Question about ViewSonic VX1935wm LCD Monitor
Blacks out after two seconds of display,
Viewsonic monitor, vx1935wm, quit producing a picture, it will show for 2 seconds when the power is turned of then blacks out.
    Champion:
  • 293 Answers
Hi...there,
It's seems you got a busted backlight inverter. Need to replaced a new inverter...
Posted on Feb 23, 2009
    Problem Solver:
  • 5 Answers
I had the same problem with my vx2235wm. the symptoms were it would power on with no signal and the blus light would glow. when the PC was turned on it would kick back to the "power-save" state and the desktop would disappear.
To fix this you need to take the case apart (3 screws, one is behind the stand, then gently pry it apart starting at the bottom with a flatscrew driver and pop each tab carefully every couple inches, along both sides and a final wiggle to free the top edge.)
Inside you will find a metal cover, to remove this undo the screws holding the power supply and display ports then unscrew the screws holding it on.
Take notes of where the wires going in are oriented and then you should be able to see two boards.
In this case the suspect part is the DAC which the power supply goes into. On the DAC there will be a part number. In my vx2235wm it was DAC-19M009. Buy the whole board online. Mine shipped for around $40 total. Wait 2 days for it to arrive and installation is pretty much reverse of removal.
My dead display is back in comission, hope this helps with yours.
Posted on Aug 24, 2009
  • 4 Answers
Check your board and you will most likely find "domed caps". The electrolitic capacitors are easily replaced with just a soldering iron. Make sure to replace with the same or higher voltage rating and get the polarity right.
Posted on Apr 01, 2010
The monitor will turn on then turn right off
> Check power connector on monitor.
> If not any power option on then contact hardware engineer.
> If monitor on but not any display come then check all PC cable and power.
> check RAM slot.
> HDD Check it.
Thanks...
Sep 09, 2013 | ViewSonic VX1935wm LCD Monitor
ViewSonic VX1935wm Monitor says out of range
The problem is in the power supply inverter board, usually caused by bad capacitors, suggest a professional.
Mar 10, 2012 | ViewSonic VX1935wm LCD Monitor
The monitor shows black when I power up my computer in the morning. When I turn the monitor off, then on, I get a picture for a few seconds with analog in the upper right corner, then it goes black again....
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
May 09, 2010 | ViewSonic VX1935wm LCD Monitor
Gateway FPD1750 monitor's keep go black screen, no picture at al
tgordon60, If you know how those NEW "CURLIE-Q" energy efficient CFL light bulbs produce WHITE LIGHT, then you will know what makes an LCD display panel produce all the pretty colors and the WHITE BACKGROUND of the FIXYA web page!!! Only difference is that your "cold-cathode-fluorescent-lamps" are thinner and straight, and hung on rear of LCD glass panel and have a DC to AC electronic ballast called an "INVERTER" circuit to produce 600 to 1000vac to light them up. Get to my FIXYA profile and read my responses to other BLACK screen lcd owners to learn about all your options for repair. Follow any of the links to other web pages you find there. Your monitor not any different than ACER, DELL, VIEWSONIC, BENQ, SONY, AOC!!!!! 12fixlouie aka louie12fix
Dec 30, 2009 | Gateway Computers & Internet
My viewsonic ve170m display for 2 seconds and go back to black
Your power supply has gone bad you need to take the back off. Check the power supply look for blown caps the tops will be raised replace them that will fix the monitor.
Mar 16, 2009 | ViewSonic VE170m (Beige) 17" LCD Monitor
IC POWER CM2017 LCD MONITOR
Normally when this type of problem happens, the first suspect would be the inverter board, then the filter capacitors and lastly the mainboard.
A defect in one of the lamps and faulty inverter IC may cause the display to shutdown as well. If the lamp is defective, it will send a feedback and cause it to stop producing output signal thus the display just shut off once you switch in ON.
Jun 24, 2008 | Gateway FPD2275W LCD Monitor
Monitor stops display
most likley the monitor has an internal power supply failure, generally the cost of repair could be higher than buying a new one.If your monitor is still in its warranty period contact the manufacturer,if not do you know of a local tv repair shop that provides free estimates to confirm cost of repair vs. replacement?
Dec 14, 2007 | ViewSonic VA1703wb Monitor
ViewSonic VX1935wm LCD Monitor Logo
1,606 people viewed this question
Top ViewSonic Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
