Question about Dryers
Whirlpool stackable dryer was working and stopped. Sounds like it's getting power when the button is pushed - Won't start/spin. The belt has been screeching for some time. Assume the belt has snapped or slipped. Home came with machine - Don't have manual. Can the dryer be opened to access the belt from the interior of the drum?
  • 52 Answers
Stacks vary, you may be able to access between washer and dryer... there is usually a panel there, but some do have the large acces panel in the back and yes you can access the belt... watch your fingers aroound the motor because when you put a new one on, the tension is very tight
Posted on Feb 22, 2009
Model lde8414ace maytag dryer
There is something causing the drive motor to bog down. This means the fan isnt spinning fast enough and the whole unit is overheating. Check for anything around the edges of the drum, coins keys etc. The squeal is the belt from the drum being stuck. See how hard it is to turn by hand.
Jul 08, 2013 | Dryers
Kenmore dryer won't start
Spin the drum by hand to see if you feel resistance. The belt may have broke.
Oct 21, 2012 | Kenmore Dryers
When I turn the dryer on and push the start button it won't start but it sounds like it's getting power
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 30, 2011 | Whirlpool Inglis IP8200 Dryer
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Whirlpool elec dryer starts when button pushed, but stops when button released . Has happened before, but seemed to solve itself.
There is a centrifugal switch on the motor that maintains power to the motor if the motor is indeed spinning and the belt intact. If your belt isn't broken, check the switch.
Jul 14, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer has power, but drum won't spin
More likely does have a belt. Get me the model number and I will see if I can help you on this problem, Thanks, Sea Breeze
Mar 21, 2009 | Whirlpool GEW9250 Electric Dryer
Washer stopped in the middle of a load
sounds as if yhou have a lild switch problem , lift and close the machine lid and listen closely for a "clicking " if hte machine doesnt think the lid is down it wonk spin/ drain for saftey reasons. common issue broken lid switch
Nov 13, 2008 | Washing Machines
LWH0050P Stackable Compact Washer not spinning
sounds like it could be the transmission. Does the tub turn when you turn the pulley in either direction with your hand? And take the belt off see if the motor turns when you close the lid and turn it on without the belt??
Aug 30, 2008 | Washing Machines
Belt installation whirlpool stackable
thats funny cause they dont have belts
most have motor couplings that will break and it wont spin
if it still agitates its gotta a motor coupling
Jul 08, 2008 | Frigidaire FEX831CS Top Load Stacked...
Dryers Logo
93 people viewed this question
Top Dryers Experts
