Question about Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point
Wap54g setup and troubleshooting
How do i know if the access point is shot or needs firmware or is in warranty or ?
  • SharpElk May 11, 2010
    What are the symptoms?
    Any lights/power ?
    Not connecting to internet ?
    Have you accessed the configuration to check the status?
  • 26 Answers
Try going to 192.168.1.1 if you can get there its most likely the way it is configed.
also try the reset with a pen
linksys is one of the best for support
also try pinging localhost for your adapter
Posted on Feb 27, 2009
Setting up an access point to have same settings as the router?
It seems like it is the issue with the router's firmware. Upgrade or reflash the router's firmware. This will definately solve the issue
Jul 24, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
I want to instal my wap54g wireless access point. i lost the cd that came with it
Go to this web site and download your setup.
http://www.linksysbycisco.com/US/en/support/WAP54G/download
Jan 09, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
Need help need help with WAP54g access point with WAP54g access point I recently had to help try to fix a small office network. Currently it has a netgear ds116 hub with a wap54g connected to the hub for...
Hey !
you said that you that you reset the WAP54G , the default IP address address of WAP is 192.168.1.245.
The IP address that you tried ( 192.168.1.1 ) must be the IP addres of the sonic firewall which might be acting as a DHCP server.
To access the WAP54G set up. you will need to connect the computer to the HUB and the WPA to the hub with the cable and then try to access WPA with the IP address 192.168.1.245
Click Here for more info about Access point
Oct 07, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
2wire 2700hg-b wired router wont allow setup of Linksys WAP54G access point
the ip address of the 2wire router might be different from the ip address being used by the wap54g (ip address is 192.168.1.245 by default) that's why it's not being detected.
you need to directly connect the wap54g to a computer and set the computer to use a static ip address (ex. 192.168.1.240) and run the cd that came with the wap54g. you need to set the ip address of the wap54g to the same segment being used by your router to make them see each other
hope this'll help you and just ask me if you have other concern
ciao!
Aug 24, 2008 | 2wire 2700HG-B Router (2700HGB)
Need Setup CD for WAP54Gv.2 wireless router
perhaps this can help you
http://www.shooter.co.nz/Linksys_WAP54G_setup_procedures.pdf
Jul 14, 2008 | Linksys Wireless-G WAP54G 802.11g/b...
Installing a Linksys Access Point to a Verizon Actiontek wireless router.
The IP Address of WAP54G is 192.168.1.245
Connect a computer to the Access point.
Assign a static IP Address to the computer, like : 192.168.1.10 , the subnet mask should be 255.255.255.0
Open the setup page of the Access point, by typing 192.168.1.245 in Internet Explorer / Firefox. Configure the wireless settings, Change the IP Address to the range that of the Actiontek router.
Save settings. To know about wireless security, click here.
To check the latest update on Linksys products, click here.
Hope that helps :)
Mar 28, 2008 | Linksys Wireless-G WAP54G 802.11g/b...
Linksys WAP54G connection to WRT54G
Ok, so why do you need an access point upstairs and a router downstairs connected wirelessly? If you can't connect with a laptop or a pc, why whould you think you could connect the access point? The purpose of this configuration would have to be with the access point to the router via ethernet. What's the point? If the problem is range, check out http://www.dd-wrt.com/dd-wrtv2/index.php to enhance the capabilities of the WRT54G... and maybe building a parabolic antenna for it as well. Plans to do so abound at Lifehacker.com.
Sep 05, 2007 | Linksys Wireless-G WAP54G 802.11g/b...
