Question about Whirlpool LER4634J Electric Dryer
Power working but won't stay on
Power button turns dryer on as I press it but as soon as I stop pressing, it will turn off.
  • kingkat3413 Feb 27, 2009
    I tried a new switch, and had the same result. I've also popped the breakers to see if that had any impact.
    Any more suggestions?
    Thanks for the suggestion!!!
  • 52 Answers
Sounds like u have a faulty start button. the switch isn't staying closed...
Posted on Feb 22, 2009
  • Janelle Tablada Feb 27, 2009
    There is probably a short in the circuit... You'd have to check all the wiring and make sure there's not one touching the metal housing or another wire...
(2007) Frigidaire Affinity Gas Dryer won't shut off
mybe the star button stay stuck and the dryer tinks some one is puching the star button and it will continio to run. try to open the door and it will stop and then clouse the door if the dryer star whitout pushing the star then you now the star switch is stuck. goo lock
Feb 21, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Does not respond to button press and won"t turn
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 31, 2011 | Kenmore Elite HE4 Electric Dryer
I have a miele S712 (2 yrs old worked fine yesterday) - I had been doing some diy work inside and had the vac on just to reduce some of the dust in the air - after a while the vacuum fizzled out. I...
you have got dust in the micro switch and it is not latching on, if you look at this and clean it, that will solve your problem, however blowing the motir has probably wrecked the motor bearings.
Jun 02, 2011 | Miele Vacuums
Dryer wont stay turned on. As soon a you let go of the start button it stops
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 04, 2010 | Kenmore 62602 Electric Dryer
How reprogram my universal rca remote control
hold the tv button down and keep it down and then press and hold the power button down and hold them both until the power button stays red then let go of both buttons then keep pressing the power button until the tv turns off and as soon as it turns off press the stop button and it should work.
Aug 31, 2009 | RCA RCR815 Remote Control
Dryer will not turn on and stay on.
Hello , bad news here , when you press the start button it sends power to the motor and then a clutch sets in and closes a set of points that then sends power to your element -if the clutch does not engage the motor will not continue to run or send power to the element and that is what is happening to your dryer.
not an easy fix at all , the clutch is bad and its located inside the motor and the entire motor would need replaced to repair this problem. they range from 80-100 dollars and would take about 1-2 hours to change.
let me know if you have any other questions.
Phil
Jan 12, 2009 | Dryers
I have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray...
same equql problem....?????
Can you help?
i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. Can you help? thanks thanks
Dec 21, 2008 | Televison & Video
Dvd code
Try preforming an automatic code search:
1) Make sure the device is on.
2) Hold down the DVD button and the power button simultaneously until the red light stays on solid.
3) Then press the power button - it will flash one time - keep pressing slowly, letting it flash until the device turns off.
4) As soon as the device turns off, press the stop button
If your the remote does not power the device off after cycling through all the codes - You will know this when the power button blinks and deluminates - then your "universal" remote will not work with the DVD player.
The best of luck to you!
Sep 18, 2008 | Televison & Video
Whirlpool LER4634J Electric Dryer Logo
80 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
