Question about RCA RCR311B Remote Control
I have an RCA ATSC converter box. Volume and on/off buttons quit working.
  • Anonymous Mar 16, 2009
    SAme prolem, I can't find the operations manuel to reset the codes for my telvision.
5 Suggested Answers
SOURCE: remote control for digital converter box
What brand is your digital converter box? Samsung
It does appear that universal remotes made before these boxes existed accept pre-existing codes.
Here is the Radioshack FAQ for Digital TV converters that they sell:
http://dostuff.radioshack.com/files/DTVConverterFAQs.pdf
Posted on Sep 14, 2008
SOURCE: New Rca DTV converter / panasonic tv trying to get remote to work
You must set the code to conect your tv to your remote. The instructions are in your manual with a list of codes.
Posted on Nov 25, 2008
SOURCE: Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Posted on Jan 17, 2009
  • 23 Answers
SOURCE: Cant get program codes to work on AKIA tv with rca converter box
I recently bought a used LCT2060 that had no remote. I figured my comcast cable remote would work without a problem but it didn't. So 3 universal remotes later I found my solution...a radio shack2_bing.gif universal gamer remote. It controls up to 5 components plus your xbox360, playstation and pc. The price on sale was a mere 12.97, not bad if you ask me. Hope this helped. The code that worked for the Akai2_bing.gif was 11676. Take care...
Posted on Feb 18, 2010
  • 8457 Answers
SOURCE: Hello, the remote has quit working for the volume
Ur free air DTV converter box have problem taking in the programs codes belong to ur tv,belong to the remote.Turn the converter box off/on to reboot ur DTV converter box.Read ur owner manual,re enter ur tv codes,belong to ur tv.U tv should be up and running again.
Posted on Jul 31, 2010
How can i get local channels on my rca tru flat tv BD20TF10
The RCA BD20TF10 was manufactured before digital tuners (ATSC) were required. It only has an analog (NTSC) tuner so you will need a digital to analog converter box to watch most local channels. (These were the boxes available with the discount coupon as the ATSC broadcast transmitters were enabled.) Depending on the converter box model, use either the composite video input or use the RF antenna connection. If you use the RF output from the converter, you will need to set the TV to channel 3 or 4 (set the switch on the box to match). Then follow the directions for searching for channels with the converter box.
You may be able to find a low power analog station still broadcasting. However, you'd need to be close to the transmitter or have an antenna that is rated for a long-range signals. (Usually this will need to be an outdoor antenna with few obstructions between the transmitter and the antenna.) To scan for any available NTSC channels, make sure that the TV is set to TV mode. Then press Menu. Use the Up/Down arrows to highlight Channels and press OK. Select Auto Channel Search and press OK. You may need to confirm this step by highlighting the Start Search option and pressing OK. This will also let you add the appropriate channel for watching the signal from the converter box with the RF cable. The manual for this TV is available from Sears Parts Direct here: http://www.searspartsdirect.com/partsdirect/user-manuals/BD20TF10-Rca-Parts-Television-Parts-manual . The direct link to the manual is http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0312126.pdf .
I hope this helps. I'm not sure if the Menu feature is available from the front panel buttons. You may need a remote with a matching code to do the channel scan.
Sep 26, 2016 | RCA Televison & Video
Program my g.e remote control to a A.T.103 gematic digtal box
Tv Converter Box Deals
www.bestdeals.today/tv-converter-box
Digital Converter, Ematic Digital TV Converter Box with Recording, Playback, ...Digital to Analog TV Converter DTV Tuner Box w Remote, Program Guide, PLUS MORE! ... GE Television Antennas Omni TV Indoor Antenna 24731 ... HDMI/HDTV/DTV/RF/RCA/USB Digital Converter Box TV Tuner With Remote Control PVR.
Ematic DVR Recorder Television HDMI Media Player ...
www.altatac.com/p-15751-ematic-dvr-recorder-television-hdmi-media-p...
Ematic DVR Recorder Television HDMI Media Player Converter Box w/ USB ... TheEmatic AT103B Digital Converter box allows your TV without a digital ... Features an electronic program guide, parental controls, and a USB ... Full function remote controlincluded. .... My Account My Account Order Status Track Your Order.
At103b Ematic Converter Digital Atsc
antennadisht.com/at103b
11 ozmiscellaneouspackage contents converter box remote control 1 x user ... Review (mpn:at103b for sale) Digital Converter Atsc Ematic At103b Box . ... You can find your tracking number by ing on my and scrolling down to your purchase with us. ... Features an electronic program guide, parental controls, and a usb ...
Jan 24, 2016 | Televison & Video
Rca atsc converter box remote program codes
093,085,083,091 are the codes to check. If you wish to get more, check the sites linked here.http://electrohelponline.blogspot.com/ http://electronicshelponline.blogspot.com/ http://remotesearch.blogspot.com/ Pull up previous posts, either by its left side bar, or view it in Mosaic / Timeslide / Flipcard option.
Aug 02, 2013 | Televison & Video
I have a sony tv with a rca atsc dta8001bl converter box and i need the code to program the remote
what model and make is the remote your programing ? and what is the model for t.v ? most generic codes for sony t.v. using a rca remote if 3 digit code = 002, 205, 216, 218 and for rca converter box 000,003,004,005,006,007,019,096,098,099,100,101,102,103,129,179,181,188,196,203,202,215,233,236,237
Jul 15, 2012 | Sony Televison & Video
I have a RCA Converter box. ATSC mfg Dec 2010. I need the access code for the tv I am hooking up this converter box too. Sanyo Television. Thank you
Hello
Try these links.
tv.manualsonline.com/.../rca/...converter-box/remote-instuctions-213
Try these codes too:
037, 082, 083, 124, 198, 268, 274
http://www.dataentryjobs.us/67948.html
Feb 08, 2012 | Televison & Video
Jul 31, 2010 | RCA Televison & Video
RCA RCR311B Remote Control Logo
469 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
