Question about Hotpoint RGB745 Gas Kitchen Range
CAN I CLEAN A SELFCLEANING OVEN WITH BAKING SODA AND VINEGAR. I HAVE PET BIRDS AND THE FUMES FROM A SELF CLEANING OVEN ARE WAY TO TOXIC TO TAKE THE RISK.
  • joebyrd Feb 23, 2009
    IT IS HELPFUL....WHAT I CAN GATHER FROM YOU, ONE SHOULD NEVER USE THE SELF CLEANING FEATURE, ALWAYS CLEAN WITH SOMETHING ELSE. I PLAN TO USE BAKING SODA AND EITHER WATER OR VINEGAR. IF YOU DO USE THE SELF CLEANING FEATURE, IT WILL EVENTUALLY BURN ITSELF, AND OTHER PARTS, UP. RIGHT?
    THANK YOU.
  • Hotpoint Master
  • 3,361 Answers
It is best to clean a self cleaning oven with anything except the self cleaning feature.
The self cleaning feature will eventually destroy other parts causing repair.
Posted on Feb 22, 2009
  • steve
    steve Feb 23, 2009
    Yes, that is correct.
Do I have a continuous clean oven and how do I clean it?
How To Clean an Oven With Baking Soda & Vinegar - The ...
www.thekitchn.com/how-to-clean-an-o...
Apartment Therapy's The KitchnMar 18, 2014 - Clean your oven racks: Meanwhile, clean your oven racks. See the fullcleaning tutorial here. Wipe out the oven: After 12 hours or overnight, take a damp dish cloth and wipe out as much of the dried baking soda paste as you can. Use a plastic or silicone spatula to help scrape off the paste as needed.‎How To Clean Oven Racks In ... - ‎A Genius Cleaning Tip - ‎Why You Should (Almost)
Sep 30, 2015 | Kitchen Ranges
No manual. Hit the clean button and 15 minutes it caught on fire. Hit the cancel
It probably caught fire because to much crud was built up inside probably from not cleaning often enough. I assume there were not flames but just a lot of smoke, try again but watch it carefully. Some ovens are damaged by oven cleaner so I would get a manual first to be sure using that would be OM.
Here are some links that may help:
How to Clean Oven Naturally with Baking Soda Tutorial
How To Clean an Oven With Baking Soda Vinegar Cleaning Lessons from The...
Mar 02, 2015 | Ovens
Kenmore gas stove
I wouldn't. The plastic will give off some very acrid, toxic fumes if you try to self-clean it. First use a damp sponge to wipe up the baking soda. After that, you might be able to turn on the oven just a little bit to soften the plastic residue, then carefully, use a putty knife to scrape up the plastic residue from the oven floor.
Aug 05, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Self cleaning
white vinegar and baking soda are good as a rule for any household cleaning and when we clean our hob/oven, it works well at dislodging any grime
Aug 14, 2013 | Maytag MGR6772BDS Gemini Gas Kitchen Range
How do I use the self cleaning functions - kitchenaid oven
Please allow me to help you first with some background of self cleaning functions:
Self-cleaning ovens use an approximately 900 degrees Fahrenheit (482 degrees Celsius) temperature cycle to burn off spills leftover from baking, without the use of any chemicals. A self-cleaning oven is designed with a mechanical interlock (patented in 1982) to keep the oven door locked and closed during and soon after the high-temperature cleaning cycle, which can be approximately three hours. The door stays locked to prevent burn injuries. You can open the oven door after the oven cools to approximately 600 F (315 C).
If baking spills are not wiped up after baking, there may be some smoke during an oven cleaning cycle. It is a good idea to remove any pets from the area when running the oven's self-cleaning cycle. There have been reports of oven-heated Teflon-coated items releasing odorless fumes deadly to birds.
Self-cleaning ovens have the added benefit of more insulation, which helps the energy efficiency for regular baking. This is similar in concept to an increased R-factor for home insulation.
You will also save energy costs by using the self-cleaning cycle right after baking, to make use of the already partially heated oven.
Please check this website mentioned bellow which would give you a detailed method of how to perform it:
http://cleaning.lovetoknow.com/Self_Cleaning_Oven_Instructions
Hope this would help you .
