Question about Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet washer knocking sounds
The washer is making regular knocking sounds from rear when NOT spinning.
Does any one out there have an answer to this?
  • wernebur Feb 22, 2009
    Thanks for your response. When I get some time I will start to track the issue and report back.
  • wernebur Feb 27, 2009
    Problem solved ! Thank you very much for your help.
    While taking off the rear panel I noticed that one of the sheet metal screws attaching the rear panel to one of the cross braces had not been driven home completely during assembly.This caused the rear panel to vibrate against the cross brace.
    Found nothing wrong internally and put back rear panel.
    Machine runs generally much quieter now.
    Thanks again
  • 52 Answers
From what it sounds, it could be one of the suspension bars. when it's spinning, it is all in the same direction where as agitation is both directions... that would make noise from starting and stopping directions etc. it could be a few other things... please let me kno if you need more help.
Posted on Feb 22, 2009
  • Janelle Tablada Feb 23, 2009
    Sounds good. Glad I could be of some help. I am here if you have anymore questions, I won Bronze and Silver Medals for Appliance Repair Competitions :-)
My washer started by spining faster then normal and then it started makeing a loud knocking noise and now sounds like metal rubbing metal. Everything else works fine just can't spin anything.
SOUND LIKE INNER TUB AND BEARING AND SUPPORT SHAFT...# W10250573 $364.00 INNER TUB AND SHAFT..REAR TUB AND SEAL#8181912 $224.00 VERY TIMELY AND EXPENSIVE REPAIR CHECK WARRANTY ON WASHER
Jan 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Loud knocking and vibration during spin
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet Washer rattles and knocks when spinning
you either have a broken shock or the spider gear is gone,take off the bottom panel and check out the shocks,if it's the spider gear it's time for new washer,it's around 500 bucks for new gear,to much detergent used over the years eats at the metal
Jan 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Knocking sound, violent spin cycle led to not
my problem to just 3 days ago from yours! bearings are out, $600 getting a new one.
Jan 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer not spinning
It's not really a solution but I checked my paper work from when I purchased the washer and found out that I got the extended warranty, so I have called in a service call.
Jun 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool duet is making a clacking noise on the spin cycle.
Reach inside and see if there is any play to the inner/spin tub (up and down) . Tub may be seperating from mounting and spindle assembly.
Apr 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet Sport Washer still making noise now it s leaking
make sure to look really close all it takes is alittle whole in that seal anywhere to cause a leak try to look close while it is running but first dry everything you can and then run it. also make sure your door glass is clean if it is leaking down the front just alittle dirt or hair can cause a leak aswell
Mar 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet Sport Front Loading Washer is making a funny noise
open top cover (two or three screws on rear and slide back) and look at rear of tub checking clearance to rear panel and nothing touching belt or pulley. whirlpools tend to have a high pitch low volume whine anytime motor operates.
you really dont want to replace that bearing. part of tub assm. $400 part plus labor
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have WP Duet HT front laod washer. Model #-GHW9250ML1 Type 199 080 SC/WG Problems - 1. while the tub is spinning it makes a knocking sound. When the tub slows it knocks louder. What is the problem and...
COULD BE LOOSE BASKET OR REAR BEARING LEAKING OR SIMPLY SUSPENSION SHOCKS BROKEN ,, EVEN SHOWS 1 MINUTE JUST ESTIMATE TIME NOT READY TO SHUT DOWN NORMAL ON DUET MACHINES
Nov 29, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
170 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
