Check ice and water filter: If equipped, the Ice and Water filter in your refrigerator is responsible for removing any debris or contaminants from your water that may still remain after local water treatment. Most filters contain and are made up of carbon and fabric filter. Over time, the filter may become restricted and reduce the water flow to the ice maker, causing a symptom of little or no ice. Most manufacturers recommend replacing the filter every 6 months but local water conditions may require that you replace more frequently. Lastly a clogged drain line can cause a foul smell and get into the ice and water as we,,.
freon is oderless,the gas has no smell to it,what was wrong with the fridge?having sealed system work isn't cheap,was this a new unit?but the gas has no oder
I would suggest replaceing the overload/relay w/capacitor .
Pt # 67005560 . This piece , easily plugs onto the side of the compressor . If you replace it now , since it is already burnt , it would save you the trouble of replacing it later , when the compressor will not restart . It will happen again , due to the burning .
Yes the motor should be running and need to be replace to keep the food from spoiling, this will correct the problem however the buning smell is unknown
