Question about Fantom Vacums Cyclone XT Upright Vacuum
Brush wont spin
The suction is good but the brush refuses to turn on
  • 2 more comments
  • Fast Fred Apr 21, 2009
    The belt is not the problem as they are made to last a lifetime in the Fantum Cyclone XT. The problem is probably in the circuit board in the base of the unit. You can take the cover off to gain access by popping the headlight clear plastic covers off. You will find a Phillips single screw under each one. Unscrew both and gently take the lid off. To the right you will see the circuit board. Make sure your vacuum is unplugged. You can try pushing the reset button in and putting your cover back on to see if that does the trick. Sometimes it does but not in my case as the brush will run for maybe 10-15 seconds and then shut down. Once shutting the switch and turning it back on it will run for about another 10-15 seconds once again and shut down. My guess is that our Cyclone XT needs a new circuit board but I have no idea where to purchase one and if it would be cost prohibitive.
  • taqdima May 14, 2009
    what does the reset button look like
  • Anonymous Mar 16, 2014
    brushes are spinning and no blockage still no suction
  • Anonymous Mar 26, 2014
    no suction
  • 76 Answers
Sound like it has a bad belt . I would check it and replace if bad .
Posted on Feb 23, 2009
There is no suction on spin brush
-Broken belt or some thing stuck inside. Check it out and remove or replace.
Good luck
mai
Apr 25, 2015 | Euro-Pro NV22 Shark Navigator Bagless...
Riccar 8995 no suction
If it's been over a year since you've replaced the belt that is the first place to start. Stretch belts lose elasticity and will still turn the brush roll but when the brush roll is lowered to the carpet it may not turn fast enough to pick up properly. If you have good suction at the end of the hose check to make sure there is not an obstruction in the tube where the hose goes into the bottom of the vacuum to the brush roll. Make sure your filters are replaced at least once per year and the bag is not full or has a lot of fine powder dust in it which can clog the bag.
Jun 13, 2014 | Riccar 8955 Upright Vacuum
Brush wont spin
Check the filter on the front of the machine lower left. The brush is powered by the exhaust of the suction motor with a small turbine.
This filter reduces the air flow and can cause the machine to not turn the brush.
Jan 29, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Hi my dc07 has lost suction on the roller, but not on the hose there are no blockages cyclone still strong any ideas thanks
Are the brushes in the base of the vacuum spinning? You wont get much suction from the base of the hoover if the brush bar isn't working?
Lie the vacuum on it's side and turn it on. If the brushes aren't spinning then your belt has either come off or broken. I suspect this is the cause of your problem.
Nov 04, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Brush doesn't spin. no suction felt at brush
Check that the brush has not become fouled with string, etc. If it still doesn't work try the following.
Some Dyson's have a switch for the brush on the front of the handle. If yours does, please make sure its on. This may seem obvious but many vacuum owners who have this switch don't know it is there until it is turned off and the brush doesn't function.
You didn't say if the hose has suction. If there is no suction in the machine, I would check the usual (empty dirt, clean filters, check for clogs). Hope this helps and good luck!
Mar 13, 2010 | Dyson DC14 All floors Bagless Upright...
Brush spin,good suction at hose, no suction at
Air passage from back of brush head, through the joint, and up to bag, may be blocked.
Jul 11, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
The brush wont turn
Make sure that the carpet selector is on carpet setting not bare floor. It only spins on carpet setting. If carpet setting is engaged and still doesn't work you need a new clutch assembly.
Oct 12, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Hoover sttem cleaner
The brushes spin by virtue of an air driven turbine. This turbine uses a little of the motor suction to turn a large fan which turns the brushes. If you look behind the clear glass window on the front right hand side of the machine, you will see a screen which acts as a filter to keep debris out of the turbine. If this screen becomes clogged, it will affect the flow of air to the turbine and the brushes will slow down or stop all togeather.
Also, if the lid of the recovery tank is not on correctly, the suction will be compromised and the brushes will not turn and the machine will not pick up water off the carpet.
Feb 04, 2008 | Hoover V1 SteamVac SpinScrub Vacuum
Fantom Vacums Cyclone XT Upright Vacuum Logo
439 people viewed this question
Top Fantom Vacums Vacuums Experts
Richard Agent
Charles T Nevin
Charles T Nevin
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
