Whirlpool GU2400XTP Built-in Dishwasher Logo
Posted on Feb 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dish washer won't wash dishes.
I have a Whirpool built-in dishwasher. The water barely comes out.
Anonymous
Level 3:
  • Whirlpool Master 3,361 Answers
  • Posted on Feb 22, 2009
Anonymous
Whirlpool Master
Level 3:
Answers
3361
Questions
Helped
1029261
Points
10654
Remove the screen below the spray arm and clean the sump.
Replace the impeller kit on the motor shaft.
Clean debris out of the holes in the spray arm.
Even when we rinse dishes before we put them in the dishwasher, they come out pretty filthy still. Is there something we can do?
my mother suggested this to me.
run the hot water tap in the sink that the dishwasher taps into .
So that the water going into the dish washer is going to be hot !
the other thing was that the plastic coated detergent block thing may need a longer wash cycle setting so that the plastic covering dissolves completely to clean the dishes more .
Water hardness could be an issue .
dish washer may have a slat reservoir and a water hardness setting . Check the dish washer manual for water ph level adjustments.
Aug 25, 2018 • Dishwashers
Whirpool dish washer has water coming out the air gap when flushing out of dish washer
I think you have a clogged line. the drain from the dishwasher goes up to the air gap and also into your sink drain pipe.
hope this helps
It lets a little "soaking"
your belt went bad in dish washer replace belt. dont keep runing that like that you will burn the moter up in dish washer
Water does not go into the dish washer during the wash cyle. This is a new problem on an existing Magic chef dish washer.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Dish washer not filling
I had the same problem. It was a clogged water inlet valve. Packed with sediment. Accessible from the bottom if you have the right tools. Just clean out and replace. Or the valve could be bad.
GE PDW9700 - The dishes do not get cleaned
Same as above problem: I have had this dishwasher for less than 4 years and the dishes as of about 2 years ago stopped getting cleaned. I use the recommended dish liquid and rinse and lightly clean the dishes before I put them in.
What a piece of junk!! gs
Model # dwu7702aae has heat delay light coming on during cycle. Why?
Heater is used to both heat water during clean cycle and dry dishes after wash cycle. Most washers have either a separate switch for Heat or Dry for optional use, or some have the water heat and dish dry options built into cycle set options.
You can save money by turning off the Dish Dry option since it is a very in-efficient way to dry dishes. Instead, open the wishwasher door after washing cycle completes, just enough so fresh air can get into, and humid air can escape, dishwasher.
Water Heat option is only needed for dried food on dishes, and is never needed if dishes are either rised off before putting them in the dishwasher, or rinsed off inside the dishwaser with a Rinse cycle, if they are to stand for a time waiting for a full dishwasher for wash.
Dish washer frigerdaire, some dishes do not come clean
ck water level, a few min into wash cycle open door . make sure your water level is just below heater coil
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
