Question about Microsoft XBox Controller S ( Brand) X-Box (XBOXNAC006)
FORD MONDEO CENTRAL REAR SEAT BELT
THE SEAT BELT IS JAMMED, ANY IDEAS HOW TO GET TO THE BITS INSIDE THE REAR SEAT
  • davuk80 Mar 29, 2009
    My middle seat belt on my mondeo is stuck and won't pass the mot without fixing it. Can't get to it because it seems to be sealed inside the seat.
This worked, you do have to push it really hard, thanks
Posted on Oct 01, 2009
  • madmax09 Oct 01, 2009
    This worked well, thanks you do have to slam it back really hard
Me too… found this though - hav'nt tried it yet though.
http://www.honestjohn.co.uk/forum/post/index.htm?t=12183
Posted on May 11, 2009
  • danniob May 11, 2009
    Just tried it… worked first time - don't you just love the "interweb".
2011 ford mondeo, seat belt won't lock for child restraint. I have pull out slowly
seat belts on all cars only lock when the brakes are applied or some thing is hit.
Oct 22, 2017 | Ford Cars & Trucks
I have 2012 ford mondeo hatch and the middle rear seatbelt is locked. We can not pull it out. Can this be fixed at home? Or does the whole seat need to be replaced or repaired at ford?
You do not fix seat belts you replace them, the chance of the seat belt retractor not functioning correctly and failing to lock the belt in a collision is just not worth saving a few bucks, wouldn't you agree?
Nov 16, 2016 | Ford Mondeo Cars & Trucks
How do i fix a jammed rear seat belt
You must remove the rear seat bottom and remove the bolt for the seat belt retractor, this will allow you to in jam the seat belt.
Dec 13, 2015 | Vauxhall Astra Cars & Trucks
Need to change fuse for cigar lighter in 2003 ford mondeo zetec?
On this website you find fuse box diagram and description for Ford Mondeo (2000 - 2007)
Ford Mondeo mk3 2000 2007 fuse box diagram Auto Genius
Nov 06, 2012 | 2003 Ford Mondeo
Seat belt on rear seat has jammed
This happens to me also. To solve the problem you need to un-bolt the seat belt clip. A bit tricky when the bench is tight down, but get a friend to hold it up out of the way as much as possible. This will relieve the tension and allow the seat belt to return to normal. To prevent this in future, pull the seat belt out and clip it in to place before lowering the back bench. This allows enough slack on the seat belt tensioner to stop the problem from happening again.
Aug 30, 2009 | 2000 Volvo V40
Ford Mondeo Mk3 Estate 2L. Air bag / seat belt Warning Light
Common fault on FORD
Usually due to a poor connection in the YELLOW PLASTIC CONNECTOR underneath the passenger seat.
Just push it together properly and it should clear the AirBag fault
Jun 30, 2009 | 1999 Ford Taurus
I have lost the key which is the only one which opens the bonnet on my 52 ford mondeo
Take it to a lock smith and he can make a new key otherwise remove the back seat climb in and remove the c clip holding the lock on and remove the screw from the lock and pull out and take to the lock smith to get a new key made. To remove the rear seat pull the carpet away from the lower front of the carpet find two bolts one on each side and remove pull up on the seat and remove seat next find bolts to back of seat and remove lift up on the rear seat and pull out and away from the trunk then crawl inside to remove the lock,
Jun 18, 2009 | 2003 Ford Focus
Ford mondeo mk2 wiring
The easiest option is to purchase a HAYNES WORKSHOP MANUAL.
where there are all the wiring diagrams in the rear (Available on Ebay etc)
If you have a particular Mondeo problem, then this free site can be very useful
http://www.mirez.co.uk/map.htm
Apr 07, 2009 | 1997 Ford Taurus
How to fold Ford Mondeo rear seats
Has it not got the buttons on the top of the seats?
Simply press and pull down.
Sep 26, 2008 | Kettler Mondeo Elliptical Trainer
Microsoft XBox Controller S ( Brand) X-Box (XBOXNAC006) Logo
1,497 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
