Question about Maytag PAV2300 Top Load Washer
Belts Maybe not sure.
If my dad only has a few things in the washer and it fills up it won't spin it is starts making a noise and you can smell rubber burning.
  • 52 Answers
The belt may have shifted off the pulleys. Sort of like a chain falling off of a bicycle. You will need to check and then change the belt. That is the easiest problem. Let me know if it's not that, then i could get into more complicated things.
Posted on Feb 22, 2009
LG WM4070H front load direct drive washing machine occasionally emitting burning rubber smell.
Sanitary cycle uses calrod heating element inside of washer to heat water. I suspect that is where smell is coming from. If you infrequently use sanitary, and if you use fabric softener and/or liquid detergent, then a built up on the calrod unit can happen. When used, the buildup can produce odors as you describe.
Apr 09, 2017 | LG Washing Machines
Washer fills but won't agitate or spin
Try making sure the belts are actually on the drum, probably have to turn upside down. Sounds silly but a lot of simple things are missed.
Apr 02, 2012 | Whirlpool Washing Machines
The washer fills and agitates, and spins, but when it is stopping the spin cycle it makes a really loud groaning noise and my tenant says there is a rubber smell.
The brake shoes are not grabbing like they should, the rubber smell is the motor coupling. This is putting a load on that coupling and will soon cause it to fail.
Nov 18, 2010 | Frigidaire GLWS1233A Top Load Washer
There was a rubber smell, now washer won't spin.
It is possible that the bearings supporting the drum have seized
Was the machine noisy before it stopped?
If there is tension on the belts and the drum is locked then the motor will spin and burn the belts.
Aug 18, 2009 | GE WBSE3120B Top Load Washer
Burnt Rubber smell and spin cycle didn't work
the main motor needs to be serviced , sounds like the couplings broke , hope this helps , AJ
May 18, 2009 | Maytag Dependable Care LAT9416
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Whirlpool noise
Ok can you take the front panel of the washer off easily?
If you can look for the motor pump assembly. Start the washer with no load, turn the water level down to the small and fill with water when it goes into agitation does it make the noise? if not turn timer to spin and see if motor makes the noise.
One other thought, maybe the smell is coming from the dryer?
Let me know. I wont be on line again until Friday Sorry
May 26, 2008 | Whirlpool LTE5243D Top Load Stacked...
Own a Maytag Washing Machine Model No. LAT9416AAE I overloaded with a extra large comforter. I started the cylce and went upstairs to my room leaving it unattended. My parents were down stairs With it, and...
there is a thermal overload protector in the motor. After the motor cools it should restart. There is an off balance switch that might have been tripped when pulling out the comforter or when bailing out the water. As for the belts, tip the machine back and you will see the belts underneath the washer. Very easy to change and you'll see what I mean when you see the belts. That should solve your problem. AND DON'T OVERLOAD THE WASHER AGAIN.
Feb 27, 2008 | Washing Machines
Kenmore 24642 Top Load Washer Problem
If this is a top load washer, more than likely you have a broken motor coupler.  Be sure the unit is unplugged before starting any repair.  You have to remove the console hold down screws (may have to remove the console cover caps to get to them, or they may be in the back).  Pull the console towards you then up and fold over the top of the washer.  You will see 2 gold colored clips, pop them out, then remove the lid switch wire harness plug.  Fold the cabinet top towards you, and remove the cabinet.  You will see the pump lower center.  Remove the two clips, and swing the pump out of the way.  Unplug the motor wiring harness.  Remove the two clip hold down screws, then unclip the motor hold down brackets.  The motor will now fall (be sure to hold securely) and pull motor out.  You will see the motor coupler on the end of the motor, a round rubber coupler, and another drive coupler in the hole on the transmission.  You will see the prongs on the plastic drive parts that go into that rubber part.  Most of the time, these will break off.  Remove everything, then reinstall (be sure to drive the couplers flush with the shafts), line up motor/rubber/transmission shafts, and reinstall everything.  Let me know if you need further help or information.  Part number for motor coupler is 285753A (Sears, APW, FSP, Whirlpool #'s).  You can also usually find these on ebay, but they arent that expensive (maybe $10 to $15).  Good Luck!!!!   Jim
Oct 24, 2007 | Kenmore 24642 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
66 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
