Question about Medion md40298 Notebook
Time zone setting on Medion atomic clock
Misplaced instructions as to how to set time zone-has usa time zone map.currently shows west coast and i need an east coast setting
  • 4 more comments
  • Anonymous Mar 10, 2009
    HOW DO I SET THE TIME ZONE TO EASTERN?
  • Anonymous Mar 11, 2009
    I have misplaced my instructions on how to set time zone. It is automatically set for pacific and I need central. Hope someone can help me soon.
  • Anonymous Mar 17, 2009
    can't change my medion time zone
  • dirtbike46 Mar 28, 2009
    My clock is also set for the west coast, help?
  • eric_regi181 May 05, 2009
    I have a Medion Atomic Clock model 10954. It is several years old. I have misplaced the instruction and need help setting the appropriate time zone.
  • Kurt Mathes Nov 19, 2013
    http://download2.medion.com/downloads/an...
Re: Median MD10954 time zone setting.
Press the MODE button but do not hold it in.
repeatedly pressing the MODE button will alternately display the DAY OF THE WEEK or the SECONDS next to the time.
With the DAY OF THE WEEK displayed, press and hold the UP button for up to 5 seconds. Each 5 second press of the UP button will move the time zone by one.
When finished, you may press the MODE once again to revert to SECONDS display.
Good luck,
ACTION from Cincinnati
Posted on Jun 12, 2009
  • George Lewis
    George Lewis Jan 14, 2017
    Thanks. Without the instructions I couldn't even guess that one.
Thank you for the fix (action333). Extremely nice and generous!!!
Posted on Apr 14, 2010
How do I set the alarm on my Sharp Accu-Set Model SPC452?
  • 1 Insert batteries into your atomic clock. Without these the clock won't work. The number of batteries required depends on the clock. There is usually a panel on the back of the clock where you can insert the batteries.
  • 2 Set the clock. Usually, this is done automatically, as the clock will seek out and receive the signal within 6 to 8 minutes. If this doesn't happen, you'll need to do it yourself. Hold down the "Set" button. A figure on the clock will start blinking. Adjust this by pressing the adjustment button. Press "Set" again to go to a new time. Continue until the clock is properly set. No matter what you put time you put in manually, the clock should adjust to the atomic setting within 48 hours.
  • 3 Set the time zone on your atomic clock. How to do this depends on your specific clock. On some, there is a time zone slider; you simply slide it to your time zone. Otherwise, you will need to enter the manual mode you used to set the clock. Switch the mode until the time zone starts blinking. Now, adjust until your current time zone is selected. If it goes by Greenwich Mean Time (GMT), the time zones in the United States are -5 for Eastern time, -6 for Central, -7 for Mountain, and -8 for Pacific.
  • Read more : http://www.ehow.com/how_6403731_instructions-time-zone-atomic-clock.html
    Jan 29, 2015 | Audio Players & Recorders
    How to set timezone
    Hi Mary
    To set the timezone:
    • In the Normal Time Display, press the [MODE] button to enter the Alarm Time Mode.
    • Press the [SET] button to set the desired time zone. Refer to the Time Zone map on the display, P=Pacific, M=Mountain, C=Central and E=Eastern.
    • Press the [MODE] to return to the time mode position.
    Full instructions for all of the clock features can be found at the following link:
    Instructions Warranty for Atomic Clock Model SPC364
    Trust this helps
    Regards
    Alan
    Sep 27, 2014 | Home
    My clock has the west coast showing I need the TN area
    right click on the time at the bottom right corner click on time zone find your area the apply job done.
    Jan 10, 2013 | Medion md40298 Notebook
    I live in Eastern Time Zone. My atomic clock shows map of USA in top right hand corner and it is set in Western Time Zone. How do I reset to Eastern Time Zone? I have had atomic clock for several years. I...
    The "mode" button is there to change the function of the + & - buttons.
    If you press the mode button several times you will cycle through the various setting features of the clock.
    Look for the one that sets the time zone and use the + or - buttons to select your zone.
    Some experimentation may be required!
    Feb 25, 2010 | Casio GW1500A-1AV G-Shock Atomic watch
    Atomic clock is 2 hoursfast
    You need to reset it to YOUR time zone. The default on this model is Pacific Coast time so you must be in the Central Time Zone (2 hours ahead of Central). Instruction manual should show you how to reset.
    Feb 09, 2010 | SkyScan 86742 Digital Atomic Wall Clock
    Setting time zone
    found manual--
    Remove from email listing and send no further communiques.
    Oct 31, 2009 | SkyScan 86709 Atomic Wall Clock
    How do I set time zone
    My 86742 batteries took a dump after many years so I ended up with the same problem. It took me about an hour to figure it out, but here is the solution:
    1) Pull the batteries and replace them, or gently insert a straightened paper clip into the "reset" hole in the back of the clock. The clock will beep.
    2) Press the "receive" button" so the clock sets itself. The default time zone will be "EA".
    3) Press the "adjust" button untill the time zone is showing (rather than the day-of-the-week).
    4) Press and HOLD the "set" button down untill the hours digits start to flash.
    5) Now press the "set" button again six times. The time zone characters will flash.
    6) Press the "adjust" button untill your time zone appears.
    7) Press the "mode" button to return the clock to normal operation.
    8) Press the "adjust" button to display the day-of-week.
    Do you think they could have made it any MORE complicated?
    May 18, 2009 | SkyScan 86742 Digital Atomic Wall Clock
    Skyscan Atomic Clock WWVB
    figure out where yu are north south west east zones on your map from where yu are , then pull battery again it should stop at for eight or twelve push time zone then set in a window facing your zone it should automatically pick it up shortly in awhile
    sw i think it may stop at four also but then wait
    Oct 14, 2008 | SkyScan 86709 Atomic Wall Clock
    Sharp Atomic Clock Daylight Savings
    I have misplaced the manual for my sharp Atomic clock, need to reset the time zone and shut off the alarm. How can I obtain a new manual?
    Mar 10, 2008 | Baby Gear
    Resetting the atomic clock to the correct time zone, and outside temp to work.
    For the Sharp SPC374T Atomic Clock - Time Zone setting- Press the 'Time' button once, the time zone will show where 'Day' usually is, use the Up or Down buttong to adjust.
    For the outdoor Thermo, credit to my neighbor for this one. Remove battery from main unit, wait 2-3 minutes. Reload batteries. Once you get a reading from the outdoor sensor, hit the reset on the main unit. You will have to reset the time zone as described above, but this worked for me after 10 months of no outside temp showing up!
    Good luck,
    Doc
    Dec 01, 2007 | Baby Gear
    Medion md40298 Notebook Logo
    3,696 people viewed this question
    Top Medion Computers & Internet Experts
    John Anderson
    John Anderson
    Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
