Question about Canon i850 InkJet Photo Printer
Canon i850 receives message that there is a paper
Canon i850 receives message that there is a paper jam but we find nothing
    Genius:
  • 2,035 Answers
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Mar 31, 2009
Can I reset the EEPROM of a canon print head?
Reset Procedures for Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
you done.
Aug 14, 2012 | Canon BubbleJet i9950 InkJet Photo Printer
My canon i850 is blinking 3 orange lights at me and refusing to print. any ideas. tried turning on and off. removing print driver and re-installing thanks!
3 blinks is a line feed error, something stopping the platen roller from turning, look inside where the paper goes and see if something fell in like an ink pen, paper clip, just something that doesn't belong. The platen roller is the gray roller behind the carriage and sometimes you can see thru under the white plastic guides something jammed.
Nov 25, 2009 | Canon i850 InkJet Photo Printer
Paper jam
NEED TO FAN THE PAPER AND ROLL THE PAPER THAN SURF IT LIKE IT IS ON WAVES OF WATER,
STRAIGHTING OUT PAPER
MAY NEED TO TRY DIFFERENT TYPE OR BRAND OF PAPER.
THERE IS A PROGRAM THAT MAY HELP YOU WITH THIS PROBLEM IT IS CALL
GREENPRINT WORLD DOWNLOAD
ENTER
ROD
Jan 30, 2009 | Canon i850 InkJet Photo Printer
"Clear paper jam" error, but there is no jam!
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
I850 printer error message 5100
GO ONLINE AND TYPE IN
CANON 850i PRINTER ERROR MESSAGE 5100
ENTER
ROD
Jun 19, 2008 | Canon i850 InkJet Photo Printer
How do I clear jammed paper when there is no paper showing
I JUST MANAGED TO CLEAR MY PRINTER.  I UNPLUGGED EVERYTHING AND PUT MY FINGERS IN WHERE THE PAPER ROLLS IN.  I ROLLED THE ROLLER UNTIL I FOUND THE TORN PAPER.  GINGERLY I REMOVED IT.  NOT EASY.  MY PRINTER WORKS AGAIN! ALFIANNA
Apr 03, 2008 | Canon i850 InkJet Photo Printer
Reset following paper jam
It sounds like a bad paper sensor and the printer needs to be serviced. Your only bet is to try to clean it out.
Dec 02, 2007 | Canon i850 InkJet Photo Printer
I860 False Paper Jam Message
Check the back of the printer. There should be door at the bottom. Your paper jam could be there.
If this helps you, please rate me. Thanks, Patty
Nov 06, 2007 | Canon i860 InkJet Photo Printer
Canon i850 InkJet Photo Printer Logo
old marine
old marine
