Question about Kenmore Refrigerators
Need to replace ice actuator on fridge
Fridge model is Kenmore 25351699100. I need to figure out how to install a new ice actuator, Sears part 5304421635 I BROKE THE ACTUATOR ( PLASTIC TOB OR ARM ) ON THE ICE DISPENSER. SEARS MOD 25351692100 SIDE BY SIDE. WHERE CAN I GET THE PART ?
  • 58 Answers
SOURCE: Kenmore Refrig with Filters water and ice dispenser- water is dripping when not in use, no flow when activated
valve needs to be replaced. it is located in the back, just follow the water line to it. to shut off water there is eaither a shutt off behind ref or in the basement. again try to fallow the water line
Posted on Oct 31, 2007
SOURCE: Ice dispenser in door- won't deliver whole ice
Dear Sir,
I have purchased a whirlpool refrigerator on dt.05.11.2006 from M/S.Ganesh Enterprises, Angul bearing Invoice No. 335. last few days the main door of the refrigerator is not working properly. A part is broken from the door(clamp). Inspite of repeated contact and reminder the dealer have not taken any action till today and telling that the parts is not available.
I am very much dissatisfied with the service of the dealer. Therefore I am request you Sir, kindly look into the matter and necessary action in this regard please be taken.
Thanking You,
Yours faithfully,
R.Agarwalla,
06764-232367, 234667
Posted on Jul 15, 2008
  • 172 Answers
SOURCE: ice dispenser broke
Please send me your model number and I will try to find the piece that holds the pin that holds the flap in place. My phone is (865)945-3808, or email is mca0824@aol.com
Michael Anderson (Owner)
Anderson Appliance Parts and Service
Posted on Sep 24, 2008
docjohn174
  • 943 Answers
SOURCE: Kenmore/Fridgedaire refrigerator ice actuator replacement
hi thanks for the question are you talking about the arm to stop the ice making if so you can just put back in clips on the front of ice maker and at back thanks the appliance doc
Posted on Sep 26, 2008
  • 14 Answers
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
Posted on Apr 04, 2009
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
Stale ice after a new water coil is installed
The water became stale inside copper lines feeding ice maker most likely. Dump your ice for a few times until this clears you should have ask for some money back for copper poison, (joking) Thanks,Sea Breeze
Feb 23, 2012 | Kenmore Refrigerators
Water drips from the freezer into the fridge.Upon disassemble, there is ice buildup under the coils. kenmore coldspot model #71184101
The defrost timer or the defrost heater element has probably failed. Go to the link below and enter your exact model number; you should find a line-drawing illustration and parts list for your fridge that you can use to locate these items and normally also determine how to remove or install them:
Sears PartsDirect
Apr 08, 2011 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore side-by-side not dispensing ice or water, the ice maker has been replaced, no water going into the tray. I cannot locate the water filter, does this model have one?
Don't know what is the model number of your fridge. 1.Need check electric water valve under the fridge. If that fridge made by GE (Kenmore just a Sears brand name and they use several others manufacturers for refrigeration), usually it's a frozen plastic water supply line inside freezer door. You could unplug fridge for 24 hours (you have to put food from freezer to other freezer).
Jun 29, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
Alarm no longer sounds when fridge door is open
Chances are that you will have to replace the buzzer. That part is available at Sears Direct. J
May 28, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Puddles of water in the fridge
OK that sounds like Ice may be blocking the defrost condensate drain. I will need your model number to help me to identify your model better but can leave you with some information about water leaking inside the freezer or fresh food compartment. Sears use a model number found around your door frame and looks like this for example 312.56989 Be right back with some links, Thanks Sea Breeze
Feb 19, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Ice maker issues - what to do next?
I have not found Kenmore to do the best with the icemakers; however, you want to make sure that the lever on the side was replaced properly. They have a slot that they need to go into. The other thing that is important is to see if the motor is running on the ice maker. It could be at fault, but if that is the case those units usually are better off replaced as a whole, which runs around $200. You will probably get them cheaper through an appliance dealor rather than going through Sears and there probably is one in your yellow page section of your phone book...hope this helps.
Oct 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Purchased a new kenmore bottom freezer refrigerator They do not supply any ice cube trays or buckets any more Where can I purchase the proper items for my freezer The salesman at Sears suggested the dollar...
You can buy whatever you want from Sears Parts Center either online, or at a service center. If your fridge came with an icemaker installed then you are supposed to have an ice bucket in the fridge from the factory.
Sep 13, 2009 | Refrigerators
I have a kenmore refrigerator model 36369262991. I have water accumulating on my top shelf. It drips from the thermostat control panel. what is wrong?
I had a similar problem on a Whirlpool Fridge. In fact, there is a good possibility that your Kenmore is made my Whirlpool. As you probably know, Sears doesn't make appliances, but contracts with well-known appliance makers to manufacture kenmore-branded products.
If your fridge is an auto-defrost model, whenever it auto-defrosts, water from the melted ice collects in a tray behind the freezer, and drains into an evaporation tray at the bottom of the fridge through a drain tube. Over a period of time, the drain tube can become clogged, and instead of draining out of the freezer, the water overflows into the fridge. The clue is that the problem is intermittent -- the dripping stops between defrost cycles.
The fix is to remove the liner panels from the freezer, melt and sponge out any collected ice, clear ice from the drain with hot water, and clear any gunk from the drain tube with compresssed air or a flexible "snake." I used 1/8" pvc tubing as a snake.
It isn't hard to do, but if you are nervous about disassembling parts of your fridge, you will need to get a pro to do it.
Jun 29, 2009 | Kenmore Refrigerators
Refrigerators Logo
180 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
