Question about Proform XP Weight Loss 620 Treadmill
Treadmill seems to slip while running,
Pro form xp 620, basically when I step the treadmill seems to stop. It seems loose.
  • 83 Answers
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
Posted on Apr 30, 2010
Belt slips when running on treadmill
see the video and proceed according. God bless you
Jan 31, 2013 | Proform XP Weight Loss 620 Treadmill
We have a pro form xp weight loss 620. The upper control board is not working. We need a new control system. It is the board in the handle area.
Well I do not know exactly where you are.
I will recomend some place where you can order you parts.
www. proform. com
www.fitnessreapirparts.com
www.treadmilldoctor.com
www.gymparts.com
sincerely.
Jun 27, 2011 | Proform XP Weight Loss 620 Treadmill
I have a Pro Form XP 620. How do I tighten the belt
http://www.youtube.com/watch?v=AZSMLpXm-tA&feature=related
PLEASE DO IT WITH CAREFYLLY AND PACIENCE.
Do not overtight the belt, can overcome another problem,like overheating.etc.
sincerely.
Jun 23, 2011 | Proform XP Weight Loss 620 Treadmill
I have a Pro-form 595PI treadmill..bought it used and has been working great until now.It seems that when I get on it , it seems to be slipping and not a fluid motion to walk or run on...Whats up???
check tension on the w/belt to loose will make it slip other wize check your drive motor belt thats under the hood. if you see a bunch of black dust your belt is worn replace
Mar 17, 2011 | Proform 595 PI Treadmill Walking Belt
I have a pro-form 680 LT less than a year old. The belt seems loose, it catches as I run and I about fall over.
The walk belt should be tight (about 1.5" to 2 " when lifted at the edge), if not tighten screws at the rear. If the belt is tight enough then pull the front cover off and check the front roller. Sometimes the plastic drive pully slips on the front roller. If it only stops while you are running and is fine when you walk, i would go to the front roller.
Nov 02, 2010 | Proform 680 LT Treadmill
When walking on my pro form xp weight loss 620, while walking along fine, every so often it starts to make a slipping sound and seems like the belt is slipping. tried tightening the belt and still does the...
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
Jul 07, 2010 | Proform XP Weight Loss 620 Treadmill
Pro-Form 360P, when I step on the belt, it stops moving.
when the belt is stopped you should be check the deck if this it´s worm or the walking belt, because a probable cause is lack of lubrication, In addition should send the engine to revision, because according to what your gross probably already there are some Diode Rectifier damaged, You must know that the cause that generates this problem stems from the walking belt and the table or deck
Jul 16, 2009 | Proform XP Weight Loss 620 Treadmill
Manual
Proform's website has owners manuls:
http://www.iconservice.com/proform/manuals.html
The list of available ones for your model are at:
http://www.iconservice.com/cgi-bin/ncommerce3/ExecMacro/proform/manuals.d2w/report?man=PROFORM&name=50071&lan=&x=0&y=0
Jan 10, 2009 | Proform XP Weight Loss 620 Treadmill
Proform XP Weight Loss 620 Treadmill Logo
996 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
