Question about InFocus LP70+ Multimedia Projector
LP530 green Iamge
I have an infocus lp530 says it is 1080i capable I hook it up to a comcast hd cable box the image on the screen is green can see all images just has a green tint to entire picture. I used 3 different connectors m1-component (one with male end one with female) ends, m1vga-vgacomponent none worked. I used them all on my lp70+ and they all worked fine. can someone tell me what could possibly be wrong.
  • 2,237 Answers
Make sure the resolution on the projector matches the input resolution.
Posted on Sep 03, 2009
When i hook up my lp530 to my computer all it says is no signal found what do i need to do to make this projector work
there should some function key and Fn button combination on the pc that directs the screen image to the external vga connector. check in the pc manual
Jul 08, 2011 | InFocus LP 530 Multimedia Projector
My image appears green on the screen
if the image is like this with out any cables hooed to it it is likely the light tunnel and will have to be fixed by a tech. If it happens with the cable hooked up, try new cables.
Nov 13, 2010 | InFocus ASK Proxima M2+ Multimedia...
Just want to know if i can get hd channels with a regular comcast motorola dct700 box, if so how? Also, what DVD player should I buy with this, as well as type of cables. TV just given to me, no remote,...
No HD channels on a DCT700, you have to have a HD capable box from comcast. Usually $8.95 a month for box rental. Don't know a lot about DVD players. If you get a comcast HD box, and have an HD TV, you should use an HDMI cable for best picture. Second choice is component cables. Those are the red, white and yellow or red, white yellow, blue and green cables.
Jan 03, 2010 | Haier HLH32ATBB 32 in. LCD HDTV
Hookup the comcast hd box to my new lcd tv?
You can use either component (Red/Green/Blue video and red/white audio) or HDMI cables to connect the Comcast HD box to your TV. Most times you can get these cables for free at the Comcast front counter.
Sep 26, 2009 | Onkyo TX-SR606 Receiver
Green tinted people
The only time I have had issues like this was because of the Component Cables not being in the right position (the Red and Blue connections switched), or a bad Component Cable where the Blue Connection is not receiving a signal. Swap out the cable to be sure and double check that it is properly installed. Green to Green, Red to Red , Blue to Blue.
Hope this helps,
skyassoc
Jul 18, 2009 | Samsung HLN5065W 50" Rear Projection...
Significant volume decrease when using Comcast cable box
This low audio problem happened to me suddenly yesterday. I powered off over night - no change. I plugged the A/V cables into a second TV - no change. I called Comcast - problem solved.
Tap these buttons on the remote;
May 16, 2009 | Panasonic Viera TC-L37X1 37 in. LCD HDTV
LP 130 PROJECTOR SCREEN IS GREEN WHEN I HOOK UP DVD WITH COMPONE
the cable might be the problem. swap out with another cable. other than that, make sure that the correct input is selected and the resolution matches.
Mar 11, 2009 | InFocus LP 130 Multimedia Projector
Green Line in Philips 42TA648BX/37 42" LCD
Just a guess. Try to get hold of a different cable box & see if you have the same problem. If so, problem is with cable box.
Jan 15, 2009 | Televison & Video
No Non-Hd sound
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Jun 19, 2008 | Insignia 26 in. LCD Flat-Panel HDTV
Infocus lp530
I called InFocus and was walked through several steps to determine if it was a bad cable or an internal problem. My InFocus unit would power up and stay powered up with no problem until I connected it to the computer using the analog computer cable (blue connectors). They had me try it with a different computer and then with the S-Video cable. Each time the InFocus unit powered down within seconds of connecting to the computer. The problem is internal. The unit had to be sent to InFocus for repair ($180). If the unit works with the S-Video cable then your problem is a bad cable.
Jan 08, 2008 | InFocus LP70+ Multimedia Projector
InFocus LP70+ Multimedia Projector Logo
287 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
