Question about Samsung Computers & Internet
My Samsung R40 will not charge. The cable/charger
My Samsung R40 will not charge. The cable/charger is new and works fine, as I can occasionally charge it by using something heavy to jam it in the right way. I kno what the problem is but I dont know what it is actually called, the socket you put the charger cable into is broken, but without knowing what it is I cant replace it.
    President:
  • 1,223 Answers
It is called the AC power Wall Socket is that what u r talking about do u think u can replace it i think u should call some elec guy to fix it like maintenance guy it has nothing to do with ur notebook its just the pins inside the socket got loose and ur plug is unable to stand in there am i right pls vote if u find me helpful
Posted on Feb 23, 2009
Samsung galaxy s2 will not charge
Could be a battery problem, ut is usually a problem with the charge cable or connector. Try a different charge cable, they are usually Micro USB connectors, and check if the power (MaH) Matches what your phone needs. Otherwise you might need to repair the port. Try this.
http://www.youtube.com/watch?v=q4e-5xkhvHA
Jul 22, 2014 | Samsung Galaxy S Ii 2 Sgh-t989 16gb...
P5113 not charging properly
There are a couple of common problems that can cause bad charging:
  1. Bad charging cable - try a new cable
  2. Bad charger - try a new charger, or try plugging it into a PC USB port overnight with the PC turned on
  3. Charger is not the right charger for your tablet - Samsung devices are known for being picky about what charger you use. If you don't use the original charger that came with the device, or a Samsung charger made for your specific tablet, you will have trouble.
  4. A bad/broken charging port on the tablet - this is not something you can fix yourself. You would likely have to return it to Samsung for repair, or find a local repair shop.
Jan 07, 2014 | Samsung Galaxy Tab 2
Hi i have a Samsung np-r40 and it dosnt charge or get any lights working, it works fine with a full battery so comp is fine but cant get it to charge or come on useing the mains ive brought a newcharger...
Something, a component, in the laptop may have fried the charger. I don't know for sure. You would have to trace the circuit with a multimeter to locate the bad power component.
Jan 12, 2013 | Computers & Internet
Galaxy Note slow charge. Holds battery well though.
try this ..get a qtip and dip in 99% rubbing alcohol. not too wet. just damp. clean contacts on the charger port. use a magnifying glass and light to check if its clean. let it dry for 20 mins. it will also help if you have airplane mode on but its optional. use oem charger and cable or ipad charger works fine with samsung cable. hope it helps
Jun 10, 2017 | Samsung SGH-i717 Galaxy Note HD LTE 16GB...
Samsung R519-53S not charging
Please remove battery and connect charger and turn on computer. If on adapter working fine, now connect battery without removing charger , and check charging.
May 09, 2012 | Samsung R519-53S Notebook
What type of battery is the best and recommended for Casio QV-R40
The Camera would work with 4 AA batteries of almost any type. However a high capacity rechargeable battery would be more economical in the long run and you need a charger too. NiMh batteries with capacities of between 1200mah and 2900mah would be fine. The Hybrio type comes ready-charged and retains its charge best on the shelf. Therefore I would recommend e.g.
Four, Uniross Hybrio AA 2100mah rechargeable batteries
Dec 12, 2010 | Casio QV-R40 Digital Camera
My Phone not charge by charger but the data cable prefectly working may know that what is the problem in my phone?
If it charges from the data cable connection, then the problem may be in the charger. If you have a car charger, try that first. If it charges from the car charger (or if you can find a friend with the same model, and it charges from their charger) then the phone is fine and your charger has just failed.
Sep 26, 2010 | Motorola Mobility I335 Cellular Phone
Notbook Power adapter problem
Your power charger is fu.k.d up.  Get you a new charger on e-bay for cheap and try charging.  If that don't work, then the IC card charge port is fu.k.d up.  Open this puppy up and replace the thing.  You can find these parts on e-bay for cheap as individual parts or you can buy you a whole broken computer and use it for parts whenever parts on your computer start to fail.
Oct 31, 2009 | Computers & Internet
Samsung charging problem
If very well could be the charging port. Have you tried a different charger?
If it is the charger port, You have 3 options.
1. get it repaired, warrant if possible
2. Get a new one
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebay2.gif.
For more information and links to the parts check the following link below.
Samsung SGH-D900 charging problem repair
May 13, 2009 | Samsung SGH-D900 Cellular Phone
Computers & Internet Logo
674 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
