Question about Dell 3100cn Laser Printer
Hi, My Dell 3100CN printer is displaying "Change Black Toner." I have replaced the toner cartridge. The printer begins to calibrate for a very long time. When it finally finished calibrating, it return to the error "Change Black Toner." Can you help me with this?
  • javicho51 Mar 15, 2009
    Hi I did try your suggestion to change for non dell toner config but it didn't work I still have same message
    replace black toner , do you have another solution?
    Thank you
    javicho
    Tony Ludlow
  • Anonymous Mar 13, 2014
    I changed the black toner cartridge now it says ID error. I've taken it in and out. Wont change
There is a chip in each toner cartridge which tells the main machine something about how full it is. It may be that it tells it how full it is, or it may be that it tells it how many pages it has done. It sounds as if the new black cartridge has a duff chip, and is telling the main machine that it is empty. To test this, you can overide the message. 1. press on the menu button;
2. select configure;
3. select maintenance;
4. select non-dell toner;
5. set the value to on.
If that does't work, get back to me.
Tony Ludlow
Posted on Mar 01, 2009
Dell 3100n keeps saying "Change Black Toner" even
Before installing a new toner, put a disposable towel over the ink toner exit, and shake your toner lightly back and forth and up and down. Make sure your toner cartridge is in the open position before replacing it in your printer.
If you are using a refillable ink cartridge, make sure you are resetting the cartridge using the method described by the refillable manufacturer.
If this does not answer your question please request more information before voting on my answer. I will try to find more information about your toner cartridge that will help you futher.
Nov 16, 2010 | Dell 3100cn Laser Printer
Dell 3100cn laser printer poor print quality
It sounds like you've got contamination on the drum cartridge or on one of the toner cartridges.
I'm actually going to be installing black toner in my 3100cn in about 8 hours, so I'll inspect and clean each of the carts, and write up the process for you tonight.
Jan 27, 2010 | Dell Office Equipment & Supplies
WILL NOT CALIBRATE,KEEPS ATTEMPTING TO CALIBRATE.
This is commonly caused by faulty toner cartidges or OPC drums.
If there is a fualty color cartridge the device will try to recalibrate over and over....
Isolate the faulty toner cartridge and replace it.
I have seen this as a common problem with some poor quality refilled cartridges
Dec 22, 2009 | Dell 3100cn Laser Printer
I AM CHANGING THE BLACK TONER CARTRIDGE ON A DELL 3100CN WITH THE ORIGINAL DELL TONER CARTRIDGE AND I GET AN "ID ERROR" MESSAGE
Either the "toner cartridge sensor" N4445 isn't reading the chip in the toner,
or an MCU board P5281 or EEPROM is defective
-Whit :)
Jul 30, 2009 | Dell 3100cn Laser Printer
LDell 3100cn awer printer won't recognize new toner
Have you removed the plastic protection strip from the bottom of the toner?
Nov 14, 2008 | Dell 3100cn Laser Printer
How do you change the magenta, yellow and black toners on the dell 3100cn
The toner carousel must rotate, so that you get the slot for the other toners in front of you.
Follow detailed instructions on the user manual, click here to get the manual :
Owner’s Manual
Nov 07, 2008 | Dell 3100cn Laser Printer
Dell3100cn Replace black toner
I had the same problem. My solution was to replace the black developer unit. It works fine now!
Oct 26, 2008 | Dell 3100cn Laser Printer
Dell 3100cn printer trouble
this sounds like you might have 2 problems on you fuser is not getting hot enough to fully fuse the toner to the paper and two your black toner cartridge has been comprimised and needs to be replaced
Oct 16, 2008 | Dell 3100cn Laser Printer
Dell 3100CN w/new black toner cart reads "Black toner LOW"
service your printer and change roller taplon tape and fuser aseembley.
Oct 09, 2008 | Dell 3100cn Laser Printer
Dell 3100cn Laser Printer Logo
378 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