Getting The WRE54G To Connect With The WRT54G
The WRT54G, WRT54GS, and WAP54G all must have the latest firmware versions available installed in order to connect with the WRE54G Wireless-G Range Expander. Here are the minimum firmware version requirements that you must meet: * WRT54G (all versions): at least firmware version 2.02.2 * WRT54GS: at least firmware version 2.07.1 * WAP54G (all versions) : at least firmware version 2.07 To Identify your WAP54G Version Number: To find out which version of the WAP54G you currently have, flip your Access Point over to look at its underside. Near the serial number label, near the Linksys© logo, you will see your model number and a possible version. Labels for the WAP54G version will look like one of the following: * WAP54G (no version means Version 1) * WAP54G ver. 1.1 * WAP54G v. 2 For WAP54G Version 1 and Version 1.1 Users ONLY: (if you have a WAP54G Version 2, you may proceed with the 2.07 or later firmware upgrade) NOTE: Before upgrading the WAP54G Version 1 and Version 1.1 models to firmware version 2.07 or later, make sure your Access Point?s current firmware is version 1.09.1 beforehand. The version 1.09.1 code performs an important OS upgrade for these versions of the Access Point -- it must be loaded before using later firmware.
Feb 16, 2006 | Linksys (WRT54GC) Router
Setting up a WAP54G as a wireless repeater with a WRT54G
Requirements for WAP54G & WRT54G Repeater Mode function: * WRT54G: Firmware 2.02.2 or higher * WAP54G: Firmware 2.06 or higher Go to http://www.linksys.com/download to download the latest firmware upgrades for both devices. . Accessing the Router?s Setup Page: Open a Web Browser (either Internet Explorer or Netscape). 1. Type the IP Address of the Router into the Address Bar (192.168.1.1 is the default IP Address). 2. Click GO or press the [Enter] key. The User Name and Password prompt will appear. 1. Leave the User Name field blank. 2. Type admin in for the Password (the default Password). 3. Click OK or press the Enter key. The Router?s Setup page will open: * Click on the Status Tab. * Click on the Wireless sub tab. Write down the Wireless MAC Address and the Channel number values located on this page. If the Encryption Function is Disabled, go to the WAP54G Repeater Setup section below. If Encryption Function is Enabled: Note: WPA (Wi-Fi Protected Access) is not yet compatible with wireless repeater mode. You must use WEP Encryption if you wish to use security options with this configuration. To gather WEP encryption information, click on the upper Wireless tab, then the Wireless Security sub tab. Write down the Passphrase. WAP54G Repeater Setup Be sure that you have the WAP54G plugged directly into one of the WRT54G?s numbered ports for the duration of the setup. Accessing the WAP54G?s Setup Page: Open a Web Browser (either Internet Explorer or Netscape). 1. Type the IP Address of the WAP54G into the Address Bar (192.168.1.245 is the default IP address). 2. Click GO or press the Enter key. 3. The User Name and Password prompt will appear. 4. Leave the User Name blank. 5. Type in admin for the Password (the default password). 6. Click OK or press the [Enter] key. The WAP54G?s Setup page will open. 1. Set the Channel value to the same channel as the WRT54G router that was obtained from earlier steps. 2. If WEP encryption was enabled on the WRT54G: * Select Enable for the Wireless Security option. * Click on the Edit Security Settings button and enter the same Passphrase as the one of the WRT54G router that you recorded. Click Generate to populate the WEP key fields. * Click Save Settings to save your changes and close the encryption window. Click Save Settings to save your changes on the Setup page. 3. Next, click on the AP Mode tab. * Select the Wireless Repeater option. * Enter the WIRELESS Mac Address from the WRT54G that you recorded. (Disregard the fact that the page asks to ?Enter the LAN MAC ADDRESS?). Click Save Settings to save your changes. Close your web browser. You can now place the WAP54G Access Point in another nearby location (with its power adapter plugged in) so that it can repeat the wireless signal that it receives from the WRT54G. Notes: * The ?SSID? of the WAP54G does not have to be the same as the WRT54G. This can be used for initial configuration; using a different SSID will enable testing of network connectivity, and will show that the WRT54G is associated with the WAP54G. * If MAC Filtering is configured on the WRT54G, no extra configuration is needed. Wireless clients will still need to be added the MAC Filter list of the WRT54G, but the WAP54G does not have to on the list.
Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point Logo
222 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
