SIM setup How can I get into the simulation mode in order to setup the SIM for the ADF of the Toshiaba, Studio202s, model DP2021. Thanks
  • Anthony Chiang
    Anthony Chiang May 11, 2010
    Are u refering to estudio 202 model?
    http://www.businessneedz.com/Toshiba-E-S...
  • 134 Answers
What are you trying to set up? sims can be entered by holding 02, 04, 05, 08, 09 and turning machine on. but without specifics you probably don't want to mess with something you may delete important data
Posted on Aug 05, 2009
What is sim 14?
Simulation 14 is Trouble Cancel (except for U2)
http://einfo.thecircledelivers.com:8081/Techs%20Folder/Manuals/Sharp_Digital_Copier_AR-M207,AR-M165,AR-M162_Parts_&_Service.pdf
page 39 lists all of the simulations and how to canceling out of simulation mode.
Feb 21, 2014 | Sharp AR-M207 All-In-One Laser Printer
Error h4-00 code on AR- 5127. please what can i do to reset it. Thanks. It also says call for service even though the machine is new.
this error occures if:
The setup temperature (about 90°C) is not reached within the specified time (about 17sec) from turning on the power.
When the temperature of main heater lamp thermistor falls below 140°C in the standby mode or printing.
When the temperature of main heater lamp thermistor falls below 50°C in the pre-heat mode.
AS POSSIBLE CAUSE:
Main heater lamp thermistor defect
Main heater lamp failure
Main thermostat failure
Control PWB failure
Check the heater lamp blinking with SIM 52.
When the lamp blinks normally:
Check the thermistor and the harness.
Check the MCU PWB thermistor input
circuit.
If lamp lights and stays lit:
Check for disconnection of the heater lamp
and thermostat.
Check the interlock switch.
Check the power circuit and the lamp
control circuit on MCU PWB.
Clear the display of self-diagnostics with
SIM 14.
To clear, enter sim mode:
1) #/P key (program) ON ? Asterisk (*) key ON ? CLEAR key ON ?
Asterisk (*) key ON ? Ready for input of a main code of simulation
2) Entering a main code with the 14-key ? START key ON
3) Entering a sub code with the 0-key ? START key ON
4) Select an item with the scroll key and the item key.
5) The machine enters the mode corresponding to the selected item.
Press START key to start the simulation operation.
To cancel the current simulation mode or to change the main code
and the sub code, press the CUSTOM SETTINGS key.
* Canceling the simulation mode to return to the normal mode
1) Press CLEAR ALL key
if clear with sim 14-0 doesn't helps, choose sim 52 to check the lamp, or call service!
Sep 13, 2011 | Office Equipment & Supplies
Sharp AR275 copier error message received is "call for service u2-40" please what can i do to solve the problem?
in order press
* Entering the simulation mode
1) #/P key (program) ON → Asterisk (*) key ON → CLEAR key ON →
Asterisk (*) key ON → Ready for input of a main code of simulation
Simply # * C * and the machine will enter simulation mode.
Then enter the number 16, which is U2 code correction, follow what the screen says, Normally just press start and the machine will reset.
U2 codes are software glitches. A U2 40 is a CRUM fault which is a drum or toner chip problem.
Sim 16 almost always clears them.
May 19, 2011 | Sharp AR-275 Copier
I am getting a flashin L and can't make copies?
L1 = Scanner (reading) feed trouble Scanner (reading)
L3 = Scanner (reading) return trouble Scanner (reading)
Reset method :
1) Clear key ON - Exposure mode select key ON - Clear key ON - Exposure mode select key ON
(The machine is ready for entry of the main code of simulation.)
2) Main code input by 10-key ? Start key ON
3) Sub code input by 10-key ? Start key ON
The machine enters the selected simulation mode.
Press the start key to start the operation of the selected simulation.
Main Code =(14 Used to cancel the self diag other than U2 trouble.)
Sub code = 0
* Canceling the simulation and returning to the normal mode
1) Press the clear key.
Copy SIM 14
Sep 07, 2010 | Sharp AL 800 Copier
I just replaced all the moving parts in my Sharp AR-M620 copier including the finisher and drum etc...I have the service codes and sub codes to reset the print counters, drums, developers etc but don't...
1) Copy mode key ON ? Program key ON ? Asterisk (*) key ON ?
CLEAR key ON ? Asterisk (*) key ON ? Ready for input of a main
code of simulation
2) Entering a main code with the 10-key ? START key ON
3) Entering a sub code with the 10-key ? START key ON
Press START key or EXECUTE key to start the simulation opera-
tion.
and the sub code, press the user setup key.
1) Press CA key.
Sep 06, 2010 | Sharp AR-M620N Copier
Sharp MX-4501N Error L4-11
L4-11 is a Shift motor trouble in the finisher. First you must repair the problem then Use SIM6-1 to check the operation of the shift motor. Then use SIM30-1 to check the shifter home position
sensor. Check the harness and the connector
between the PCU PWB and the shift motor.
You can clear the code by using SIM 14.
1) Copy mode key ON → Program key ON → Asterisk (*) key ON → CLEAR key ON → Asterisk (*) key ON → Ready for
2) Entering a main code with the 10-key → START key ON
3) Entering a sub code with the 10-key → START key ON
item.
operation.
code and the sub code, press the user setup key.
1) Press CA key.
Sep 01, 2009 | Sharp AR-507 Copier
How I CAN CANCEL CODE U2 in sharp arm451n
This resets the code
Sim 16 sub 0 Used to cancel the self diag "U2" trouble. Cancel Trouble Error
SIMULATIONS
1. Entering the simulation mode
Enter the copy mode and perform the following procedures.
[P] [*] [C] [*] [Main code] [START] [Sub code] [START]
2. Switching the simulation mode
Press [USER SETTING] to return to the code entry screen.
3. Canceling the simulation mode
Press CA key to cancel the simulation mode.
You may need to have a tech look at this.
Hope that helps
Jun 23, 2008 | Sharp Office Equipment & Supplies
61 people viewed this question
k24674
