Question about Microsoft Windows Vista Ultimate Edition
WHEN I TURN MY COMPUTER ON I GET AN ERROR MESSAGE - HOW CAN I STO
STOP THIS MESSAGE FROM APPEARING EVERY TIME I TURN THE COMPUTER ON?
C:\PROGRA~1\MYWEBS~BAR\1.BIN\M3PLUGIN.DLL
  • Anonymous Feb 23, 2009
    "WHEN I TURN MY COMPUTER ON I GET AN ERROR MESSAGE - HOW CAN I STOP THIS"
  • 34 Answers
Please click on Start, Click on Run and type the following in the open box and click OK
msconfig
Vista: In the Start Search field, type msconfig , and press Enter . The System Configuration window opens.
Or
Press and hold Windows logo key on keyboard and press R. It will open Run Window. Type the following in the open box and click OK
MSconfig
Please click on Startup tab
Remove the check mark from entries related to Mywebsearch OR M3PLUGIN.DLL
Then click on Apply, Close and Please click on Exit without restart.
When the system restarts, you will see a message about System Configuration Utility. Click in the box for “Do not Show this message” and then click on OK.
It may work!
REGARDS
RAHUL
Posted on Feb 22, 2009
A SCRIPT ERROR WHICH KEEPS APPEARING ON FACEBOOK
Phone Number:
1-650-543-4800
Average Wait: 12 mins
24 hours, 7 days
I would try a DIFFERENT kind of browser to rule out Facebook itself you and download and have browers installed at http://www.ninite.com
Good Luck.
Nov 18, 2015 | Facebook Computers & Internet
I have a Singer 7285Q sewing machine that comes up with a "E-7" message and the machine won't work. It only happens when I use "back stitch" button. My instruction manual has no mention of an
E7 means
The start/stop button, reverse/reinforcement stitch button
or the thread cutter button was pressed while no thread
cassette was installed. If the start/stop button is pressed before the sewing machine is correctly set up or if an operation is performed
incorrectly, an error message appears in the stitch indicator. Follow the instructions that appear.
If you press (Stitch selection key) or do the operation correctly while the error message is displayed, the
message disappears
Oct 30, 2014 | Singer Sewing Machines
E7 error message Singer Patchwork
I used can air and blew out the reverse button area. Worked immediately after turning off and back on.
Mar 23, 2014 | Singer 7258 Sewing Machine
Error code 0x00000002
STOP 0x2 DEVICE_QUEUE_NOT_BUSY error code has a value that is 0x00000002. This is a fatal error typically known as STOP message or Blue Screen of Death (BSOD).
This error generally occurs in Windows XP but may also occur in latest version of Windows such as Windows Vista or windows 7. The computer may stop responding without warning. Moreover, your computer may give error messages like STOP 0x00000002 error or related errors and if blue screen appeared then you may have to restart the system in the mean time of your work due to which unsaved work will be lost.
Cause of Error:
  • You may be using corrupted profile in your system which raised this problem
  • The device driver of your system is not updated
  • Malfunction of hardware usually is the cause of error such as STOP 0x2 DEVICE_QUEUE_NOT_BUSY or similar error
  • Registry database of your system may have corrupted or modified erroneously by invalid application
  • You have installed new hardware unsystematic or installed unknown application
  • Spyware has infected the PC
  • Antivirus software is not working
  • The operating system or application might have run out of usable memory.
This is one of the serious problem in computer if it is not resolved instantly then it might create some more unexpected error. STOP 0x00000002 error and its related error will disturb you all the time and you may have to bear loss of data. When blue screen of death appear on your monitor screen then you need to restart directly whether you have saved your work or not. Therefore, you are suggested to fix STOP 0x00000002 error as earliest possible.
How to Fix:
To fix STOP 0x00000002 error you need to follow the following methods.
  • If this error occurs in your pc then you will have to restart the PC and then press F8 key before appearing Windows. You will see a black screen with white text giving many options. Select the option "Last Known Good Configuration" and press Enter. If you have configured the computer improperly then it may fix the error.
  • If you have installed any hardware in your system then the chances is more that the device driver is not updated and thus errors of type STOP are given at the time of operation. You must download latest drivers.
  • If your system does not become stable then you need to try scanning of registry with this tool. Since, registry keeps all configurations of your system if it gets impaired then you must download registry repairing softwareand repair it .
Mostly, spyware has been the reason of various errors in computer system. Spyware damages files in the computer system and if once damaged then it is no longer used and it also corrupt registry database. The file which is infected by virus may be a program file, system file etc. If STOP 0x00000002 error occur in spite of antivirus then download anti spyware to scan your computer.
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
Sep 28, 2011 | Microsoft Computers & Internet
Error message stops install of windows xp
Open the case of the computer and look for a battery on the mother board ( looks like a large watch battery ) remove this for about 20 minutes. Put it back and re-boot the pc. You will have to reset the date and time.
Apr 26, 2009 | Computers & Internet
49.3046 Error To Continue Turn then On
Disconnect cables (except power) and try turn it on. If message dissapears be sure that you delete all pending files to print in your computer (specially large pdf).
Apr 03, 2009 | HP DeskJet 5550 InkJet Printer
DeBug appears whenever
what IE are you using?
the debug will appear when you using IE6. the reason is that most of th web site have activex. IE6 can't handle it. you need to install IE7 sp1.
Mar 27, 2009 | Microsoft Windows 2000 for PC
Blue screen with error message on startup
Most likely problem is a physical problem with the hard drive, but could be plenty of other things. Best bet is to back up your information (if possible) and do a fresh windows install, if you continue to get the message after a clean windows install, your hard drive is not stable, and has a problem.
Dec 30, 2008 | Dell Inspiron 6000 Notebook
Microsoft Windows Vista Ultimate Edition Logo
120 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
