Question about Nikon AF 24-50mm f/3.3-4.5D Zoom-Nikkor Lens
For Nikon AF 24-50mm f/3.3-4.5D Zoom-Nikkor Lens I need instruction book. Specifically, there are dots side by side marking the apeture selected, left one yellow, right one green, what one is correct and when? Second, upper right of the apeture ring there is a pull down lever with with a white dot on it and and a corresponding orange dot.What does this do and how does it work? Thank you Rick
  • richard1571 Feb 25, 2009
    Thank you very much for taking the time to answer my question.
    Kindest regards- Rick
    Scholar:
  • 48 Answers
The green mark is the index for the aperture setting at 24mm, the yellow mark is the index at 50mm. These really only matter if you are setting the exposure manually and using an external meter. The green mark is the primary mark -- as you turn the ring you will notice that it lines up with a number at every clickstop, while the yellow one is a bit off.
The pull down lever you ask about is the aperture lock. Autofocus film cameras and all digital cameras expect the lens to be set at smallest aperture (highest number). They will give an FEE error if it is not set correctly. When you turn the aperture ring to smallest aperture you will be able to slide the white dot into position next to the orange mark, and that will lock the aperture ring so that it is not accidentally tgurned while using or changing the lens.
Posted on Feb 25, 2009
Sticky zoom ring on a Nikkor 18-55 AF-S Zoom. The zoom gets jerky at the 18-24 mark. I think it needs some lube but I don't know where to put it?
You would have to disassemble the lens barrel to get to the zoom sliders, and lubrication is not likely the problem anyway. The zoom mechanism uses nylon bushings sliding in a groove, and zoom problems are usually due to wearing/cracking of those bushings.
If it's still in warranty, send it in. Otherwise, the cost of repair probably exceeds the value of the lens. Sorry.
Aug 05, 2013 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED...
Autofocus on Nikkor 18-55mm lens doesn't work
probably you have problem with the focus motor, i ever have same problem and need to replaced the focus motor.
Jun 08, 2013 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Where is the reset switch of nikon d40 camera ?, how to reset camera?
There're actually two buttons. Press and hold the Info and zoom-in buttons (both marked with a green dot) for more than two seconds.
Full details are in the "Two-Button Reset" section of the manual (page 38 in my copy). If you need a manual you may download a copy from here.
Jan 08, 2013 | Nikon D60 + AF-S DX VR NIKKOR 18-55 mm...
What is 55-200mm?
That's the focal range of a zoom lens. Unlike a single focal-length lens (or a "prime" lens) a zoom lens lets you adjust the focal range. "55-200mm" specifies the lens's focal range from 55mm at the low end to 200mm at the long end.
You can read a general description of zoom lenses at
http://en.wikipedia.org/wiki/Zoom_lens
Nikon current has two different 55-200mm lenses:
http://www.nikonusa.com/Nikon-Products/Product/Camera-Lenses/
2156/AF-S-DX-Zoom-NIKKOR-55-200mm-f%252F4-5.6G-ED.html
and
If you're asking about the L110, it has a permanently-affixed lens and will not use either of the above lenses.
Aug 11, 2011 | Nikon Coolpix L110 Digital Camera
I have a Nikon D3100 and want to buy a zoom lens 70-300.Please help I am confused is a Nikon AF Zoom-Nikkor 70-300mm f/4-5.6G compatible? And is it automatic focus?
That lens will work with the D3100, except for the autofocusing. In order to autofocus with the D3100, you need AF-S lenses, such as the AF-S VR Zoom-NIKKOR 70-300mm f/4.5-5.6G IF-ED or the
AF-S DX NIKKOR 55-300mm f/4.5-5.6G ED VR.
May 22, 2011 | Nikon Cameras
Hi. Is the Nikon AF Nikkor 20-35mm 1:2.8D made for Nikon's digital cameras? Is it compatible with their whole line or just some? Thanks
No. The lens will work with every Nikon film or digital SLR made in the past three decades or so, though of course the autofocus won't work on older cameras that don't support AF.
Dec 01, 2010 | Nikon AF 20-35mm f/2.8D Zoom-Nikkor Lens
Replacement rubber zoom band nikkor 17-55 2.8
yes...check with Nikon or I have seen replacement rings on ebay even...I'd check with nikon or a local nikon repair facility for parts..
Jan 25, 2010 | Nikon Zoom-Nikkor 17-55mm f/2.8G ED-IF...
Nikon 18-55 zoom lens doesn't autofocus
You might like to check if the A/M slider switch on the lens by the Nikon label is set to A.
It sometimes gets moved accidently.
Set to M the lens will not autofocus.
May 24, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Lens has locked in place and I can't move it
Your motor may have gone bad. Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
Here is the facebook page link, it has everything you need to send it in.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
May 18, 2009 | Nikon Zoom-Nikkor 70-300mm f/4.5-5.6G...
Nikon AF 24-50mm f/3.3-4.5D Zoom-Nikkor Lens Logo
214 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
