Question about GE (PSS26MSRSS) Side by Side Refrigerator
  • jcbc390 Feb 24, 2009
    Drinking water line freezes every other day. must use hair dryer around door to defrost line. this is a GE side by side refrigerator about 2 years old
  • ghoeffner Feb 24, 2009
    I have the same issue. My GE side by side will make ice but now will not dispense water. I don't want to call a repair person. I believe the line is frozen, but how do I find this out and how do I "un freeze" it?
  • 74 Answers
Replacement door is the best solution as moisture has got into the foam of the door causing the water pipe to freeze
Posted on Feb 26, 2009
Why am I getting water but its not making ice?
this model has the double valve. one for drinking water and second to fill ice maker to freeze
and produce ice. Possible one coil for ice maker is not operating.
Check also supply tube to ice maker It is possible frozen and plugged.
Jun 23, 2014 | GE GSL22JFPBS Side by Side Refrigerator
I have a GE Refigerator (PSF26MGWA WW). the ice maker will not fill up with water. The tray heats up and the sweeper works. The fill solenoid for the ice maker does not work properly.The drinking water...
the ice maker is in control of the valve, however, the valve is one assembly containing the valve for the water dispenser and the one for the ice maker, take your model to the appliance parts store and get you a water valve assembly for your model number.
Dec 23, 2017 | GE Refrigerators
Ge refrigerator water low, Drinking wate.
make sure line is not kinked behind the frig, maybe change filter if it has one. then change water valve if that dosent solve problem
Apr 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
In my GE Performance refrigerator side-by-side Ice is being made, but no water is dispensing. The GE Smartfilter is atleast 5 yrs old (I never used/never changed) because we always bought water from...
The water that goes to the door actually is routed through the hinge on the freezer door. Take a look and see if you can't find where the tube comes out and goes into the water dispenser. I bet it has come loose and is rerouting the water down the side of the fridge and onto the floor; hence the puddle.
Also, just because you don't drink the water doesn't mean you don't drink the water! If you use ice from the ice dispenser then you ARE drinking the water. The water that feeds the ice trays comes through the filter, so you might consider changing it every 6 months rather you use the water dispenser or not.
Hope this helps, I have one too and its causing a different set of problems...
May 11, 2009 | GE Profile Performance 25.2 cu. ft....
Ge Profile ice maker not working
you either have a bad water valve, which it is sticking open or B. the ice maker is not shutting the valve off.
Apr 12, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice Maker
well ur refrigretor is;nt producing enough gas to produce ice make sure u hire some expert who can examin and solve it.
Mar 18, 2009 | Amana ARSE66MB Side by Side Refrigerator
common problem the water line inside the freezer door is frolzen up . to fix remove everthing from the freezer door , turn off freezer . open freezer door and put a blanket over the opening to the freezer leaveing the door to room temp for an hour or so to defrost . check if defrosted . remove blanket close door . this will happen with ge , try seyying the freezer control on the next lower number (warmer)
Jan 14, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker not makeing ice. It slowed over the past few days and now has stopped. Drinking water dispenser still works but freezes up easily.
Normal ice making problem water flow is low ,cheak the machine waterpipe in let line blockage clean the pipe line
Jun 15, 2008 | GE Refrigerators
Ice Maker Problem
my ice maker stopped making ice. Green light is on. Drinking water is ok
Feb 17, 2008 | GE GSS20IEP Side by Side Refrigerator
Water button not work
You can check the site again on how I fixed the same problem. GE also has a recall on many refg. with this same problem. Probly a frozen line inside dr.Quickest way to isolate is to disconnect line at were it enters bottom of dr. and press dispenser tab. If you have water to this point it is about 99% sure a freeze in dr. No water means probly selenoid or the switch or something else. Ice and water line do not feed off same line , ice will dispense even if water does not.
Dec 24, 2007 | GE GSH25JFR Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
67 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
