Washer off balance
I would like to know how many springs on each side of washer
  • 52 Answers
There's usually 2 on each side. for a total of 4
Posted on Feb 22, 2009
Washer spins but shakes all over floor. changed all balance springs,but still does it. model lsr8233eqo whirlpool.
Balance of the machine is naturally important, however if the washer has an internal problem with the drum spinning out of balance; your machine will move all around. Many times this is due to an over load of clothes or an item that falls to one side and creates a load to one side.
Feb 12, 2018 | Washing Machines
Amana washer ntw4700yq1 bangs when entering spin cycle, why
sounds like the clothes load is unbalanced and uneven try sorting out the load and balance it out if it keeps banging side to side try checking the springs inside the washer (careful when opening your clothes washer please! or allow a pro to open your washer and inspect it for any spring weaknesses)
Dec 16, 2017 | Amana Washing Machines
WASHER SPINS LIKE ITS OUT OF BALANCE ALL THE TIME
Rex, probable broken balancing springs. Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
GE Washer Top Loader Out of Balance Shaking Repair Tutorial
http://forum.appliancepartspros.com/washer-repair/6812-spin-cycle-badly-out-balance.html
How to Fix Shaking Washing Machine
How To Fix And Stabilize An Unbalanced Washing Machine
Mar 09, 2016 | Washing Machines
Tub is off balance
The tub is out of balance. When it starts hitting the sides, stop the washer and move your clothes around inside the tub to balance the tub. Now start it to spin again. This should stop the tub from hitting the sides.
Feb 14, 2012 | GE Washing Machines
Tub free hits side of washer when trying to spin
1- Clothes load is not balance. 2- Tube is balanced by several springs from the bottom tube to the chassis. If one of these springs is broken or slipped out the tube will lean to onside causing this problem. Check these out.
Jan 09, 2010 | Washing Machines
My Maytag Ensignia washer is not spinning well. It bangs side to side with even the smallest loads. It seems like something is loose. Is this something I can fix myself or do I need a repair mans help....
Try leveling the washer... If the washer is level, then don't wrap the clothes around the agitator...drop the clothes straight in, on top of each other evenly around the agitator. The Ensignia washer has a Dual action agitator... That means the clothes roll over them selves, instead of moving side to side, as with a traditional agitator. wrapping the clothes around the agitator will cause the load to be un balanced and then cause the "banging" noise... this should take care of the problem...
Jul 31, 2009 | Maytag Ensignia MAV4758AWW Top Load Washer
Washer stays out of balance
most likely a spring has come off the tub base. there are three short horizontal springs that surround the tub connecting it to the tripod base and one long spring in the very back that connects the base to the bottom back. check these out and reattach if off.
May 24, 2009 | Whirlpool LSR5132PQ Top Load Washer
Maytag Washer MDE7400AYW goes off balance while spinning about half the time. Walks across room. Springs are OK. Tub seems very easy to move from side to side by hand.
Typically when the drum spins and walks the washer, it is a loading issue.
As the clothes spin, they collect on 1 side, due to cintrifical force acting upon an uneven load.
THis is especially prevalent in loads that are:
1. small,
2. contain lots of towels and
3. anything else that really holds water and is very heavy when wet (like comfortors, pillows)
These will very quickly throw the load off-balance.
When it happens, pull out some of the itmes, and re-load the laundry more evenly around the drum. Be sure to circle the post with towels and sheets, etc.
If you continue to run the machine off-balance for an extended time, the bearings and seals will wear quickly. Unfortunately, you will only know this when the washer begins to leak out under the machine onto the floor.
Hopefully this will fix-ya....if not let me know please!
Nov 07, 2008 | Maytag Washing Machines
Washing Machines Logo
80 people viewed this question
Top Washing Machines Experts
