Question about Bosch 1587AVSK 5.0 - AMP Top Handle Jig Saw with Case
Blade wont stay in Bosch 1882VS jig saw
I can't seem to get the blade to stay in my jig saw. I found a screw that was loose, down through the handle, but when i tighten it the blade starts to tighten but then also starts to turn clockwise and ultimately the blade is not sitting straight on the guide wheels. What am ai doing wrong ? ...PS I;m using bosch jigsaw blades.
Tks
BK
  • Anonymous Mar 23, 2009
    I have the Bosch 18V cordless jigsaw and have had no problems until today. The blade will not stay in. I was looking to see if someone had posted a solution.
  • cplsoulmates Apr 30, 2009
    own a Bosch b4300 purschased in Pa sometime in 2005-06, have since relocated to Tucson, Az and the movers lost all the boxes of data on the tools that I have brought with me including the Bosch , its an excellent tool and I love the way it works , but since arriving here the blade does NOT wish to turn on a radius and disengages from the slot , also I need a booklet on it since the other was lost , any ideas??
  • 3 Answers
From your description I cannot say for certain, but it sounds as though you are not locking the blade correctly, or the blade lock mechanism is broken. You can tell if the blade-lock is working by clicking it. It should make an audible "click" that you can feel. Also, you can pull on the blade ( with the saw UN-plugged of course!) and feel if it is properly seated. If you are operating the blade-lock according to the instructions and it still doesn't lock positively, see a service center before you use the tool again. A broken blade-lock could be dangerous.
Posted on Apr 10, 2009
    Sergeant:
  • 359 Answers
ARE YOU USING BOSCH BLADES IF NOT GET SOME THEY ARE MADE A LITTLE DIFFERENT THAN SOME OF THE OTHER BRANDS AND FIT A LITTLE BETTER , IF YOU ARE THEN DO NOT KNOW
Posted on Feb 23, 2009
Jig saw b4300 blade replacement
This tool has no mechanism for the fixating ot the saw but only a short ***** part 53 its a fault in the manual , it simply replace the saw with a screwdriver. or simply the clamp ***** to release turn it loose and from the top you can replace the clamp *****
Bosch B4300 0601582535 Jig Saw Parts
Sep 05, 2013 | Bosch 1581AVSK Top Handle Jig Saw Kit
Bosch b4300 jigsaw blade replacement
To change the Bosch B4300 blade - If the grey knob does not turn to release the broken blade, you need to use a LONG THIN flathead screwdriver down the center hole at the top. Unscrew until the broken blade is loose. Pull out. Replace the new blade and then screw the it tight through the same hole at the top. DONE.
Jan 25, 2012 | Bosch 1581AVSK Top Handle Jig Saw Kit
How do you change a blade in the Bosch Jig Saw Model 1587 AVS
Pull the black knob on the top front of the handle up and turn it clockwise to tighten and counterclockwise to loosen. I'd turn it counter clockwise at forst just to make sure it's loose enough to accept the blade when you start.
Sep 01, 2011 | Skil 1587AVSK - Bosch Jig Saws Power Tools
Installing blade on a bosch jigsaw
The black part on top of the handle must be pulled directly up about 1/2 an inch. this engages the screw mechanism that loosens the blade. For some people doing this the first time feels like they are going to break the handle but it moves easier over time. Now turn the black handle counterclockwise several turns and the blade will hang loose in the holder. Turn the blade 90 degrees and remove it. Place a new blade in and turn back 90 degrees. Tighten the handle on top until it clicks. Align the black handle to the main handle and press back down into place.
Jul 15, 2010 | Bosch 1587AVSP Top - Handle Jig Saw Kit...
My bosch jigsaw keeps saing sideways!!!
Most Bosch jigsaws have a handle on the top of the main handle that you need to pull up and rotate counterclockwise to allow the screw to accept the blade. Insert the blade and rotate 90 degrees into position then tighten the handle and press back down into place. In the beginning it may seem like you are going to break the handle pulling it up but rest assured it will get easier as it gets used.
May 10, 2010 | Bosch T-Shank High Speed Steel Jigsaw...
How do i change the blade
Hello. where the blade enters the blade holder there is a screw. Unscrew it, turn counterclockwise, remove the screw and then remove the blade. Reinstall the new one and replace the screw. Joe
May 08, 2010 | Bosch 1581AVSK Top Handle Jig Saw Kit
Not sure how the blade seats in saw pneumatic bosch jig saw i can get it to go in but the blade seems to wander and seems to be unstable
do you have the screwdriver that came with the saw? if not you need a longer straight slot screw driver and it must be ground down to fit into the blade clamp tightener. it is a narrower than usual screw driver. I lost mine and had to custom make one. good luck.
Sep 14, 2009 | Bosch 7561 - 118 Pneumatic Cutting Tools
Replace the blade on jigsaw Bosch # 1587 AVS item # 0 061 587 683
YOu can download the user manual in the following links
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00061v-1.pdf
https://www.boschtoolsservice.com/Order/IPL/IPLDetails.aspx?tn=0601587651&mn=1587AVS&init=1
The blade can be replaced by unscrewing the screw found on the shaft.
Jul 28, 2009 | Bosch 1581AVSK Top Handle Jig Saw Kit
What is the process to change a saw blade on Bosch GST 2000 jig saw SDS system
There is a lever on the handle, you have to pull it up and rotate it counter clockwise about 3 times (shouldn't take any more than that. The blade will be loose now,put in the new blade and turn the back lever clockwise until it clicks. The blade should be tight,push the lever down and move it into the slot in the handle.
I hope this helps
Apr 06, 2009 | Bosch Saws
Blade won't stay in jigsaw
It sounds like you need to replace the shaft.
Feb 22, 2009 | Bosch Saws
Bosch 1587AVSK 5.0 - AMP Top Handle Jig Saw with Case Logo
1,207 people viewed this question
Top Bosch Saws Experts
Tim Venetis
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
