Question about Plumbing
Pouring concrete I need to pour a concrete floor in my garage (already up...a steel buidling actually with no door yet) but the temperatures in Kentucky are the 20's and 30's right now. Can I still pour the concrete, do I need to put an additive in the mix, and how long will it take to cure in these weather conditions? I need as much information as you can provide. Many thanks!
    New Friend:
  • 6 Answers
I live in N.W. Wisconsin and they do pour cement in 20-30 degree weather. They have the concrete supplier mix with hot water and also add calcium chloride. The ground must be thawed with no frost in it. They pour the cement and if finish it and then cover it with tarp blankets. This does add cost to the project and if you can wait for warmer weather I highly recommend you do.
Hope this helps.
Bob
Posted on Apr 02, 2015
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Thanks for the information.
Posted on Oct 07, 2016
  • 456 Answers
In Iowa they can pour concrete when itmis 32deg., however they tend to button up the basement and put in temp. Heat to help finish and cure the concrete
Posted on Jan 30, 2015
    Scholar:
  • 104 Answers
This is your own house, I would wait until the temps are above freezing. 32Deg. Maybe 30 is OK,. I think anti frost addiditives are not that effective and weaken the concrete. Pouring at any temp above freezing is good, the concrete cures slowly giving yu time to finish it to your liking. Concrete cures in 28 Days.
If the temp goes a bit below freezing say over night, no problem as concrete makes heat as it cures. You can also cover with a plastic sheet. You do not want prolonged below freezing temps on the concrete is the bottom line. Just wait a bit to be sure and there are no decisions to make
good luck
Posted on Mar 19, 2009
Why is water coming up from my concrete floor?
ground saturation-if no water lines run through there
Jul 17, 2017 | Washing Machines
How many cubic meters of concrete will it take to pour a garage fool 336 sq feet 6 inches deep
Figure 1 90 lb. bag per square ft., 6" deep.
Don't forget sand to grade and rebar to reinforce.
You probably won't find enough guys to mix all that concrete, so you'd really be better off hiring a concrete truck.
Tip: It's best to over estimate a little so you won't be caught short.
Mar 01, 2015 | Building Materials
Yards of concrete do I need to pour a step 5'x 20" x 48"
If you poured these dimensions as a solid concrete stairs, it comes out to 1 and 1/4 yds. (note that anytime you order concrete to always figure in at least 10-15% more). So 1 and 1/2 yds "should" be adequate,, and ordering 2 yds would be 100% worry-free.
But most steps/staircases are not poured "solid". Usually you have solid walls (approx 8" to 12" thick), with a compacted mound in the main section of the formed area which still would allow approx 6" minimum thickness below the treads/risers at their inside edge.
The top platform slab should also be 6" thickness.
In other words, pouring them completely solid is overkill and not necessary. More weight = more prone to settle without proper foundation or wingwalls.
It\'s important to have a solid footing/foundation for the steps, that extends below the grade line (depth dependent on what area of the country you\'re in and the typical "frost line").
It may also be advisable to use short rebar "dowels" drilled into the existing wall the steps will be against, to prevent settling or shifting.
More specifics and info is needed for a more accurate answer.
Oct 16, 2014 | Building Materials
Water pouring out of the ice make
If the water is pouring out from underneath, and you have a drain pump, check in back of the unit to see if the water tube has come away from the drain pump, therefore dumping the drain water on the floor. It happened to our unit because the unit moves a bit each time the door is opened or forcefully closed. Hope that helps!
Apr 20, 2014 | U-Line Icemaker
I painted a section of my garage floor with a cup of paint 1/4c oil base acrylic mixed with 3/4 c water base latex...will it ever dry thoroughly? it is drying slowly and is really sticky. will I just have...
did you ever try to mix water with oil? what was the result? are you sure that you can cross the street without adult holding your hand?
unfortunately you need to remove all that paint, just drop few shovels of fine sand over, and scrape it... sand will adhere to the tp surface of the pain and will allow you to scrape it. after you scrape it off, use any degreaser or similar product to wash reminder off, leave it for few weeks to dry through and then in small patch try if it would accept latex pain, roll it very, very thinly and leave overnight, if it is dry (solid dry) after 24hrs and do not peel off, you can then use this paint on the rest of your garage floor.
now, i would advice strongly against painting garage floor with any paint except concrete paint (they are usually water based with strongly alcalic ph), and after that use concrete seal. this should give you long lasting surface, sealed from oils, dust, water and whatever contaminant you can imagine in the garage.
Sep 12, 2013 | Sherwin-Williams Best Look Latex Garage...
How do you fix a dip and crack in garage concrete? Our garage has a crack and is dipping down.
The highway department fixes this by drilling a hole and then pumping concrete under the concrete until it lifts up.
I suggest you contact local concrete company to see who does this type of pumping. I've seen them fix driveways.
Don't know how much it costs.
Oct 08, 2010 | Garden
Automatic Garage door reverses and automatically opens after closing
I can't believe it! My opener works fine a 10 degrees and above but below 10 degrees it would go down a little ways stop and go back with the light flashing. I checked the electric eye and found it would go out of alignment when the temp drop. Who knew!
I made the adjustment and it now works fine.
Jan 15, 2008 | Sears Craftsman LiftMaster Chamberlain...
Plumbing Logo
801 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
