Question about Moultrie MFH-DGS-100 Digital Camera
Moultrie D 4.0 continous exposures
At first, the moultrie worked well in the woods. Then, after turning off and changing batteries (new set of energizers) and a new 1 meg SD Card, the camera began to shoot continuous pictures every 1 minute; every 5 minutes if I use that setting. It just flashes ongoing until the SD Card is full. All other functions seem to work fine except it continously exposes frames with no motion setting it off. Can you help me solve this problem?
Tenth
  • Moultrie Expert
  • 296 Answers
..your not in "Interval Mode", are you?? IF your cam is set to start an "interval @ say 2400hrs( midnight) and to take pics every 1 min./5 min/;ect., IT WILL!
Make sure you're in "AUTO MODE"...It's easy to accidently hit the mode switch when moving the power switch from off to on..(I didn't find this out by reading a book...)
Posted on Feb 19, 2010
Camera shuts down after 1-2mins an does not take pics
Just to let you I had Moultire m-80 when I used a pny sd card it ruined my camera. They were kind enough to replace it for me. I just use what they recommended do not have any more problems. I only delete pic on my computer and not digital camera. Try doing a hard reset take everything out turn to the on position for about 2-3 minutes after 3 min put brand new battery's in it while on the on position should say no card at this time. If doesn't turn camera off put sandisk sdhc card in it. Test camera again if still not working Moultire will help you I have talked them great customer service.
Nov 26, 2013 | Moultrie Game Spy M-880
I have a moultrie d55ir i have put in two sets of new batteries keeps saying low battery what do i do it worked just fine now it wont.
Clean the battery terminals in the camera and the batteries with a pencil eraser and a q-tip moistened with rubbing alcohol.
Oct 05, 2011 | Moultrie D55IR Digital Camera
Moultrie cdc - 5.0 Trail camera appears dead. New batteries, but will not turn on?
According to Moultrie you can try a hard reset.
Take out batteries, and SD card, hold on button for 2 min.
Replace batteries and try, haven't tried it yet, but will
Aug 07, 2011 | Moultrie Cameras
Camera won't come on
1. Replace batteries with new alkaline batteries.
2. Sometimes an SD card may malfunction. Remove the SD card and turn the camera on. Check your manual for proper use of SD card.
3. Still having issues? If you bought the trail cam within the last 12 months, send it to Moultrie for repair.
Here is the link with a return form an procedures for the return.
For more information about trail cameras, visit my Hunting Supplies Website
Jul 28, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie I40 getting error code 480 and wont go into auto mode
ERROR CODE 000480 ?
If this is correct,it relates to: Camera Mod test failed;(4); and under Memory Test, 8= Comms Error.New batteries(good ones) may fix it...
It' not communicating with memory card..ck it's inserted good..press down until it stays down(press again and it will pop up.
Follow instructions on deleting internal memory before installing SDcard.
Also, make sure cam supports kind of card you're using..at 4gb and larger, they become confusing;i.e., 4/8/16mb...older cams won't support some of these. Also there are HC(high capacity); HD(high definition)don't work in these cams..
I posted this for a fix a few days ago, and it turned out to be brand new bad batteries.
Dec 23, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie DGS160 Game Camera Error 20000
Forget calling Moultrie...I think their answering system is permantly set for "off-hour" times...you may have to e-mail them several times be fore (after4-5 days they get back to you.
You're error should read error"0200000"...flash error or flash charging...getting this during system diagnosis probably is that you failed to cover sensor during ck.
I f this is a constant error...turn cam on; remove batteries; turn system off; insert batteries and try again. .
Oct 03, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie camera locked up.
THROW IT IN THE TRASH! NO MORE PROBLEM.
Nov 26, 2008 | Moultrie MFH-DGS-100V2 Digital Camera
Moultrie I60 battery life.
extreme hot/cold effects battery life...also # events, whether pics taken or not 2 million gray Ark. squirrels, that never stop moving like red squirrels will use up batteries in a hurry...even still I get 3-4 mos out of 6-dcells on my I-40s
Nov 14, 2008 | Moultrie MFH-DGS-200 Digital Camera
Locked up
On my Moultrie MFG-DGW 2.1, I was unable to change settings etc... It seemed to be locked at the Date/Time screen. I powered off the unit, removed the memory card. Turned on the unit. Then I could change the settings. I made my changes, powered the unit off, reinserted the memory card, turned the unit back on and it read the card and I could make changes too. This happens from time to time. I just have to follow those steps to clear it.
Hope that helps.
Oct 28, 2008 | Moultrie MFH-DGS-100V2 Digital Camera
Continous shooting with D100 - it doesn't work...
Mine too. It's a worn-out selector switch. Jiggle it and it'll work again. Time delay same. Our college has four Nikon D100s with this problem. Poor switch contacts.
Dec 03, 2006 | Nikon D100 Digital Camera
Moultrie MFH-DGS-100 Digital Camera Logo
141 people viewed this question
Top Moultrie Cameras Experts
AZBen
AZBen
Steve
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
