Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
99 HD FATBOY LEFT BLINKER
BLINKER DOSE NOT WORK ON THE LEFT SIDE BUT WILL WORK WHEN THE FLASHER IS ON
  • 25 Answers
Likely to be a turn module.But check power input to module from switch block
Posted on May 23, 2010
Wheres the turn signal relay located on the 99 windstar
If your other blinkers work ,it's not the flasher . Probably a wring problem or the bulb . Find a wiring diagram at www.bbbind.com an trouble shoot the circuit . Look at you tube , there are a lot of basic electric trouble shooting videos , an a few on reading wiring diagrams .
Nov 13, 2015 | Cars & Trucks
I HAVE A 1997 HONDA SHADOW 600 FRONT BLINKERS WORK FINE RIGHT REAR WORKS FINE BUT LEFT REAR WILL NOT BLINK LEFT FRONT DOSE BUT FAST I CHANGED BULB IN LEFT REAR DID NOT HELP IS IT A BAD FLASHER
If you have changed the blinkers over to LED lights , you need to put diodes on the wires to stop the fast flash. Honda turn signals Have to grounded to the green ground wires in the harness. You can not ground them to the frame or other wires or the flasher system will not work correctly. Double check that all the wires are connected to the harness correctly (They are color coded). Blue with white band is the same as blue with white stripe. Orange with white band is the same as orange with white stripe. If you have crossed the wires on the front turn signals you may be powering the rear turnsignal with the running light. The running light is the dimmer half of the bulb. The turn signal/flashing light is the brighter side of the bulb. Inspect your wiring carefully.
Mar 18, 2011 | 2004 Honda VT 600 CD Shadow
The blinker in my 99 dodge durango works sometimes. whats wrong with it?
Hello
More than likely the combination flasher relay is defective. You will need to replace the electronic combination flasher relay, the Combination flasher which is just to the left of the steering column under the dash.
Nov 16, 2010 | 2000 Dodge Durango
Have 2001 Cherokee, for some time the blinker will turn on but not blink. If you moved blinker handle up and down they would work, Now it wont work at all. Dont know how to find fuse
likely your flasher unit was failing or you had a bulb out somewhere. Flasher should be on right side of steering column under dash yours could be a "combination flasher" Older models had flashers on fuse box under dash on left side.
Mar 10, 2009 | 2001 Jeep Cherokee
99 Rodeo Right turn signal makes brake lights blink
TURN SIGNALS WILL FEED BACK THROUGH THE TURN SIGNAL SWITCH.THEY ARE INDEPENDENT OUT SIDE ON THE CAR BUT NOT IN THE SIGNAL SWITCH.REPLACE THE SIGNAL SWITCH
Jan 02, 2009 | 1999 Isuzu Rodeo
Blinkers not working
Did you check the bulbs? If one bulb is burned out, the blinkers won't word on that side. You could have one bulb burned out on each side. Start the car, put left signal on. Check front and back lights. Is one light on but not blinking? If that's the case, the light that's not on at all is burned out and has broken the circuit so the good light stays on and won't blink. Check the other side. You also have a 'flasher' , actually 2. One for emergency flashers, one for the turn signals. It could be that the turn signal flasher is shot. You just have to unplug it to remove. It's probably located near the fuses. good luck countrycurt0
Aug 10, 2008 | 1999 Jeep Grand Cherokee
Lands Phones Logo
215 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
