Question about SanDisk Sansa e250 MP3 Player
Sansa Fuze wont work with home stereo
Okay, i want to use my sansa fuze with my stereo.
partly because i have some songs on it that i dont have on cd or anything so i cant listen to them otherwise..
but anyway,
what happens is this :
i turn my stereo on, switch the source to usb, and then plug in my sansa. but it doesnt do anything, except it says "no song" on my stereo.
it says connected on the sansa, but i get nothing.
help?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • SanDisk Master
  • 102,366 Answers
The Sansa doesn't play music through the USB port. You can connect the Sansa to your stereo via the Sansa's headphone jack.
Posted on Jan 11, 2012
meeknotweak
  • 341 Answers
SOURCE: sansa fuze FAT error
Plug your Fuze into your computer. Open "My Computer," right click your Fuze and click "Format," a window will pop up with settings on how you want to format it, make sure it's set to FAT, then click "Format."
Posted on Aug 25, 2009
Schmead10
  • 650 Answers
SOURCE: my sansa fuze keeps freezing
Start the sansa updater, set sansa to recovery mode plug into computer. unplug when told sansa should restart (Lock sansa press and hold rec and menu until recovery begins)
Also you can Try
Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.....
Posted on Nov 02, 2009
WWolf
  • 10 Answers
SOURCE: How do you record FM radio on Sansa Fuze?
OK, while in radio mode, press the bottom of the wheel, scroll down to 'Recording', then select 'Record Now'.
(I have a Sansa Fuse too, so, i know my way around it.).
this should help.
Posted on Jul 22, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: sansa fuze
Make sure the hold/lock is not enagged
Try another USB port
If that fails:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Mar 08, 2009
Schmead10
  • 650 Answers
SOURCE: can't download video's to my sansa fuze
Download the converter after you run the link below ....Put check next to converter/firmware update/Manual download...Go to your start menu go to sansa choose converter(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link
Run this program or save then run
Why wont this sync with my itunes library?
Hi, Is the SanDisk Sansa Fuze compatible with iTunes? In some ways, it is. Unfortunately, the Sansa Fuze and iTunes don't always play nice together. You'll have to get a few workarounds to make these two sync together.
The SanDisk Sansa Fuze and iTunes
The SanDisk Sansa Fuze is natively a Windows product. You should be able to sync it with Windows Media Player automatically. However, not everyone owns a Windows PC and even if they do, they might store more music in their iTunes library.
If this is the case for you, you might find it helpful to be able to sync your Sansa Fuze with your iTunes music library. Bear in mind that you won't be able to sync apps, games or any other iTunes products that are not formatted for use on a Sansa Fuze.
Using iTunes with the Sansa Fuze
So, is the SanDisk Sansa Fuze compatible with iTunes? If you download the right software, it is. Apple offers a free download that works with many other non-iPod MP3 players, Sansa Fuze included.
Unfortunately, this product only runs on a Mac operating system. However, if you own a Mac, this is great news because it means you can still use your Fuze without buying a Windows PC.
If you use a Windows PC and want to transfer your iTunes music to the Fuze, don't lose hope - there's a way to do that, too.
Syncing the Sansa Fuze with iTunes
If you're using a Mac, visit this link for Apple's free software download. It comes directly from Apple, so you can be assured that it's spyware-free.
Install the software on your Mac. You need Mac OS X 10.4 or higher as well as iTunes version 8 or higher.
Plug your Sansa Fuze into the Mac and wait for the software to open. You should see a listing of your iTunes music library pop open in a window. You're then given the option to sync as many songs as possible onto your Fuze.
The syncing process is similar to syncing an iPod. Don't unplug the device until it's finished.
Syncing the iTunes Library in Windows
You can sync your Sansa Fuze with iTunes using a script called the Automator, found here. Once downloaded, open the script under your "Downloads" folder on your "C:" drive and find a string of characters that looks like this: "/Users/richard/Music/*.mp3".
Replace the name "Richard" with your own username. Don't change anything else. Select "File," "Save" from the menu.
Select the Automator icon with the right click button on your mouse and choose "Open with," "Automator Runner." If working properly, this should automatically sync the music from iTunes with your Sansa Fuze.
If that doesn't work, go into your iTunes library and highlight any DRM-protected tracks that you purchased from iTunes. Right-click and select "Make MP3 Version." These should now be compatible with the Automator.
This sounds like more or less of a "hack" than a solution, but this might be the only way to sync music from iTunes to your Fuze using Windows. If all else fails, make MP3 versions of the songs as shown above, then navigate to your iTunes folder where those files are stored. Then drag and drop these into Windows Media Player, where they should sync right onto your Fuze.
Hope that helps..
Feb 17, 2011 | SanDisk Sansa Fuze MP3 Player
Sansa Fuze not Regestering Songs
The device only likes mp3's. Most other files don't show up.
Apr 13, 2010 | SanDisk Sansa e260 MP3 Player
My Sansa Fuze won t recognize certain songs
you need to check the format the songs are in, try putting them in mp3 format
Mar 28, 2010 | SanDisk Sansa Fuze MP3 Player
When i connect my fuze to the usb port in my cd player i dont hear any songs jus says "check"
The USB connection on the Sansa is to communicate with a computer (and incidentally to charge the battery). It's not intended to connect to a CD player.
Mar 04, 2010 | SanDisk Sansa Fuze MP3 Player
I have a sansa fuze 8 gigs, FAT is corrupted, can it be fixed?
Hi, dont worry your player is probably fine, you just need to refomatt it. Checked out the sanza forum and they were pretty helpful
This guide should be useful
http://forums.sandisk.com/sansa/board/message?board.id=sansafuse&thread.id=11867
Jul 20, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa Fuze skips songs
Same problem with my sansa fuze 8 gig It skips over songs instead of playing them.
Mar 25, 2009 | SanDisk Sansa Fuze MP3 Player
My songs wont add on to my mp3
If your sansa 'fuze', right dosen't like your media get the sansa media converting software, My Fuze came with a mini-cd, if yours didn't you can download the official sansa media converter on
www.sansa.com/downloads
I hope it works for you! -Aptera P.S. I have no clue about MAC OS
Nov 27, 2008 | SanDisk Sansa Fuze MP3 Player
Sansa fuze 4 g photos wont open
Get "Sansa Media Converter" from the Sansa website or the CD that came with you Fuze.
If you are not using the "Sansa Media Converter" program to convert the photos to a format the Fuze can display, they will not show up.
Nov 07, 2008 | SanDisk Sansa Fuze MP3 Player
Synchronize to continue your music subscription
first you must format the player using msc mode then after that retransfer the songs to the player. If you are receiving this message it means that the songs on the player have expired. This is normal if you download the songs off rhapsody, napster or any online music stores and if you have ripped songs iwht copy protect music on it if you ripped them using windows media player 10.
Dec 06, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
107 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
