Question about Hotpoint Ultima WF860 Front Load Washer
My hotpoint wt960 keeps saying test HELP - Hotpoint Ultima WF860 Front Load Washer
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
Turn the machine on whlile pressing the start and on buttons at the same time.hold until 'dOFF' appears.
Posted on Feb 25, 2009
4 Suggested Answers
  • 1294 Answers
SOURCE: hotpoint wt960 comes up with test all the time
Press the Start/Cancel button until all the console Led's Illuminate
Press both Start/Cancel and On/Off buttons together until 'd off' appears
Normal screen should return and you can select a new programme. (GL = good luck)
Posted on Mar 16, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint ultima wt960.
Try disconnecting the heater element, and see what happens.
If it still trips, then it is likely to be a problem with the motor.
Hope this helps.
Posted on Jan 05, 2010
SOURCE: iv got the hotpoint wt960 and it keeps saying test
Your machine has gone into service engineer 'test' mode as you have pushed a couple of buttons together by mistake. Go through this sequence .. Switch Off. Switch On (all LCD lights flash). Press Start/Cancel button (LCD panel now reads On). Together press the 3 ON/OFF STARTCANCEL and SPIN buttons like you would CTRL-ALT-DEL on a PC. The screen will show "DOFF". This means you are now out of test mode and back into normal operating mode. This happened to me and I was talked thru the sequence over the phone by the Hotpoint service assistant Emma - brilliant and free.
Posted on Jul 17, 2010
Hotpoint washing machine wt960 not working because fo8 code come
Hi Hitendra,
F08 is a sticking heater relay. First check that connections on pressure switch are good, Check that heater connections are good.Check the board connections.Check that pump filter is clear.
Hope this helps!
Wayne
Nov 20, 2014 | Hotpoint Washing Machines
Hotpont washing machine wt960 fo8 code m/c stop
I believe F08 Error code is for a Heater fault
Issue: During a wash cycle the programme pauses part way through.
Hotpoint wt960 keeps displaying f05
Seems that the pressure switch is jammed and so it does not cut off supply or is cutting off inlet water to the washer. Remove the lines to the pressure switch and reset, check the pressure switch diaphragm
Click pressure switch
Error codes for Hotpoint
Jan 20, 2013 | Washing Machines
Hotpoint ultima wt960. washer keeps tripping the electric out. help
Hope this helps.
Jan 05, 2010 | Washing Machines
I have a Hotpoint WT960. After each wash there is
The hole that the fabric conditioner goes through is blocked.. use a straw to blow down it and this should solve your problem. hope this helps.
Sep 20, 2009 | Hotpoint Ultima WF860 Front Load Washer
Iv got the hotpoint wt960 and it keeps saying test and will not wash anything
May 14, 2009 | Washing Machines
Hotpoint wt960 comes up with test all the time
Mar 14, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hi where is the filter for a hotpoint WT960 washing machine
Its most likely built into the tub and you don't need to access it.Under the agitator is usually the place on the tub they would put a filter
May 25, 2008 | Washing Machines
Hotpoint Ultima WF860 Front Load Washer Logo
339 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