God Bless.
Jul 05, 2009 | KitchenAid Kitchen Ranges
Need directions to clean my tappan oven
1. Add baking soda to a cool oven. Sprinkle a thick layer of baking soda onto the bottom of the oven. Make sure the oven is completely cool before you attempt to do this. 2. Spray the baking soda with water. Using a spray bottle, spray the baking soda down until it is damp, not saturated. The water and baking soda together will help break down the food particles. 3. Continue spraying baking soda as it dries out. Every few hours spray the baking soda down again to keep it moist. Continue this process over several hours, spraying water as the baking soda begins to dry out. 4. Scrape out the baking soda. Scrape the baking soda out of the oven. Food residue will be scraped out with the baking soda. 5. Rinse the bottom of the oven out thoroughly. Yes, you'll still have to rinse out the oven, but next time you cook your food won't have an added taste of oven cleaner.
If I had the rest of your model number I may find what Tappan now Fridgedaire Electrolux reccomends, but this is the least toxic. Have a great day..
Feb 08, 2009 | Tappan TEF242 Electric Kitchen Range
Frigidarelectstoveglfs76aqhsetovenclenar
Self-cleaning ovens are the easiest type of oven to clean. Simply remove the oven racks, it should be fairly simple.Take everything out of the oven, including the grill. At the top of your oven door, there should be a latch. Lock that, then look on your setting dial. There should be a self-clean notch on it. Turn your dial to that and let it do its thing: The timer will shut it off and unlock the door when it's done.
set your oven to the cleaning mode, then wait a few hours. After the cleaning cycle is complete, you will need to wipe up the residue inside the oven with a damp cloth or sponge. While your self-cleaning oven is doing its job, take time to scrub down your oven racks with a steel wool detergent pad. The exterior of your oven can be cleaned with a sponge. Use basic window cleaner to clean and shine any glass or chrome areas.
If your oven is not a continuous or self-cleaning model, you are in for a little more work. Make sure you have rubber gloves (the longer, the better) to protect your skin from harsh cleanser. You will need to purchase a cleaner specially made for cleaning ovens. Be sure to ventilate the room well as these types of cleaners give off potentially harmful fumes.
How long you leave the cleaner on the interior of your oven will depend on the directions on the can. Most oven cleaners will need to be left on for several hours or overnight, others explicitly state that it should not be left on for longer than 2 hours. When removing the cleaner, be prepared for a lot of scrubbing and rinsing. You will want to ensure that all the oven cleaner is removed from the oven before use.
Perhaps you don't want to use harsh cleansers on your oven. In this case, you will find that a simple mixture of white vinegar and baking soda can do the job. Lightly moisten the interior of your oven with water. Then, apply a thick layer of baking soda. Allow the baking soda to sit for about three hours.
After three hours, spray the entire oven with white vinegar in a spray bottle. You will notice that when the vinegar hits the baking soda, fizzing occurs. This fizzing action helps remove stuck-on mess almost as easily as any commercial cleaner. Allow the vinegar and baking soda to sit for a few more hours. Then, simply remove with a damp sponge and some water.hope this helps pls apreciate with a fixyaa rating thanks and Godbless
Jan 13, 2009 | Frigidaire FEF352 Electric Kitchen Range
Roper Self cleaning Oven
how dirty is the oven? if it is not bad then 2 hours if it is then 3 hours.
make sure you don't have any pet birds in the house cause it could be toxic to them.
Oct 31, 2008 | Roper FEP320 Electric Kitchen Range
Hotpoint self cleaning oven
1.get pet birds out of house.
2.take racks out of oven
3.slide door latch over if you have one(door should be locked)
4.push clean on control
5.set hours by pushing the arrows.i would set it for 2 hours
6.when finished let it cool down when it is cool enough the door will unlock or you can push the door latch back.at this point you will have a gray ash on everything,just wipe with paper towel.
7.be pround and smile at your clean oven.
8.oh don't forget to bring your birds in if you brought them out,the reason you have to bring them out is because the fumes are toxic to birds,but not to humans.
hope this helped
Sep 22, 2008 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
650 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
John Tripp
John Tripp
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
