Question about Mitsubishi WD-52525 52" Rear Projection HDTV
I have a mitsubishi dlp 52" I have sound, and no picture. I cut it on and it will cut off in 2 min or so. Is it the lamp or something else?
  • quan_chau Mar 06, 2009
    I have the same problem, my dlp 52" has sound, no picture,only green lines from top to bottom. I can see channel number when I selected or switched to different channel, I press Device button on remote control,I can see device menu screen... I replaced the lamp just 3months ago.
    Does any one know this problem? appreciate your help. Thanks.
    Problem Solver:
  • 6 Answers
Replace lamp!
Posted on Feb 25, 2009
No picture have sound timer light blinks .when you turn TV on lamp light come on. Goes off. Tv have sound for 10 min TV cut off type 62" Mitsubishi dlp
How old is your TV set ? if you have not replaced the lamp in 2-3 years that is most likely the problem and need to replace that part.
This lamps now run from $40.00 - $90.00 depending on quality.
Jul 30, 2013 | Televison & Video
I have the 60 inch mitsubishi dlp. There was a sound just like a light bulb going out. Then there was no picture or sound. I replaced the lamp and still no picture or sound. I hear clicks when trying to...
If the status led is blinking yellow its indicating that the filter cover on the side is open. If its the lamp indicator thats blinking yellow its indicating the lamp door cover isnt attached properly.
Sep 24, 2011 | Mitsubishi WD-52825 52" Rear Projection...
No display or sound on Mitsubishi WD-52725
This is a DLP They have issues with the color wheel, the winding sound could be from this color wheel. If it stops spinning it will cause the tv to shut down. DLP is a mechanical display process. If you are handy and understand electronics you could replace this yourself. If not i would let a tech handle it.
Sep 01, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi dlp 52525 garbled rolling picture. Picture just colored lines, rolling slowly. Sound fine, fairly new lamp.
You most likely have defective capacitors in your electrical chassis. It's best to send the entire chassis back to the manufacturer for total rebuilding. The cost is about $350 + labor, unless you can remove the chassis yourself.
Good luck.
Aug 09, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Replaced lamp ,have sound but no pic,shuts down
Thats the code for whats known as lamp abnormality which is actually caused by failed capacitors on the power board. Heres a link to the repair kit that will usually fix that issue. The kit contains the replacement capacitors and also has step by step detailed instructions with photos so you can easialy do the repair yourself.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Jun 13, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Color gets hazy & basically is only pink & green
try to open the unit.then check for anything suspicious, like connectors if properly connected etc.then , power it on.look for something that causes the fan to stop running or anything related to that.check the lamp, too.
May 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi 65" DLP HDTV, Status light is red, no picture
Check your lamp; it may have blown. Sound, no picture and a red light are classis signs a lamp has failed.
Feb 02, 2009 | Mitsubishi WD-62528 62 in. LCD Television
No Picture At All on my DLP Mitsubishi
First do a self test to get error codes. To do this look on threads here or go to ctechnicians.com
Dec 31, 2007 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi dlp does not get picture
the plug the connects underneath is not connecting right you have to get at the plug and seat it correctly
Dec 08, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
82 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
