Washing maching squeeks while in spin cycles
Squeeking srarts low gets louder as the washer spins faster
  • awheeler8482 Feb 22, 2009
    I will try this and see what happens
  • Outlook09TN Feb 26, 2009
    On the spin cycle, there is an unbearable droning squeeling noise...as though it were metal on metal....I've sprayed liberal amounts of WD on the motor underneath and the pulleys with no success....any other ideas?
  • 52 Answers
Try this... if you can, spray some wd-40 all over the motor and transmission shafts... sometimes, using a powder detergent can clog it up OR just the normal wear and tear if you using a liquid... it's always a good idea to run thru a cycle of bleach on your hottest setting. it break up that debris and is considered good upkeep.
Posted on Feb 22, 2009
  • Janelle Tablada Feb 23, 2009
    Ok let me know. This is the easiest fix you know. If it doesn't solve it, than I can help you troubleshoot the more difficult things...
  • Janelle Tablada Feb 27, 2009
    You will have to take the agitator off. There are 2 different kinds on most models. some u can take the fabric softener cup right out and pull the agitator off. Other, you have to unscrew a knob then pull it off. once that's done, u can check to see if there's anything like a quarters that may have fallen out of your pants. if there's nothing there, there should be a few screws when you can take off the inner tub. take that out and see if something is caught there. let me know.
The washer recently began producing a high pitch squeek during the washing cycle, and a louder than normal sound during the spin cycle.
The motor Carriage is not pulling back fast/far enough special poly lube you can use other lube just wont last long or will deteriorate wheels quickly. What you can do is set for spin, hold open lid slightly with one hand pull back on motor slightly. If sound stops you got it. Other wise sounds like mount stem may need replacing if you do also replace spin bearing this is under basket and outer tub on top of transmission.
Nov 25, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer noise
Hello, If its making a loud squeeking/scraping noise, in my maytag that i repaired, the problem was the waterpump. If you turn the washer on it's side, you will see that it has a belt with three pully's on the bottom. One pulley is connected to the waterpump and right where the pulley meets the metal plate it's connected to, there should be a gold2_bing.gif coupling. This coupling sometimes comes loose and scrapes the metal plate on spin cycle (when the pulley is spinning) which causes the scraping/squeeking sound. If this is the case, you will see where the coupling has scraped a groove into the metal plate. The coupling will eventually catch while spinning and break entirely. The cheapest new water pump is $80.
Thanks
May 19, 2010 | Washing Machines
Maytag front loader HE washer.
cheak your tube if there is a nail or an object is stuck in one of the holes
Jan 24, 2010 | Maytag MAH6700A Neptune High Efficiency...
Maytag model# sav365zaww squeeks
check your pump the bearings in your pump
could be going out this will cause the water not to be pumped out properly and will also cause a squeek
Dec 29, 2008 | Maytag SAV365Z Top Load Washer
Squeeking noise on whirlpool washer duet ghw9100lw2
replace your belt in back easy.every year if still has smell buy warranty your rear bearing is going bad."less soap plz"
Nov 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite model: 22932
Washing machine works fine UNTIL spin cycle. Loud engaging sound and then it makes a squeek, squeek sound...not really a squeek, but if you were to listen to it, eee, eee, eee, eee, eee and loud.
Dec 10, 2007 | Washing Machines
Spin cycle
Try some anti-squeek on the belt, or soap; shd solve the problem.
Sep 07, 2007 | Hotpoint Aquarius WD63 Front Load...
Kenmore elite washer 26922
I would take body of washer find out where noise coeing from.. got 2 screws in each side of head, flip head up and take clamps off .. pull whole body off washer run thu cycle and see if ya can locate the noise.. sometimes water pumps get something in them that well make weird noises.. but are in all cycles.
Sep 07, 2007 | Washing Machines
GE Washer WPSQ4160T
TRY REMOVING FRONT OF WASHER YOU WILL SEE 4 SHOCK LIKE PISTONS TAY GET DRY AND MAKE GRINDING NOISE OR SQUEEKS LUBERCATE ALL REAR HARD TO GET AT MAKE SURE YOU GET TOP AND BOTTOM (RAY)
Dec 07, 2006 | GE WBSE2090A Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
