why my desktop computer dell dimension 8400 power wont turn on?
it could be hard drive failure or processor failure or just old age . try getting into the bios . and reset to factory default .
Feb 26, 2015 | Dell Dimension 8400 PC Desktop
How to restore to factory settings without disk?
Dell has been including a "factory restore partition" on the hard drive for several years. Your Dimension 8400 should have the Dell PC Recovery software and files on the original drive.
Is the original hard disc installed? Have you ever upgraded the OS from the original XP? If you have not upgraded these two items or changed the partition structure on the drive, then shut down the computer and restart it. When you see the blue bar with www.dell.com, press <Ctrl> and <F11> simultaneously. (The Control (Ctrl) key is usually duplicated on most keyboards on both ends of the row with the space key. F11 is the second to the right among the function keys if they are in a line at the top of the keyboard. Three other keys (and possibly media control keys) will be to the right of the function keys on many keyboards.)
Sometimes it is hard to correctly time this. If you reach the windows boot-up, restart the computer and try again. (I usually have to do this 3-4 times.) Select Restore and then confirm the action on the next screen. Then wait for the program to reformat the C: partition and copy the files from the recovery/restore partition. When the computer restarts, it will display the End User License Agreement and other "start-up" screens for a new computer.
If the hard drive has been changed so that the PC Restore doesn't work, find someone with a copy of your version of Windows (DVD). Note your current license key. Then use a program to reformat the C: partition and reinstall Windows. (You'll lose the Dell extras that came with the computer.) Members of MUGs (Microsoft Users Groups) or Microsoft Technet may have these disks.
I hope this helps.
Jul 28, 2014 | Dell Dimension 8400 PC Desktop
Reinstalled Windows XP on a Dell Dimension 8400 and The local area connection is not detected. Cannot seem to find drivers through Dell support
Dell Dimension 8400 PC"s use either Broadcom Extreme Ethernet controllers OR, on SOME models of the 8400 that do NOT have ON-board Ethernet connections, SMC Networks Ethernet Drivers. I've seen MANY a Dell Dimension.
Sep 11, 2013 | Dell Dimension 8400 PC Desktop
Dell 8400 Boots to Black Error Screen in XP States to reinstall System 32
This might be caused by hard-drive failure. You should run hard drive test from BIOS to make sure hard drive is ok. You can access BIOS by pressing F2 during start up, from there start hard disk self test and wait for it to complete.
If hard drive is ok after test, insert in your original Windows installation media and reinstall OS.
Oct 02, 2012 | Dell Dimension 8400 PC Desktop
Hi - I have a Dell 8400, fails post. Diag indicators are A,B,C green and D amber. Sometimes the screen is black with a single blinking cursor and sometimes it shows the Dell splash screen. Cannot get to...
Unfortunately the dell website (not me) is not very helpful. Here's what is says about your diagnostic lights
Another failure has occurred.
  • Ensure that the cables are properly connected to the system board from the hard drive, CD drive, and DVD drive.
  • If there is an error message on your screen identifying a problem with a device (such as the floppy drive or hard drive), check the device to make sure it is functioning properly.
  • The operating system is attempting to boot from a device (such as the floppy drive or hard drive); check system setup (see "Boot Sequence") to make sure the boot sequence is correct for the devices installed on your computer.
  • If the problem persists, contact Dell.
Apr 20, 2010 | Dell Dimension 8400 PC Desktop
No video
you can try to hook up everything back up and then take out the video card and clean the place that it llides into and the card itsself and reinsert it and see what happnes but please make real sure that u connect everything back just like it was cause if there are cablkes that are switched there will be problems
Aug 19, 2008 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Motherboards Dead?
check to make sure the hard drive cables are connected properly and securely. Make sure all your cards are seated firmly and properly. Take the cmos batter out for about 30 seconds and then place it back and make sure it is firmly seated and in the proper position. If this still does not help please let me know for further help.
May 24, 2008 | Dell Dimension 8400 PC Desktop
Install 2nd Hard Drive in a Dell Dimension 8400 Computer
all u do is make your new hard drive the master by setting the correct jumper for it the manual will tell u more. then make the old drive a slave. install yr opreating system it should be installed in drive c: thats the master when done, u do yr normal copy and paste to transfer your files from old drive to new drive.
xerick
May 22, 2008 | Dell Dimension 8400 PC Desktop
Woes with Dell
If the power light is steady amber, a device might be malfunctioning or incorrectly installed.
Disconect fan , see if it starts.
Jan 13, 2008 | Dell Dimension 8400 PC Desktop
Computers & Internet Logo
138 people viewed this question
Alun Cox
