Question about Dell Inspiron 1501 Notebook
Dell inspiron 1501
Battery wont get full charge. laptop wont turn on without being plugged in. manual only refers to making sure time/date are set correctly to make battery work.
  • Randall  Trahan
    Randall Trahan May 11, 2010
    The battery for the time and date is the CMOS battery on your motherboard and not the battery to run your computer. Depending on how long you have had the battery it may just be worn out..they do after a while. If it won't charge then there is no fix except to buy a new one.
  • Dell Master
  • 4,806 Answers
Hi there
Take the battery out and start the laptop up on AC power only, set the correct date, time and time zone, shut down the PC and remove the power jack, wait about 30 seconds then power it up on AC only again, If the date and time has changed the the cmos battery has run out and needs replacing. If it keeps date and time the problem is the battery or the powerboard controller that charges the battery is defective. If the battery is getting a charge, run the battery completely out of charge, then try to charge it again.
Good luck and thanks for using Fixya!!
Posted on Feb 22, 2009
My dell inspiron 1501 does not swith ON is this due to motherboard problem
There could be problem with motherboard. But before that can check with a different battery(fully charged).
Jan 18, 2012 | Dell Inspiron 1501 Laptop
I am using a Dell Laptop and it is inspiron 1501. But its battery is not charging. I get 2 error message the adapter can not recognise... The battery can not recogise.. Something like that. The laptop gets...
try to remove the battery from the computer, after unplugging it, plug in the AC adapter without the battery and check if it will turn on. if it doesnt then 2 possible reason
1. the AC adapter is busted, you can try a known good Dell AC adapter. if its still now working with a know good AC adapter then
2. its the motherboard that needs to be replaced.
Hope this help
May 19, 2010 | Dell Inspiron 1501 Notebook
My 1501 Dell Inspiron wont turn on. The charger
The ac power jack needs to be either resoldered or replaced.
Dec 09, 2009 | Dell Inspiron 1501 Notebook
My dell inspiron 1501 won't charge when it's plugged in it works for awhile then it seem to loose contact and the battery runs down fast.
Hello
It would appear that there is a motherboard issue with this model laptop from Dell. Below is a link to the discussion thread for the problem you described. Unfortunately, there is no current solution for this issue - short of replacing the laptop.
http://en.community.dell.com/forums/p/19092498/19363647.aspx
Dec 03, 2009 | Dell Inspiron 1501 Notebook
Laptop not turning on
If you replace the main battery and it will not charge, make sure the AC adapter is working (You can test the output with a multimeter) and make sure the LED on the Adapter stays on when connected to the system. Most likely, the motherboard has failed and will need replacement
Sep 14, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501, replaced battery and power cord
Power on the laptop without the battery in the unit. If it powers on, then place the battery in and it will start to charge. Sometime the Dell laptop will not see the battery when it is replaced.
Mar 23, 2009 | Dell InspironTM 1501 Notebook
MY INSPIRON 1501 WONT START!
Do you mean to say there's No power or wont boot into Windows ?
Did you check your RAM and made sure the're properly seated ?
Try tapping on F8 while rebooting to go to Safe Mode and selecting "Last Known Good Configuration"
If you would like to perform a system test consult the Dell Support site with full instruction
Jan 04, 2009 | Dell Inspiron 1501 Notebook
Replacement battery for Dell Inspiron 1501 won't charge
If your old battery was doing the same (not charging), then is is because the charger is not charging the battery. Do you have a friend with a Dell laptop? Maybe you can use a borrowed charger to test and see if it will charge the batteries. To answer your question , no Dell does not have anything built in to prevent you from using a 3rd party battery.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 28, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Notebook Logo
316 people viewed this question
Alun Cox
