Question about Maytag Legacy Series Top Load Washer
Maytag Legacy Series Top Load Washer model SAV515DAWW When filling, the cold water just trickles in and takes a long, long time to fill. When I unscrew the hose from the washer and turn the water on it gushes out strong, so the problem is in the washer. The hot water fills ok.
  • gag2B Mar 30, 2009
    Not only does the water trickle out but the machine goes into excessive vibration on the spin cycle, like it move along the floor and shakes half the house.
  • sliceofbread May 03, 2009
    Hot water fills ok, warm fills faster, cold is worthless
  • 37 Answers
Have you tried cleaning out in and around the inlet on the washer (where the cold hooks into the washer)? We had the same problem. When I removed the cold water hose, I cleaned out the end of it and the inlet on the washer-there should be a small screen on the washer side. It does it on cold because with the hot, a hot water heater filters most of the debris out of the water before it comes out and the cold water is not filtered. Hope this helps!
Posted on Apr 03, 2009
  • tonyhera Apr 03, 2009
    As far as the vibration, my model has "self leveling" rear legs-WHICH DO NOT LEVEL :)
    What I do is everytime it starts that, once the washer is empty, is to pull the back of the washer about 8-10 inches off the floor-by standing in front of the washer and leaning the front of it toward me. I then let it carefully drop back to the floor. With this washer, you have to make sure that your load is perfectly balanced and even and not at all overloaded before allowing any water in. Hope this helps also!!
  • 52 Answers
From what you have said, you may have a bad solenoid in your water fill valve. it's the rubber piece under the debris screen. if you can get that out and replace it, you'll be golden.
Posted on Feb 22, 2009
Maytag Legacy Series Top Load Washer model SAV515DAWW splashing
the agitator dogs are likely broken.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Maytag Legacy Series Top Load Washer
Kenmore Washer 90 series cold water trickle
Hi, You need to remove the fill hose and see what is plugging the inlet valve screen. This should make a guge difference.
Please let me knwo ig I can assist you further.
Thanks
Vic
May 23, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag legacy series tub wont fill
Your drain hose is too low or there is no air gap where the hose enters the drain line.
This causes the water to siphon out as it fills.
Mar 08, 2009 | Maytag Legacy Series Top Load Washer
Maytag Washer Legacy series When cycle starts the cold water just trickles in and takes a long, long time to fill. The faucet valve is fully open. When I unscrew the hose from the machine and turn the...
Remove the cold hose from the machine.
Look inside the inlet you removed the hose from, there will be a screen.
Take it out, clean it, and replace it.
Problem solved.
Feb 22, 2009 | Maytag Washing Machines
Maytag legacy series washer not holding water
Same problem here. But according to Maytag Service, the draining pipe may be too deep inside the draining tube on the wall, thus creating a siphon effect and not allowing the tub to fill.
Their suggestion is to ckeck the pipe and make sure no more than 6-8 inches are inside the draining pipe. This should take care of the suction. We'll see, Imma do that when I get home.
Jan 06, 2009 | Maytag Legacy Series Top Load Washer
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Dec 30, 2008 | Kenmore 22422 Top Load Washer
Washer does not work after water fills up (Legacy series)
The motor has had it and it is effecting the whole washer or it may be the computer but most likley the motor.
Turn it off and unplug it. take it to the nearest repair man
If you have any questions please dont hesitate to ask
Dec 04, 2008 | Maytag Legacy Series Top Load Washer
Washing Machines Logo
296 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
