Question about JVC KD-S580 CD Player
How to set clock on kds580 player
Which button to set clock and any specifics as to what else to do to set the clock thanks.
Saida de audio jvc kds580
whats the problem please send exat iformation
Apr 22, 2011 | JVC Audio Players & Recorders
How do you set the clock on a Pioneer DEH-1600?
To set the clock, please follow the following steps
#1
Press and hold the "SRC/OFF" button on your Pioneer car CD player until the unit powers down. Note that the "SRC/OFF" button is located on the top left of the Pioneer car CD player.
#2
Press and hold the multi-control knob, located on the left side of the CD player. Hold the multi-control knob until the words "Clock Set" appear on the CD player's display.
#3
Turn the multi-control knob until the words "Clock Set" are highlighted. Press the multi-control knob on your Pioneer car CD player to enter the clock setting mode.
#4
Turn the multi-control knob to highlight the "Hours" option. Press and hold the multi-control knob until the hours-place digits begin to flash. Rotate the multi-control knob until the desired value is displayed. Press the multi-control knob on your Pioneer car CD player to save your changes.
#5
Turn the multi-control knob to highlight the "Minutes" option. Hold the multi-control knob until the minutes-place digits begin to flash. Rotate the multi-control knob until the desired minutes value is displayed. Press the multi-control knob to save your changes and end the clock-setting process.
Hope this might help
Thanks
Oct 07, 2010 | Pioneer DEH-1600 CD Player
Just purchased, didn't have any instructions in box. How do I set time and alarm? Thanks
Clock: With the radio off, press the Clock Set button, then the Memory button. The time will start blinking. Use the Hour and Minute buttons to set the alarm time. Press the memory button when you have set the correct time.
Alarm: With the radio off, press the Alarm Set button, then the Memory button. The alarm time will start blinking. Use the Hour and Minute buttons to set the alarm time. Press the memory button when you have set the correct time.
Sep 19, 2010 | Memorex MI4019BLK Alarm Clock Clock Radio...
I bought a car with this model, 6cd/cassette
Setting the clock:
1.Press and hold the Band Button (on the left of radio)and the Clock setting button (button No:4 on the right) to display the clock.
2.Press and hold the Band button and the Clock Setting button again for 2 seconds or longer for the clock display adjustment.
3.Press the SEEK UP Button (on the right of the radio with the arrows) to set minute.
4.Press the SEEK DOWN button to set hour.
5.Press the Band button to confirm the clock setting.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 25, 2009 | Clarion ARX6670Z Cassette Player
Sanyo Hi-Power 50Wx4 FXCD-1350 CD-R/RW setting the clock
Press the DISP button for more than two seconds,then to adjust mins.press the > button,to adjust hours press the < button.Press the DISP button again to start the clock.Please don't forget to rate, Thanks.
Apr 09, 2009 | Sanyo FXCD-1350 CD / Cassette Player
Zenith XBV443 DVD Player / VCR Combo - Set Clock Manualy
I have the Zenith xbv613 model DVD/VCR player and also need to change the clock set up. For the xbv613 I had to switch the player to VCR. The menu button did not bring the clock set up in DVD. When I switched to VCR and hit the menu button the clock set up showed, where I used to right arrow button to change the time. Hope this helps.
Sep 24, 2008 | Zenith XBV443 DVD Player/VCR
Setting the time on my clock on radio Model # RP3755B
Well, I have an RCA clock radio/CD player and just figured it out. Press the "Time" button and hold it down while pressing the CD "Forward" button. Hope it works for you! Ron
Jul 03, 2008 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
Pioneer cd radio deh-11 clock set
For most Pioneer single CD players, you can set the clock using the following steps:
  1. Press and hold the SOURCE button until the unit shuts off.
  2. Press and hold SOURCE again until the clock appears. With some models you will press and hold the FUNCTION or AUDIO button instead of the SOURCE button.
  3. Press the left or right arrow to select the segment of time you wish to adjust.
  4. Press the up or down arrows to increase or decrease the numbers in the blinking segment.
  5. Once the clock is set correctly, press the SOURCE button to exit.
Nov 10, 2007 | Pioneer DEH-1100 CD Player
Setting clock on car player
For most Pioneer single CD players, you can set the clock using the following steps: 1.Press and hold the SOURCE button until the unit shuts off. 2.Press and hold SOURCE again until the clock appears. With some models you will press and hold the FUNCTION or AUDIO button instead of the SOURCE button. 3.Press the left or right arrow to select the segment of time you wish to adjust. 4.Press the up or down arrows to increase or decrease the numbers in the blinking segment. 5.Once the clock is set correctly, press the SOURCE button to exit.
May 20, 2007 | Pioneer 50w x 4 CD/MP3/WMA/ receiver with...
Pi0oneer blue led reciever cd player
May 11, 2007 | Pioneer 45X4 DFS BLUE LED CAR CD
JVC KD-S580 CD Player Logo
196 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
