Question about GE Spacemaker JVM1640SJ Microwave Oven
EVERYTHING WORKS NO NOSIES SOUNDS LIKE IT IS WORKING WILL NOT HEA
MY MICROWAVE TURNS ON EVERYTHING IS WORKING FINE NO ODD NOISE BUT WILL NOT HEAT UP
  • 52 Answers
Could be the power fuse inside the microwave, you have to remove the casing to access these.large power fuse would seem to be the problem, this is normally 10 amps but could be 13 amp. there is also a control fuse that control the power relays
if this is blown the relays could be at fault
Posted on Feb 23, 2009
Whirlpool MH3184XP Microwave Turns On, Heats, but sounds like fans not working. 4 years old, fans worked fine until they seem not as loud anymore. The magnetron is working fine as it heats (did the 1 cup...
Suggest you pull the plug out, remove outer cover and place a cup of water into the micro. Set power to minimum then switch on and take note if the fan works or not. If not, switch off immediately and have it replaced(magnatron will burn out if left to run without fan.)
Sep 18, 2010 | Whirlpool MH3184XP Microwave Oven
Our microwave oven started making a loud sound and quit heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101==]-]=-
Feb 14, 2010 | Emerson MW8107WA Microwave Oven
Everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Jan 03, 2009 | Whirlpool GH4155XP Microwave Oven
Ge microwave won't heat everything else works fine
Hello t_sumner4756,
Everything else can work perfectly fine but if it doesn't generate microwaves to heat your food than it is not working ( you knew that anyway).. Unfortunately, and in most cases when you microwave stops working in that manner..the components at fault are either the Magnetron, Filament PS or a High Voltage Capacitor..What that means is that you are probably better off just replacing the entire appliance rather than attempting to repair it. If it is a year old or less, bring it back to where you purchased it and have them replace it.. I am sure that is not what you wanted to hear but when the cost to repair exceeds the cost to replace... it just isn't worth repairing.. Plus.. there is an element of danger associated with these kinds of repairs...
Regards,
Rick
Nov 22, 2008 | Sharp R-303CW Convection / Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Microwave Oven Basic Troubleshooting Tips
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
My microwave is not heating up suddenly...its working fine till morning...suddenly it stopped heaing things....[lease suggest me with a solution
Do the inside light and turntable come on when you try to cook?
Is it making any unusual noise or is it louder or quieter than normal?
Do you have the model number?
Aug 09, 2008 | Microwave Ovens
Ge microwave - making noise
I have a GE counter top microwave oven. When the oven starts cooking (the magnetron turns on) the oven makes a harsh buzzing noise. What is wrong and what should be done?
Mar 07, 2008 | Microwave Ovens
Microwave making noise, not heating
Was the noise something like someone growling into a coffee cup?
As odd as that sounds, that's a common sound for a bad magnetron to make, a hollow gurgling or sizzling.
It may be the magnetron, but generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 04, 2007 | Kenmore 62702 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
132 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
