HP Compaq Presario V2000 laptop running Windows XP Home SP2
A few days ago, I don't know what precipitated it, the machine started
a jerky behavior. Let's say when playing videos, the sound and pic
would momentarily stop several times a minute. The hard drive light
would light up at the same time, flickering. And it seems the CPU
usage would go to a hundred percent off and on. Because of this
hesitating, everything runs slow.
I'm running AVG free and it's up to date. I also have windows
defender.
I tried using scandisk (via device manager) and it found several
errors and fixed them. But still the problem persists.
I don't know if this is a soft or hard problem. But there has to be a
way to isolate what the problem is.
Any ideas?
Nehmo
Rating: 0%, 0 votes
bads that are causing the periodic momentary stopping, when
the drive is retrying on bads and eventually reads the sector
successfully after multiple attempts with that particular sector.
The best check for that possibility is to post the Everest SMART report here.
If that shows bads, it might just be because the drive is getting too hot
now that its summer and you just need to clean the fur out of the fans.
The Everest SMART report may well show the hard drive temp too.
Thats normal if its just crashed a few times.
Yes, the SMART report will show if its a hard drive problem or
the problem is elsewhere if the hard drive SMART report is fine.
The main evidence for a hard drive problem is the hard drive led symptom.
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
Could be any of several things. Some mentioned. Also open msconfig and
check nothing unneeded is ticked. Also use 'autoruns' to see if
anything is running that shouldnt be - which is what it sounds like.
But be careful with autoruns, very easy to screw up the OS if you
untick something essential.
Also running MS wintop will show a fair bit.
NT
Rating: 0%, 0 votes
problem on my Windows machine. I was using AVG and AdAware Pro. The
problem, in my case, turned out to be "VirtuMonde" which was very
difficult to detect and even more difficult to remove. My symptoms were
identical to yours plus I had an added "popup" bonus which drove me crazy.
My point is that you could be suffering some sort of malware attack and
it may not be a hardware *or* software problem at all.
Linux Geek
Saying that XP is the most stable MS OS is like saying that
asparagus is the most articulate vegetable. (Dave Barry)
Rating: 0%, 0 votes
ID Attribute Description Threshold Value Worst Data Status
01 Raw Read Error Rate 50 100 100 0 OK: Value is normal
02 Throughput Performance 50 100 100 0 OK: Value is normal
03 Spin Up Time 1 100 100 1452 OK: Value is normal
04 Start/Stop Count 0 100 100 1946 OK: Always passing
05 Reallocated Sector Count 50 100 100 6 OK: Value is normal
07 Seek Error Rate 50 100 100 0 OK: Value is normal
08 Seek Time Performance 50 100 100 0 OK: Value is normal
09 Power-On Time Count 0 88 88 5056 OK: Always passing
0A Spin Retry Count 30 137 100 0 OK: Value is normal
0C Power Cycle Count 0 100 100 1858 OK: Always passing
C0 Power-Off Retract Count 0 100 100 27 OK: Always passing
C1 Load/Unload Cycle Count 0 88 88 128173 OK: Always passing
C2 Temperature 0 100 100 4294639661 OK: Always passing
C4 Reallocation Event Count 0 100 100 6 OK: Always passing
C5 Current Pending Sector Count 0 100 100 19 OK: Always passing
C6 Off-Line Uncorrectable Sector Count 0 100 100 0 OK: Always passing
C7 Ultra ATA CRC Error Rate 0 200 253 0 OK: Always passing
DC Disk Shift 0 100 100 8271 OK: Always passing
DE Loaded Hours 0 91 91 3635 OK: Always passing
DF Load Retry Count 0 100 100 0 OK: Always passing
E0 Load Friction 0 100 100 0 OK: Always passing
E2 Load-In Time 0 100 100 209 OK: Always passing
F0 Head Flying Hours 1 100 100 0 OK: Value is normal
The C2 temp looks funny. Is this what you mean by the SMART report?
Yes, I suspected there may be dirt around the fan. I have lots of
dogs. It really would be "fur". I'd have to figure out how to open
this thing.
(||) Nehmo (||)
Rating: 0%, 0 votes
Is warmer/hotter than normal air being blown out by the fan(s)?
Does there appear to be any dust buildup around the fan(s)?
Check the memory for integrity using one of the utilities below running it for a few
hours (2-3):
Brian A. Sesko { MS MVP_Shell/User }
Conflicts start where information lacks.
Suggested posting do's/don'ts: #
How to ask a question: #
Rating: 0%, 0 votes
Have you tried a system restore to before the issue started? What does task
manager show as the process maxing out the CPU? Do you have process
explorer? That will give more detailed info than task manager.
Rock [MS-MVP User/Shell]
Post a New problem for Toshiba MK8025GAS 80 GB Hard Drive
Email this problem
Can you Help with these Hard Drives problems?
E-mail verification
